Old 08-27-2009, 12:56 AM   #1
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Default Pick tire size that emulates final wheel rate of 6sp tranny
I have a WRX with the stock 5sp and a set of 16x7 wheels with 205/55/16's on them. Compared to my friends 02 bugeye WRX with 6sp swap on 17x7.5 215/45/17 tires, we found that his 2nd gear (along with everything else) was better suited for the power band on the local rallyx courses.
If I wanted to emulate his final drive at the wheel but ONLY picking a different tire size (in order to cheaply get closer to his ratio to operate in the better part of the power band), what size would that be and how do you calculate it?
(The 6sp trans' 2nd gear is noticeably shorter. My rallyx instructor commented that in contrast to my friends 6sp 2nd gear, I really need something in between my 1st and 2nd gear ratios. I'm not about to swap trannys or gearsets yet, so I'd like to go with tire if possible.)
chimchimm5 is offline   Reply With Quote
Old 08-27-2009, 08:37 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
first you need to find out what the gear ratios are for both transmissions and also both differentials. You can then start to figure out the needed revolutions per mile and make you tire size selection based on that figure
Old 08-27-2009, 02:34 PM   #3
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
according to cars101, the 2006 impreza has:
5speed manual
1st- 3.454, 2nd-1.947, 3rd- 1.366, 4th- 0.972 5th- 0.738, final 3.7
So (2nd)*final = 7.2039
6speed manual
1st: 3.636, 2nd: 2.375, 3rd: 1.761, 4th:1.346, 5th:0.971, 6th: 0.756, final 3.9, reverse: 3.545
So (2nd)*final = 9.2625
225/45/17 radius 12.3in circ 77.3in revs/mile 819.0
How do you figure out the desired wheel from here?
Anyways, from the ratio above, it does not look like it would be practical to compensate with just the tire size. Too great a difference.
Looks like I want a 6sp swap.
Old 08-27-2009, 02:44 PM   #4
Web Foot STi
Member#: 39086
2004 STi
Here it is from R&T
5spd/6spd 7.61 vs. 9.25 Overall second gear ratio.
http://www.roadandtrack.com/reviews/...mpreza_wrx.pdf
http://www.roadandtrack.com/assets/d...2003134229.pdf
Stock STi tyre is ~24" dia. For the same overall effective ratio you would need ~19.7" tyre.
Note: R&T is for a 2002 WRX.
You are even worse off: Dia=(24"/9.25)*7.2= 18.7" tyre dia!
Web Foot STi is online now   Reply With Quote
Old 08-27-2009, 02:52 PM   #5
Web Foot STi
Member#: 39086
2004 STi
Engine rpm, wheel rpm, or vehical speed (MPH)?
It's all just ratios.
MPH = (rpm* Static Loaded wheel Radius" {SLR})/(overalll drive ratio*168)
Example:
MPH = (7200*12)/(9.25*168) = 55.6 mph.
Tire Sizes that fit That Rim Lynk Tire & Wheel 7 02-20-2007 10:54 PM
Tire sizing to alter final drive.... Illusive Tire & Wheel 12 12-01-2005 06:00 PM
Best Tire Size for my RS wheels Unsung Boxer Tire & Wheel 7 01-26-2004 02:28 AM
tire size for 7 in wheel Rodan Tire & Wheel 5 03-20-2003 11:28 AM
Tire size w/17 inch wheel Girlie22B New England Impreza Club Forum -- NESIC 1 02-18-2002 08:59 PM
