Old 08-26-2009, 03:40 AM   #1
subystone
Member#: 138598
wrx impretza saloon
ralle de mundo azul
Question anyone use blouch TD04 19T???
has anyone used this turbo??? i was thinkin about going with it. i don't want much more power plus i want to keep this response i have already. i plan on competing in the auto-x this next season. i have a couple more cooling to do and the rear suspension left and i'll be good to go. would it be wise to use bigger injectors with just an upgraded compressor in a TD04?
subystone is offline   Reply With Quote
Old 08-26-2009, 12:40 PM   #2
SacksLax
Member#: 193949
Yes get larger injectors
SacksLax is offline   Reply With Quote
Old 08-26-2009, 12:56 PM   #3
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
WhyHelloOfficer is offline   Reply With Quote
Old 08-26-2009, 02:51 PM   #4
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
Definitely larger injectors for the larger compressor. Even Jerry at Deadbolt recommended pinks for their Monster TD-04 and that didn't have a larger compressor.
sanremo_russ is offline   Reply With Quote
Old 08-26-2009, 04:16 PM   #5
WhyHelloOfficer
Member#: 193989
Australian Racecar
Absolutely larger injectors. My IDCs are 98% and up and my car is still running the stock TD04.
Old 08-26-2009, 04:29 PM   #6
samo22
Member#: 119693
1995 L w/ ej205
I'm also interested in how this turbo performs. The only result out there are Surfer Steve's results though. You should probably upgrade the fuel pump at the same time.
samo22 is offline   Reply With Quote
Old 08-26-2009, 05:19 PM   #7
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
Yep and throw an intercooler on there + a tune and your good to go...
Old 08-26-2009, 06:13 PM   #8
Mekks
Member#: 219749
ive also been looking into this option.
Mekks is offline   Reply With Quote
Old 08-26-2009, 06:17 PM   #9
05wrx09
Member#: 204111
2005 WRX
I've heard great things about the Blouch TD04 19T, but always wondered how it stacked up against a VF39 for example. I guess those links were helpful in showing it's more powerful. I wonder how much more reliable it is? For $300-400, I guess you can't beat that kind of performance.
05wrx09 is offline   Reply With Quote
Old 08-26-2009, 07:11 PM   #10
Strider327
Member#: 131280
2004 Impreza WRX
The Blouch TD04 19T is the biggest TD04 turbo you can get. The characteristics of this turbo is low end and mid-range power. Spool is increased by 500rpms (faster). The VF39 has mid-high eng power. Spool is around 3500 RPM instead of 2800RPM with the 19T TD04. It really depends on what your gonna use it for.
Strider327 is offline   Reply With Quote
Old 08-26-2009, 07:15 PM   #11
05wrx09
Member#: 204111
2005 WRX
So the TD04 has no top end? In that one dyno chart it looked like the TD04 had more power up top. Maybe I have that backwards.
I just want a powerful daily driver basically. My friend has a VF39 on his 06 WRX (totally different animal with the EJ255 I know) but that thing is a beast and he takes Stage 2 STis all day long with his Protune.
I want to be able to beat him. I'm already down with power with the EJ205 so I have to make up for it somewhere! I wanted a VF43, but it's about the same price used as sending my TD04 to Blouch for an upgrade to the 19T.... which would be better?
Old 08-26-2009, 08:09 PM   #12
Strider327
Member#: 131280
2004 Impreza WRX
If your on a budget get a VF34, VF43 or 16G standard. Either one will do the job easily. You can find those used laying around on the forums.
Old 08-26-2009, 08:20 PM   #13
samo22
Member#: 119693
1995 L w/ ej205
I've seen some people with 16g wheel in the td04. Is 16g bigger than 19t or no?
Old 08-26-2009, 08:24 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by 05wrx09 View Post
I want to be able to beat him.... which would be better?
a P&P 16g running 24psi and alky injection and 650's and lots of other stuff and a REAL good tune
FORGET anything td04 based....not happenin....no....not gonna catch a vf39'd 06 with that
Old 08-27-2009, 12:16 AM   #15
05wrx09
Member#: 204111
2005 WRX
Well as it stands, I'm considering a VF43 if I can find a decent one with low mileage that isn't too pricey. Then I want to get it PnP and coated.
Then some of Grimmspeed's PnP services (IM, TGVs, etc) and an E85 tune on 850cc injectors. That should get me more horsepower than he has, although I'll never have the torque of the EJ255
Old 08-27-2009, 12:46 AM   #16
Mekks
Member#: 219749
the spool of the 19t td04 sounds good, but i dunno, p%p small 16g sounds better imo. might not hit 300hp but it should be really fun around town,
Old 08-27-2009, 01:55 AM   #17
Strider327
Member#: 131280
2004 Impreza WRX
good street setup
EVO III 16G PnP EWG
Old 08-27-2009, 02:28 AM   #18
05wrx09
Member#: 204111
2005 WRX
good street setup
EVO III 16G PnP EWG
Man...
an Evo III big 16G on my little 2.0 would murderalize my friend's 06 with a VF39
Old 08-27-2009, 02:56 AM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
I would pass on coating the turbo and just wrap it......and coat/wrap the entire exhaust from the heads to the end of the dp
that and the rest of the above would be enough to pop the trans......
I would LOVE to have a well done 2.0 in a light shell with 4.11fd/gears/lsd's on e85 and an evoII
Old 08-27-2009, 03:01 AM   #20
05wrx09
Member#: 204111
2005 WRX
What I wouldn't give for a PPG Dogbox
Old 08-28-2009, 09:20 AM   #21
subystone
Member#: 138598
wrx impretza saloon
ralle de mundo azul
man thanks for all the responses! damn, really helpful thread for me! okay i have a top mount bigger than the spearco. it's good to know the injectors and fuel pump. i'll do those. sounds like this turbo is better than i even thought before! i would never do the turbo without a better tune. i'm os tuned now and hell i love it. great tune. runs sooooooooooooooooo smooth. i spool FULL around 3100 and still get 26mpg ha ha.
05wrx 09 my buddy had an 06 with just stage 2 and holly hell that thing WORKED sti's like they were not even turbo'd ha ha. the 2.5 IS a completely different beast. i like holding it down for the 2.0 though. i'm not much for straight lining though. i'll be autocrossing this car. or at least till i pick up a fozzy for a dd then i can track this one.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
Anyone use the Blouch 19t TD04 upgrade? illt3ck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 10-19-2008 11:48 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
