Old 08-26-2009, 11:30 PM   #1
KillerBlackbird
Member#: 117268
Default Volk SE37K, 08 STi, will it fit?
So I have found a set of SE37K's in 18X8.5 with a +40 offset. Anyone have an idea if these will clear the Brembos on my 08 STi? I plan on running a 245/40-18 tire so I shouldnt have rubbing issues.
KillerBlackbird is offline   Reply With Quote
Old 08-26-2009, 11:41 PM   #2
mosc
Member#: 177401
2015 STi White
you'll be 15mm closer to the fenders thanks to that small offset so you indeed might have rubbing mattering on your suspension. Brembo clearance I'm not sure about but I doubt it's a problem.
mosc is offline   Reply With Quote
Old 08-26-2009, 11:50 PM   #3
KillerBlackbird
Member#: 117268
Thanks.
I was kinda thinking the same about brake clearance since the TE37 and CE28N in the same size and offset fit, but the spoke design is different. You are right, it might rub on the fender lips, or it might be close. I will be running the stock tire size 245/40-18.
Old 08-27-2009, 01:54 AM   #4
KillerBlackbird
Member#: 117268
Through a little searching, a 17X8.5 +50 SE37K fits over the stock STi Brembo on an 04 so a +40 in the same width should fit...theoretically. I think I'm gonna take a chance and do it.
Old 08-27-2009, 02:39 PM   #5
450 slug
Member#: 221778
Default offset
i having trouble figuring out whta i can get away with
450 slug is offline   Reply With Quote
Old 08-27-2009, 03:31 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
good post
k&n typhoon off 04 sti, will it fit 06 wrx? subyman99 Newbies & FAQs 2 04-08-2007 06:44 PM
Cusco Rear Sway for 04 sti, will it fit an 04 WRX Wagon? YumGTR Brakes, Steering & Suspension 4 01-04-2006 12:09 PM
Racing Hart cx on STi will it fit? Prelude2theSTI Interior & Exterior Modification 0 03-16-2005 09:58 PM
volk ce28n 17x8.5, will it fit? TYPE wRx Tire & Wheel 5 07-15-2003 06:23 AM
Pic: AEM CAI in STi, will it fit??? GDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-25-2002 09:19 PM
