Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Closed Thread
Old 08-27-2009, 05:49 PM   #1
wantsti
Member#: 134764
04 sti
java black pearl
Default What do you need to do to use E85 fuel?
What do you change on your car if you want to run E85 fuel?
I know you will have to get a tune but what else?
wantsti is offline
Old 08-27-2009, 06:14 PM   #2
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
injectors and tune
06HAWKMAN is offline
Old 08-27-2009, 06:35 PM   #3
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Injectors Fuel pump or two depending on turbo.
Kastley85891 is offline
Old 08-27-2009, 06:49 PM   #4
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
They have an article about it in the new Modified mag (I think) about the CST Subaru that runs on E85. It's the tuner shoot out with three cars on the cover. They had to run huge injectors and I think 8 of them with duel fuel pumps but it is a race car.
aclver1 is offline
Old 08-27-2009, 06:55 PM   #5
wantsti
Member#: 134764
04 sti
java black pearl
I'm just stage 2 so stock turbo. What size injectors would I need?
wantsti is offline
Old 08-27-2009, 06:57 PM   #6
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
E85 is for weenies.
I run on JP-5 and gypsy tears.
Kentrik is offline
Old 08-27-2009, 07:01 PM   #7
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
850's will support up to 400 whp, so stock turbo no probs, anything more its 1000's or biggers and def twin pumps
Old 08-27-2009, 07:04 PM   #8
wantsti
Member#: 134764
04 sti
java black pearl
So will my stock fuel pump be fine too?
wantsti is offline
Old 08-27-2009, 07:24 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
You can't push that much fuel with the stock fuel pump. A walbro is only like 90. If you are thinking of 450 for injectors and 400 for a cobb tune. 90 isn't much more.
medamullet is offline
Old 08-27-2009, 07:34 PM   #10
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
255 for sure
Old 08-27-2009, 08:35 PM   #11
godfather2112
Papi Chulo
Member#: 53794
If you are asking this question and not searching, I probably wouldn't recommend running E85
godfather2112 is offline
Old 08-27-2009, 10:38 PM   #12
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Why do you want to use E85? There are only 3 E85 gas stations in Utah. You use 30% more fuel also. Just get tuned on race gas and use it at the track.
bhhamblin is offline
Old 08-28-2009, 12:03 AM   #13
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It's a perk to be able to make different maps for some of you. Full time, I wouldn't do it in Utah on a daily driver. For some of you doing open source tuning or virus maps, it's a good exercise to work with a good fuel. Just 30% ethanol staves off detonation and doesn't require much of a bump in fueling.
The stock parts do well, but it needs some love in the fueling department. A Walbro 255 helps, but you need bigger injectors for full E85. Splash blends are popular, too. Don't be shy of just using 30% or 50% ethanol, either. Colder plugs rock out, too. I swear by BKR7E11 NGK-Rs with a tight gap.
I always end up adding a few gallons of 91 to my E85 just to put some heat in the block. After years of using e85 I can say that it almost does it's cooling job too well. 30% and 50% blends will work just fine for most of you on an experimental basis without extensive fuel system mods.
HamFist is offline
Old 08-28-2009, 08:49 AM   #14
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
so hamfist, you aer saying to USE a 1 step colder plug? I am not down with the "lingo"
Old 08-28-2009, 12:20 PM   #15
wantsti
Member#: 134764
04 sti
java black pearl
Because it would be an easy way to get some more power with out running $8.00 a gallon gas, and there is a station right by my house where I can get it.
wantsti is offline
Old 08-28-2009, 12:22 PM   #16
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Are you going to bring gallons of gas with you to the track? You'll use it fast.
Old 08-28-2009, 12:25 PM   #17
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya, 1 track day it about 1 tank of gas. You won't make it there and back on a tank of gas. I would suggest bringing 15 gal at least to the track. 5 gal to fill up once you get there, 5 gal just in case you run out there ( you will burn 1/4 tank getting to milller from Clearfield) 5gal to get you home, hopefully and 5 gal to get you home, hopefully.
Old 08-28-2009, 12:29 PM   #18
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
I wish I could only use a full tank on a full track day Im 1/2 tank per session.
Old 08-28-2009, 12:31 PM   #19
Touge86
Member#: 166498
2013 M3
Mint Green
isnt there a lot more you could do to your car before you worry about using e85?
Touge86 is offline
Old 08-28-2009, 12:38 PM   #20
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Sure there's more he could *do*, but there's not much to do for him to simply use more ethanol. It's more about user training than getting new parts when it comes to ethanol use.
HamFist is offline
Old 08-28-2009, 12:40 PM   #21
Touge86
Member#: 166498
2013 M3
Mint Green
im not sayin so much the ethanol at all but that if he is sitting at stage 2 there are other parts he could get rather than simply worrying about cheap power you know?
Touge86 is offline
Old 08-28-2009, 12:41 PM   #22
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
That's true, and with e85 it will be more fuel being burned.
I ran out on the track once a few years ago. I usually top off when I get off 84 before the track and fill up on the way out of town.
Old 08-28-2009, 12:56 PM   #23
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
If im using a 1/2 per session on normal gasoline. Id probably be about 3/4 a tank with ethanol lol.
I sure love how the stuff smells.
Old 08-28-2009, 01:31 PM   #24
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
It's weird on paper, but makes sense underfoot. With making more torque, I'm in the throttle less which preserves my mileage. That only works on the street, though. A track session will indeed see worse mileage. However, my driving style changes with more torque. I shift sooner coming out of corners and don't have to rap the car out to redline to see times drop.
HamFist is offline
Old 09-02-2009, 07:32 PM   #25
Sports Wagon
Member#: 43081
Here is what Cobb in Texas did on a stage 2 STi with 850's on E85.
Sports Wagon is offline
Closed Thread
What do you need to do to have constant voltage to fuel pump? csugden Electrical & Lighting 2 10-31-2009 10:39 AM
Do you need a Passport to go to Puerto Rico? Dirty25RS Off-Topic 46 10-16-2008 11:24 AM
Do you need a passport to go to Canada ? ZMANNH25rs Off-Topic 34 05-13-2004 05:05 PM
What do you need to do to prevent hair loss? WRXVII Off-Topic 34 08-07-2002 07:34 PM
Do you need a passport to get into canada? v6scoobie General Forum Archive 36 11-16-2000 08:29 AM
