Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 08-28-2009, 12:17 PM   #1
Blackout33
Member#: 179361
1999 corvette
Default Stage 2 sti?
Hey guys I've done some searching and read the rules but I would still like a little clarification. Stage 2 STI with a Cobb Accessport OTS map would put me in street modified correct? My reasoning behind this is the the factory boost map is modified? Am I correct in the classification of my car?
Blackout33 is offline   Reply With Quote
Old 08-28-2009, 12:34 PM   #2
corzy666
Member#: 177840
2000 swapped RS
White 330whp
I was thinking of a wrx =/
corzy666 is offline   Reply With Quote
Old 08-28-2009, 12:49 PM   #3
cpasti
Member#: 50582
Actually with boost adjusted it should be BSP, and would be STU with an STU map. STIs don't qualify for STX. If you have any other mods, you'd have to check what those may do as well. For instance a tire over 245 would disqualify you from STU.
cpasti is offline   Reply With Quote
Old 08-28-2009, 01:35 PM   #4
Blackout33
Member#: 179361
1999 corvette
ok it looks like ill be running bsp next year and should build my car up to that. I don't think i can run STU because the accessport blocks the emmissions code.
Old 08-28-2009, 01:54 PM   #5
Illini_STi
Member#: 70634
Depends on the map. I have an accessport with STU map that I run at events. In that map all the emissions codes are active. I also have a BSP map that has boost and deactivated codes. I run the BSP map on the street and then reflash to the STU map for events.
Do you have a cat? If you don't have a cat then you will not ever be STU legal.
Illini_STi is offline   Reply With Quote
Old 08-28-2009, 05:00 PM   #6
corzy666
Member#: 177840
2000 swapped RS
White 330whp
Doh... I was thinking of a wrx when I posted.... sorry OP.
Old 08-28-2009, 07:41 PM   #7
Blackout33
Member#: 179361
1999 corvette
Its a perrin catted down pipe.
Old 08-30-2009, 08:11 PM   #8
CarTuned
Member#: 42203
2011 WRX
I had the same question...
Ans) Boost modification, whether electronical or manual, will bump you to ESP. Not sure about BSP. I'm gonna check that out. Also, I was told COBB has an STU freindly map...might be worth a look.
CarTuned is offline   Reply With Quote
Old 08-30-2009, 08:31 PM   #9
waktasz
Member#: 86356
2015 s1000r
wheelie monster
STI and 08+ WRX are BSP. WRX is ESP.
waktasz is offline   Reply With Quote
Old 08-30-2009, 09:08 PM   #10
Blackout33
Member#: 179361
1999 corvette
thank you for the clarification
Old 08-30-2009, 10:36 PM   #11
Splash
Member#: 55936
04 WRX STi
post would have been redundant.
Splash is offline   Reply With Quote
2006 stage 2 STi, STi Mikey Tuned, 303whp/339wtq Downpipe77san Proven Power Bragging 29 03-04-2010 04:08 PM
FS: 1998 wrb 2.5RS-T (axis stage 2 STi block) $14,000 Keith Tri-State Area Private Classifieds 10 03-28-2008 03:33 AM
FS: Cobb Stage 2 - STI 05-06 - v.2 AP with updated firmware daltrum83 Engine/Power/Exhaust 12 03-17-2007 07:36 PM
Vishnu Stage 2 STi rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 122 11-03-2004 03:23 PM
Vishnu Stage 2 STI DYNOED MGSTI Proven Power Bragging 77 09-12-2004 08:18 PM
