Old 08-26-2009, 06:10 PM   #1
Brad Pittiful
Member#: 34931
Default Where did my color red go? Is my monitor dying?
having some problems with my monitor...it seems like its trying to come on and the little light keeps flashing...after it finally came on the color red seems to be missing
i turned the monitor on its side to remove the cable from the pc to the monitor...did i maybe hit something to make the red go away
no problems with this thing until last firday...when the problem started happening...then happened again on sunday...and again today...the monitor is a hanns-g hx 191
Brad Pittiful is online now   Reply With Quote
Old 08-26-2009, 06:12 PM   #2
gramicci101
Member#: 64763
The cake is a lie.
You turned the monitor on its side?? All the red drained out through the cable. Staples has replacement cartridges.
gramicci101 is offline   Reply With Quote
Old 08-26-2009, 06:12 PM   #3
chris619
So Special
Member#: 59470
show me on the rug
where he banned you
did you know that blood is actually BLUE? but the oxygen turns it red.
*the more you know.jpg*
chris619 is offline   Reply With Quote
Old 08-26-2009, 06:14 PM   #4
Brad Pittiful
Member#: 34931
i thought that was an urban legend...wow
no its not
Old 08-26-2009, 06:17 PM   #5
Howl
Member#: 57830
Communists propaganda.
Howl is offline   Reply With Quote
Old 08-26-2009, 06:19 PM   #6
chris619
So Special
Member#: 59470
show me on the rug
where he banned you
no its not
if i read it on the internet, it must be true
Old 08-26-2009, 06:22 PM   #7
snaps
Member#: 193012
15 wrb WRX
Look! Something shiny!
I think the government took it so they could raise terror levels again.
snaps is offline   Reply With Quote
Old 08-26-2009, 06:23 PM   #8
Brad Pittiful
Member#: 34931
its a first on the internets that something written on it isnt true
Old 08-26-2009, 06:28 PM   #9
NightHawk
Member#: 175181
the oxygen rich blood traveling from your lungs to the rest of your body is red.
the blood traveling to the lungs to be oxygenated is blue.
I think.... I'm an EMT on paper only
NightHawk is offline   Reply With Quote
Old 08-26-2009, 06:37 PM   #10
Brad Pittiful
Member#: 34931
where the **** is my red!
Old 08-26-2009, 06:38 PM   #11
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
You're using a VGA cable, or DVI/HDMI?
I assume VGA.
Either the cable is bad or the connector on the monitor. This happens with VGA monitors, both LCD and CRT. A solder joint or something breaks down after a while.
There's a Dell 19" LCD at work doing the same thing, we were laughing at the guy today.
rogue is offline   Reply With Quote
Old 08-26-2009, 06:40 PM   #12
testify
Member#: 196517
2007 n00b rocket
urban grey metallic
My monitor at work has actually had a green tint to it at times lately. I just smack it around a bit and it goes back to normal.
testify is offline   Reply With Quote
Old 08-26-2009, 06:47 PM   #13
Brad Pittiful
Member#: 34931
I assume VGA.
well when i unplugged the cable and tried to reinsert it...it wouldnt go in...i didnt do anything not normal in reinstalling the cable...i looked at it and some of the prongs were not aligned and bent...i straightened them out and plugged it back in...now im missing the color red
Old 08-26-2009, 06:48 PM   #14
gramicci101
Member#: 64763
The cake is a lie.
You broke a pin or a wire. New cable time.
Old 08-26-2009, 06:52 PM   #15
Brad Pittiful
Member#: 34931
but why has the monitor been acting weird recently...i havent touch that cable in months for it to have any bearing on the red color missing today...is the monitor starting to go
Old 08-26-2009, 06:56 PM   #16
Hazdaz
Member#: 14611
Ya got a spare videocard that you can try? Or a spare video cable?
My guess is that one of those 2 is on it's way out. Cables tend to last forever, but it does sound like in this particular case it's at fault.
Hazdaz is offline   Reply With Quote
Old 08-26-2009, 07:04 PM   #17
Brad Pittiful
Member#: 34931
ok all the cable suggestions made me check it out again...and guess what...i wiggled it and my red has returned
so whats this mean...i didnt have the cable set right...or is the cable still messed up and i should get a new one
Old 08-26-2009, 07:07 PM   #18
Hazdaz
Member#: 14611
Well if it's back - and stays back - then don't worry about it.
But if it comes and goes, then some connection is loose. Be it from the videocard, the cable, or even the connector on the back of the monitor. Is the cable screwed in nice and tight? (you know, using those thumbscrews that the cable has)
Old 08-26-2009, 07:10 PM   #19
Brad Pittiful
Member#: 34931
very cool man...and on the last part of your post...yes it is tight using the screws that came with the cable...even though its tight i could still move the connector somewhat...it fixed the problem...for now
Old 08-26-2009, 07:13 PM   #20
Hazdaz
Member#: 14611
then DON'T MOVE IT! You might have a loose connection within the monitor itself, which would be a bigger issue to fix, so as long as it works now, screw it - leave it alone!
Old 08-26-2009, 07:17 PM   #21
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
This.
Old 08-26-2009, 07:19 PM   #22
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
When these go, they tend to gain and lose connectivity based on heat.
Old 08-26-2009, 07:23 PM   #23
TarmacRally
Member#: 85805
... Shiny & Chrome
Witness Me!
can you read this?
TarmacRally is offline   Reply With Quote
Old 08-26-2009, 07:26 PM   #24
Brad Pittiful
Member#: 34931
dont worry i wont
ill keep an eye on this
Originally Posted by TarmacRally View Post
can you read this?
yes i can...but if i couldnt and i didnt see any text i would just highlight it with the mouse so i could see it
Old 08-26-2009, 07:27 PM   #25
chris619
So Special
Member#: 59470
show me on the rug
where he banned you
can you read this?
SCIC moderators: Where did a certain thread go? subaru kym Southern California Impreza Club Forum -- SCIC 1 04-16-2003 03:13 PM
Hmm.. Where did the brake bolt go? I wonder if I need it? yebokmj New England Impreza Club Forum -- NESIC 7 12-21-2002 07:58 AM
Where did the SXPi thread go? tytlyf Southern California Impreza Club Forum -- SCIC 38 05-09-2002 07:02 PM
swrt.com - where did the old galleries go? fellfrosch7 Motorsports 5 09-21-2001 08:18 PM
