Old 05-05-2002, 08:47 PM   #1
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
Question Swaping internal wastegates
Hey guys, I want to upgrade to a WRX turbo but don't want to run 8psi (or whatever) everyday. I was talking to a DSM friend of mine and he said to see if I could take the wastegate off the WRX turbo and put on the wastegate from my RHB5 turbo (5psi spring). Looking at the turbo's he has it was 2 bolts and a cottor pin. Looking at my RHB5 it was 2 bolts, but instead of a pin in looks like a spot weld or something. Something more permenent anyway. I know that the rods would have to be the same length and shape for this to work, but has anybody tried, or can shed some light on this for me?
Thanks,
Mike
Legacy GTR is offline   Reply With Quote
Old 05-05-2002, 08:59 PM   #2
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
Oh, I have that 90* elbow on the turbo inlet, could I use that on the TDO4?
Mike
Old 05-05-2002, 09:35 PM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
As far as swapping wastegastes, you could probably do it, though you might have to do some modification to the actuator rods and mounts for the wastegates. When I initially set up my turbo (RHB5) I had to clock the turbo. This also resulted in having to relocate the wastegate, and we ended up having to drill an extra hole in the wastegate mount (there's only two screws for it) for it to fit. I do know that the wastegate mount for the TD04 is somewhat bent/not flat like the ones found on the Legacy turbo's. You may find some problems in trying to adapt these two together.
I have been considering the same upgrade as you, but finding the right springs for the turbo's is somewhat of a setback. I don't know of anyone who makes different internal wastegate springs for IHI turbo's, so I sort of gave up. Another option is obviously to use an EBC, or put on an external wastegate. For this, the internal wastegate on the turbo would have to be welded shut (that little gate) and/or disabled.
If you find anything out, let me know.
Oh, I am not sure if the 90 degree elbow will fit or not. I ended up not using mine, as the fabricator just made a custom mount for me instead. I doubt that the intake inlets on the two turbo's are the same size, but you could probably build some sort of a step-up to compensate.
Graham
Graham is offline   Reply With Quote
Old 05-05-2002, 10:13 PM   #4
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
What are those rods made out of? If it's weldable I could cut the rods, put the RHB5 spring side and reld it to the rod on the TDO4. I would just get an external wastegate but half the reason I was going to do it was because i'm installing a FMIC, and figured it would be a good time. But I don't have the money for an external wastegate right now. Oh well.
The outlets are the same size. I'm not sure what that size is, but the intercooler is made for the WRX and the pipe that fits on the outlet fit on the RHB5 just fine.
Mike
Old 05-06-2002, 09:44 AM   #5
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Have you considered an external wastegate?
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 05-06-2002, 02:52 PM   #6
inpreza kid
Member#: 3334
is it possible to cut the wastegate spring?
inpreza kid is offline   Reply With Quote
Old 05-06-2002, 06:04 PM   #7
STiTuner
Member#: 5778
09 135i
Jet Black
don't do it
Brad
knows what not to do
STiTuner is offline   Reply With Quote
Old 05-06-2002, 06:31 PM   #8
inpreza kid
Member#: 3334
i got my wrx turbo today. the rod that connects to the wastegate is ajustable but i don't know what the range is.
Old 05-06-2002, 09:17 PM   #9
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Its adjustable? Are you sure about that?
I have heard of "shimming turbo's", which consists of shortening the wastegate actuator rod, but I'd be weary of doing anything like this, as you never know what ramifications it may have.
Graham
Old 05-06-2002, 09:59 PM   #10
SPeeDSiN
Member#: 4667
Black (well kinda)
never really understood what shortening of the rod would do. could anyone elaborate?
SPeeDSiN is offline   Reply With Quote
Old 05-06-2002, 10:19 PM   #11
inpreza kid
Member#: 3334
this is just a GUESS but if you shorten the rod it will cause the wastegate spring to tighten up. this will cause the wastegate to bleed off at a higher boost pressure than before.
here's a pic. sorry for the quality. i'm not sure what the limits of the wastegate will be if you ajust the bolt.
Old 05-06-2002, 11:08 PM   #12
STiTuner
Member#: 5778
09 135i
Jet Black
by adjusting that bolt you will by making it longer alwasy let the bypass bleed.... making it shorter would... umm well you can only make it so short.
I don't see how you'ld be able to fit like a legacy wastegate or anything else on there if you have ot clock the turbo though. for the simple fact that between the coolant feeds oil feed and where the position of the valve sits.... I don't see any room for it.
as far as I know the only option you have if you go the route of clocking the turbo is to weld the valve shut.
Brad
has his turbo sitting on his desk
Old 05-07-2002, 02:23 AM   #13
inpreza kid
Member#: 3334
so would ajusting it longer or shorter make it bleed at a lower boost pressure?
Old 05-07-2002, 08:21 AM   #14
STiTuner
Member#: 5778
09 135i
Jet Black
by making it longer you will bleed more exhaust gasses.
Brad
Old 05-07-2002, 09:27 PM   #15
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
Couldn't you also solve the problem, at least a temporary solution, by have your BOV vent while the TB is open, or would that just be counter-productive?
scoobyguy is offline   Reply With Quote
advantages of external wastegate over internal wastegate? petawabit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-04-2003 02:54 AM
needed bigest turbo w/ internal wastegate, suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-15-2002 01:51 PM
WRX Turbo Internal Wastegate Question seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-29-2002 12:56 AM
Stock Turbo on WRX External or internal Wastegate??? VallejoWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-11-2002 10:12 AM
Testing spring strength of internal wastegates... MPREZYA Normally Aspirated with bolt-on Forced Induction Powertrain 9 09-25-2001 06:23 PM
