Alaskan Impreza Club
Go Back   NASIOC > NASIOC Chapters > Alaskan Impreza Club Forum -- AKIC
Old 08-23-2009, 08:55 PM   #1
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Default turbo balancing...
someone on here mentioned something about a shop in anchorage that will do impeller balancing? anyone know the shop? #?
greenspeed is offline   Reply With Quote
Old 08-24-2009, 12:06 AM   #2
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
well i didn't need it. I read up some on the TD05H and it is component balanced there for impeller balancing isn't needed, but i marked my locations and successfully rebuilt my evo3 16g. Just have to get it on the car and make sure all is well. The shaft spins really smooth, no shaft play at all, and it only took me 3 hours from start to finish and that includes a drive to lowes to search for snap ring pliers
Old 08-24-2009, 04:03 AM   #3
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
Congrats
Kiwi Fella is offline   Reply With Quote
Old 08-24-2009, 02:07 PM   #4
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
one of the oil control spacers was different so the impeller was locking up after i got it back together and had to tear it down and use the old one and noticed just how different they were...now she spins fine.
I think i figured out why it was buring oil too. it had a steal braided line fitting on it, massive amounts of oil going into the turbo would cause seals to seep oil out. Basically like a grease gun and filling a hub with the gun, if you keep filling it it will push the seal out and cause it to leak
Old 08-24-2009, 03:31 PM   #5
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
If thats a ball bearing turbo it requires a restrictor in the oil feed line. Also make sure the return line isn't caked and blocked with crap.
TurboSetch is offline   Reply With Quote
Old 08-24-2009, 05:11 PM   #6
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
So you're putting a 16G on an otherwise stock engine and non-turbo transmission?
Carter is offline   Reply With Quote
Old 08-24-2009, 05:31 PM   #7
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
thrust bearing turbo.
And yes evo 3 16g on a stock NA trans...should be fun stuff..
Seth you ready to tune this week?
Old 08-24-2009, 05:43 PM   #8
Carter
Member#: 156708
2004 Mini Cooper S
You need 6 speed dood. And brembos. Balla.
EDIT: Naw forgo the six speed, and do a straight cut dog box.
Old 08-24-2009, 05:55 PM   #9
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
i do know my trans is my weakest link, but someone told me when i did the swap that my trans wouldn't last 10 miles, I blew that one up cause of straight syncromesh and this one i refuse to retire til i get money, or blow it up. however being able to lauch just once would be cool
Old 08-24-2009, 06:14 PM   #10
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Tune? So you want to blow the trans up ehh? I can definitly help you with that..I have a tune just for your setup.
Old 08-24-2009, 06:18 PM   #11
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
i can't afford to upgrade my injectors so we need to set it at like 12lbs
since 2 studs are broke of my td04 and i need to replace the manifold ad up pipe figured I'd just put the Td05h on since i have it
Old 08-24-2009, 06:21 PM   #12
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
We will see how your fuel does on the wideband.
Old 08-24-2009, 06:23 PM   #13
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
mines located on the dp we could move it...we'll work on this this week...
Old 08-24-2009, 06:26 PM   #14
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Doesn't matter. Just need relative readings Greenslow.
Old 08-24-2009, 06:27 PM   #15
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
WRC spec sequential flappy-paddle gearbox! When the next thing in the drivetrain breaks,upgrade that and so on down the line....
Old 08-24-2009, 06:28 PM   #16
Kiwi Fella
Modest Mouse
Member#: 27323
2000 RSTi
i know a 05 Legacy GT trannie that is for sale...
Old 08-24-2009, 06:30 PM   #17
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
for free cause I aint got no MONEY!
sonny lol, those will go in when i get my carbon brakes
btw that little shaft play that's still there sonny is cause i couldn't use that new spacer
Old 08-24-2009, 06:37 PM   #18
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Some shaft play on journal bearing turbos is normal when there is no oil pressure. Stick you hand in there while its running and check it. lol
Old 08-24-2009, 06:39 PM   #19
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Old 08-28-2009, 04:18 AM   #20
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
I've done that to my turbo in my truck. turbonetics. has slight shaft play, then NONE at ALL even being a little forceful.
AKSubieDubie is offline   Reply With Quote
Old 08-28-2009, 05:45 PM   #21
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
I think Greeny is a little to focused on playing with his shaft. Just inspect the side walls for chaffing every once in a while, if you find this to be the case then you definitly know that is too much shaft play.
Old 08-28-2009, 06:23 PM   #22
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
seth, you dirty boy! I'll bring the turbo we'll put it on on saturday
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
Turbo balancing shop? Rich Town Service & Maintenance 3 10-08-2009 01:22 AM
where to balance turbo? WReXd Southern California Impreza Club Forum -- SCIC 10 12-29-2007 12:13 PM
Anyone know any turbo balancers near Chicago??? XWRATED Mid West Subaru Owners Club Forum -- MWSOC 5 11-14-2006 11:17 PM
Pistons,Rods,Balance Crank, Crank Bearings for turbo EJ25 3BadHabbits Normally Aspirated with bolt-on Forced Induction Powertrain 14 01-10-2004 04:04 PM
