Old 08-27-2009, 06:32 PM   #1
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
Default Question regarding newer tires on rear with less tread on front???
So I have put newer tires on rear as the rears wore out alot...but the car feels a little different as it feels like the rear end has an oversteer feel compared to how I had it....this changed once i put on the new tires on rear...and plus they are different brand/tread to the fronts....any thoughts?
thanks,
Doug
Nettalp is online now   Reply With Quote
Old 08-27-2009, 08:05 PM   #2
Web Foot STi
Member#: 39086
2004 STi
Start saving for a new center differential. Tyres should match on all 4 corners.
Check and see if you have zero toe in the rear.
Web Foot STi is offline   Reply With Quote
Old 08-27-2009, 08:54 PM   #3
krzyss
Member#: 8365
2013 Ford Focus SE
Wrong question for AWD car.
If you had FWD or RWD then suggested position is rear (to avoid oversteer) but with AWD you are taxing your center diff (unless circumference difference is within 1/4 of an inch).
Krzys
krzyss is offline   Reply With Quote
Old 08-28-2009, 09:32 AM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
what you are feeling is the additional tread squirm the new tires have because they have more tread depth. What is the tread depth on the front tires?
Old 08-28-2009, 09:57 AM   #5
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
I would rather quickly save and get the matching front tires. More specifics would also be helpful like what brand/size are on front/back, and like [email protected] said, what's the tread depth of the front's vs. the rear's.
And rotate your tires properly in the future, especially when putting down more power.
BeatLA is offline   Reply With Quote
Noobish question regarding spare tire PS_REX Newbies & FAQs 12 10-16-2008 03:29 AM
on road course, any success with HPS on rears and Panther Plus on fronts? homiusang Brakes, Steering & Suspension 1 04-11-2006 12:44 AM
Question regarding spare tires colorstay Tire & Wheel 5 12-01-2004 03:08 PM
Anything wrong with installing Turboxs Stage 2 kit on WRX with Less Than 1000 miles? 2.2gotboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-25-2002 09:57 PM
Anything wrong with installing Turboxs Stage 2 Kit on WRX with Less Than 1000 miles? 2.2gotboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-25-2002 08:45 PM
