Old 08-27-2009, 02:14 AM   #1
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
Default need to run a 10mm spacer to clear brembos. what size stud to get?
what size stud should i get? 35mm or 45mm with a 10mm wheel spacer?
wildacex187 is offline   Reply With Quote
Old 08-27-2009, 12:15 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
45mm is stock length i believe so 55mm or longer.
Old 08-27-2009, 01:10 PM   #3
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
What kind of rims?
are they drilled for 5holes or 10?
If they are drilled for 10 holes, I woul suggest buying a spacer that bolts on to your OEM hubs. This way you 10mm spacers and non brembo rims are relatively pnp.
Louie is offline   Reply With Quote
Old 08-27-2009, 02:50 PM   #4
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
i ended up going with the ichiba 35mm extended studs. site says they're good up to 15mm spacing
Old 08-27-2009, 04:04 PM   #5
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
stock is 45mm and you went with 35mm? or they are 80mm? Be sure to pick up open ended lugs if thats the case.
Old 08-30-2009, 12:46 AM   #6
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
i meant to say 45mm. just got these in today and they dont look much longer than stock. apparantly its 45mm of usable thread. u think that will be enough? i dont want to spend so much on arp's
Old 08-30-2009, 12:46 AM   #7
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
according to this stock is 41.50. hopefully the extra 3.5mm will make a difference?
Old 08-30-2009, 02:24 AM   #8
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
umm just to add that the wheels are 18x7.5 50mm 5zigen fighters. im starting to think that i wont be able to fit these wheels .
Old 08-30-2009, 10:52 AM   #9
nhat
Member#: 140163
03 STi
hellaflunctional
return them and pick up either nismo 60mm or arp 80mm studs. better yet, sell the wheels and find a set that's wider with a lower offset since that's what you're looking for!
Old 08-30-2009, 02:05 PM   #10
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
yea i think this is the choice im going to go with
Old 08-30-2009, 09:03 PM   #11
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I would just get spacers that have studs attached to them like the project kics.
Old 08-31-2009, 04:32 AM   #12
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
the minimum is 15mm, wont that be too much?
Old 08-31-2009, 07:33 AM   #13
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
the minimum is 10mm (I have a set) HR Auto has them (vendor here). I do not know how much clearance you need. Assuming that your rimes are 45-50 offset now it will lower them to about 30-35. That will mean you will need to have your fenders pulled and rolled. It might be cheaper to get different rims.
Old 08-31-2009, 12:07 PM   #14
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
i cant seem to find 10mm bolt on spacers anywhere on this site, can u link me?
Old 08-31-2009, 03:07 PM   #15
nhat
Member#: 140163
03 STi
hellaflunctional
10mm bolt-on spacers will not work because they are not wide enough to accommodate the length of the stud coming out of the hub and the required lug nut without hitting the backside of the wheel. if you want to run a set of 10mm spacers, buy the extended nismo 60mm or arp 80mm studs and get them pressed in.
i believe the minimum width for a bolt-on spacer is 25mm.
Old 08-31-2009, 05:37 PM   #16
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
This is both true and otherwise. Both my Rota SVN's and Gramlights are drilled for 5 lugs at 5x144.3 and a set of dummy holes. My lug bolts pass into these without protruding into the face of rim. Meaning they are still in the holes in the backplate of the rim.
You cant even see the end of the lug bolts, but they are in there.
You can buy 10mm spacers here:http://www.evasivemotorsports.com/Me...de=KICS-5010W3
I bought mine from another vendor, because these guys were out of stock.
Old 09-03-2009, 08:14 PM   #17
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
well the ichiba studs were long enough. doesnt mean that the whole ordeal wasnt plagued with problems. the studs were too big for oem lugs. had to use muteki's from my old nissan i had laying around. then after fitting the 18x7.5 +50 wheels with the 10mm spacer they're right passed the fender. damn wagon fenders!!! why couldnt these be 18x8 ARGGGGGG
Old 09-03-2009, 08:46 PM   #18
nhat
Member#: 140163
03 STi
hellaflunctional
roll and pull the front and rear fenders.
i'm guessing you bought 12x1.5 instead of 12x1.25...
Old 09-03-2009, 09:06 PM   #19
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
this is my auction
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
the rears are fine. its the front. i'll post pix when im finished with the whole ordeal. sigh
Old 09-03-2009, 09:09 PM   #20
nhat
Member#: 140163
03 STi
hellaflunctional
45mm? stock are 45mm...how many turns are you getting with the lugs with the 10mm spacer?
Old 09-03-2009, 09:19 PM   #21
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
alot actually, i got around 10 ish. these are def longer than stock. i'll take a side by side picture when i get back to the shop
Old 09-03-2009, 09:20 PM   #22
Daishi00
Member#: 78952
2005 WRX
CGM
nhat...walk away man...walk away.
Daishi00 is offline   Reply With Quote
Old 09-03-2009, 09:26 PM   #23
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
i dont get what u're trying to say. the wheels are already on. now im just bummed that they're too far out. what is he suppose to walk away from?
Old 09-03-2009, 09:54 PM   #24
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
wow, 18.7.5 with a 50 offset, with 10mm spacers put your rims outside the fender? wow!
Old 09-04-2009, 03:15 AM   #25
wildacex187
Member#: 141738
2002 wagon sti'ed
06 zx6r 636
i have a wagon. not flarred
07 stock rims clearing brembos what spacer? skeletorr Brakes, Steering & Suspension 1 02-27-2010 12:46 AM
not another is it ok to run a 10mm spacer thread 05ASPINREX Tire & Wheel 11 04-15-2009 01:35 PM
What size tires to run? ben14142001 Tire & Wheel 4 04-27-2005 08:42 PM
What size injectors to run with vf34???? wickedbluwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-08-2004 06:00 PM
what size wastegate to run on my turbo? STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-31-2002 02:46 AM
