Old 08-26-2009, 07:36 PM   #1
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
Default final steps in painting wheels
After several days of work, I'm approaching the final steps in painting some wheels a dark gray color. I've taken my time and tried to do a decent job. Steps so far:
1) cleaned
2) sanded
3) cleaned
4) primed
5) sanded
6) cleaned
7) painted
The paint feels slightly gritty so I'm thinking I should wet sand (suggested grit?) before applying the clear coat, but it seems like even a very fine grit will leave marks. Should I wet sand, then apply one more even coat of paint before clear coating? Should I wet sand after clear coating?
nhmtns is offline   Reply With Quote
Old 08-27-2009, 10:45 AM   #2
genkidama20
Member#: 73635
04 WRX
WRB Wingless
It depends on your definition of "slightly gritty"... the clear coat should smooth out most of it if you're worried. Personally, I wouldn't worry. You'll probably curb your wheel and then all your hard work will go to waste. Atleast that's what happened with me
genkidama20 is offline   Reply With Quote
Old 08-27-2009, 08:13 PM   #3
nhmtns
Member#: 94283
'05 OBXT
Min bil är svart
Well, I ended up wet sanding with 2000 grit and the paint feels very smooth now. Even with a fine grit, I still managed to take off a little too much on the ridges of the spokes. I will probably respray one coat and wet sand again tomorrow, but do it very lightly. I've heard you can use rubbing compound to bring out the shine, but I'm not sure I'll do this before clear coating.
Final Step in my EJ257 build..."To sleeve or not to sleeve?" Wrx_Fan_0717 Built Motor Discussion 36 07-14-2010 04:36 PM
Finally Gov't steps in with Scammers kyozou77 Off-Topic 2 05-08-2007 01:20 AM
Steps in insure good paint job on scoop BIGSKYWRX Interior & Exterior Modification 4 12-24-2004 05:04 PM
Well, I'm finally stepping up... Maybe a new record contender Blugin Proven Power Bragging 37 07-29-2002 07:56 PM
FINALLY!! SOA.. step in the right direction wistful General Forum Archive 19 03-05-2001 10:46 AM
