Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 08-26-2009, 09:28 PM   #1
06bluebird
Member#: 168145
06 Stg. 3 Wagon
2015 WRX GBP
Default Need some help GUYs. CEL on 3 CODES
hey guys. maybe some of you guys could help me out. I have a 2006 WRX stg 2 cobb. 54000K
my cel turned on.
codes Read are:
P1507 IDLE SPEED CONTROL AUX INPUTS
P0301 MISFIRE #1
P0304 MISFIRE #4
I HAVE A FEELING THE MISFIRES HAVE TO DEAL WITH THE P1518 CODE. HAS ANYBODY GOT THESE SIMILAR CODES???
HOPEFULLY I COULD GET SOME HELPFULL INFO. THANKS GUYS.
06bluebird is offline   Reply With Quote
Old 08-26-2009, 10:30 PM   #2
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
P1518 Starter switch circuit low input
Not sure what the missfires would have to do with the starter...
I would check your plugs change them If they havent already been changed in the last 30k miles, If your problem continues I would start swapping coil packs to see if the problem follows the coils, then atleast you would know what to replace
07wrx4life is offline   Reply With Quote
Old 08-26-2009, 10:39 PM   #3
stisubie8787
Member#: 196636
04 subaru sti
black
the p1518 has somting to do with the starting system has your car starter ever not cranked the ignition was turned over i couldent find anything on the 1507
stisubie8787 is offline   Reply With Quote
Old 08-26-2009, 10:44 PM   #4
07wrx4life
Member#: 171514
07 DOM 3 WRX
Originally Posted by stisubie8787 View Post
I couldent find anything on the 1507
P1507 Idle Control System Malfunction (Fail-safe)
Not sure what that exactly means so thats on both of us
http://forums.nasioc.com/forums/show...ighlight=P0607
Old 08-26-2009, 10:51 PM   #5
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
have no idea what p1518 has to do with any of this, but the p1507 is your idle air control system. If your idle air control valve is sticking or is clogged, it will cause your vehicle to idle kind of lopey. It will sound almost as if it has cams. Also, when you start your car cold, it may idle abnormally high for a few seconds and then suddenly drop rpms. If the idle air control valve gets bad enough, your motor will shake slightly at idle, which can cause your engine to throw misfire codes. If your idle is similar to this, I would try replacing your idle air control valve, and see what that does for you. They run about $235 from a dealership, but you can probably find a decent one used on here for WAY cheaper. Now, if your idle is not like this, then this information does not really apply...
amalgrover is offline   Reply With Quote
Old 08-26-2009, 11:01 PM   #6
Subawroo
Member#: 221709
Default ....
I have seen some in my experiance with carbon and varnish build up,
you maybe able to clean it with some kinda of solvent, Kinda suprising
to see it fail at 54K i havent run into that at my dealership yet, have you
tried clearing it with cobb to see if it was a fluke?
Subawroo is offline   Reply With Quote
Old 08-27-2009, 09:22 PM   #7
06bluebird
Member#: 168145
06 Stg. 3 Wagon
2015 WRX GBP
Default CEL on
hey thanks guys for the info. as far as clearing the code i have. it hasnt gone of since ive cleared. but my car the does idle a little loopy. also my car wont start on first crank i been having this problem for over a year now.., which is weird because it only acts this way in the summer. i have to constantly feather the cluth in & out till it finally cranks over. its starting annoy me now.?? any clue guys?? i have a feeling its my clutch switch but not exactly sure.
Old 08-28-2009, 01:26 PM   #8
PERRIN
NASIOC Manufacturer
Member#: 6776
06bluebird: Lets go back to basics for a moment. What changed on the car before the codes came on?
Have you checked the plugs and coil packs? (Both common problems.)
Might be a ground loose to a section of the engine harness that affects the ignition and the idle air control.
Happy to help with this if we can. Unless you made some mods to the car right before this I suspect it is something simple.
Keep me posted!
Adam
PERRIN Performance
PERRIN is offline   Reply With Quote
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 10:21 AM
Need some help with this check engine code!! pornstar1969 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 12-10-2006 10:55 AM
Need Some Help Guys Bumsarama Interior & Exterior Modification 4 01-14-2002 06:49 PM
('93-'01) Need some help guys...??? fletch9871 Impreza Forum 1 04-16-2001 06:34 PM
