Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 08-27-2009, 11:43 AM   #1
oxox55
Member#: 217423
02 wrx E85
psm
got it
oxox55 is offline   Reply With Quote
Old 08-27-2009, 11:52 AM   #2
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
knowing the specs on your car would help out.
medamullet is offline   Reply With Quote
Old 08-27-2009, 12:01 PM   #3
oxox55
Member#: 217423
02 wrx E85
psm
ya sorry- I guess that would help. 02 5spd, stock td04, helix uppipe, bbr bellmouth dp, injen ses 3 inch cat back, hallman mbc, cobb sf intake, cobb heat sheild, perrin after maf hose. 80k miles. I think thats it.
Old 08-27-2009, 12:32 PM   #4
oxox55
Member#: 217423
02 wrx E85
psm
Also I'm in Ogden I think elevation is aroud 4500 ft
Old 08-27-2009, 12:36 PM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
your AFRs seem fine. Thats about what mine are.
bhhamblin is offline   Reply With Quote
Old 08-27-2009, 02:01 PM   #6
JokerDMX
Member#: 175664
03 WRX
FP Green/Built&Cam'd 2.5L
Can you post up a log?
JokerDMX is offline   Reply With Quote
Old 08-27-2009, 02:52 PM   #7
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I don't see a Walbro 255 or 565 injectors on your list. Get some more fuel capacity in there if you didn't already.
Your stock turbo and intercooler are going to hold you back for three reasons: heat, heat, and heat. The turbo makes a lot of it. The intercooler doesn't remove enough of it, and at our altitude heat sticks around longer (less air to absorb the heat.)
I also think your timing is off a bit if you are tuning around detonation. The heat issue affects how much timing you can run. Fatten your fueling in the midrange. I hate the idea of using too rich of a fuel mix to cool off the combustion chambers, but you're sort of stuck doing that on pump gas.
You have an extensive airflow mod list and NO fueling mods. Start there and maybe add a set of colder plugs.
HamFist is offline   Reply With Quote
Old 08-27-2009, 03:34 PM   #8
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Why do you have a MBC on a tuned car?
Not-EWRX is offline   Reply With Quote
Old 08-27-2009, 03:50 PM   #9
oxox55
Member#: 217423
02 wrx E85
psm
I did forget I do have an sti fuel pump- I bought the car with the mods allready on. Im planning on upgrading to a larger turbo next year so Im going to do fuel system then. I'm just trying to get a nice safe, fun tune until then
Old 08-27-2009, 03:51 PM   #10
oxox55
Member#: 217423
02 wrx E85
psm
the 16 bit ecus dont seem to have a problem running a mbc's. It makes tuning boost a lot easier
Old 08-27-2009, 04:15 PM   #11
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Who's making your maps? The stock BCS isn't really made to handle high boost at this altitude.
Old 08-27-2009, 05:14 PM   #12
oxox55
Member#: 217423
02 wrx E85
psm
I am tuning myself. once in a while it will spike 17 psi in the dead of winter, but most of the time Im only hitting a max of 16.2 psi. I know higher elevations will make the turbo ineffective above a certain point. I have logged the maf G/S to see @ which psi raising boost becomes pointless. @ 17 psi my g/s max at 191- @ 18 psi im only hitting 184
Cobb AP question specific to 2007 sti cgeorge911 AccessPort 4 07-25-2008 10:40 PM
N00b Question Specific to 2.5 Exhaust St3fan Newbies & FAQs 6 01-16-2007 09:43 PM
To tune.. or not to tune. EJ25 hybrid question FederalAuditor Engine Management & Tuning 5 02-09-2006 12:55 PM
Shiv from Vishnu tuning your car on our dyno? [email protected] North West Impreza Club Forum -- NWIC 71 01-14-2004 03:46 PM
Cobb Tuning NA Specific Cams/heads (Attn: Trey) stimpy Normally Aspirated Powertrain 11 11-17-2000 04:58 PM
