Old 08-28-2009, 06:18 PM   #1
TRBO_BXR
Member#: 75835
1992 dontask
white
Default 07 forester Supercharging.
what would be the easiest way for me to do this? i know best option is M62 eaton. whats the best way to tune and parts needed for fueling. i want 6+lb of boost and i plan on IC. 10psi is my goal. total mods will be light suspension, wheels, upgrade brakes, Header/catback.
TRBO_BXR is offline   Reply With Quote
Old 09-02-2009, 12:25 PM   #2
anothernord
Member#: 193703
Here a couple links to get you started:
http://forums.nasioc.com/forums/showthread.php?t=605625
http://www.ludicrous-speed.com/wiki/...C_Build_Part_1
The Eaton M62 from a Mercedes C230 Kompressor is probably your best option for a supercharger.
anothernord is offline   Reply With Quote
Old 09-05-2009, 02:04 PM   #3
TRBO_BXR
Member#: 75835
1992 dontask
white
thanks!
Old 09-24-2009, 02:55 AM   #4
Spudchucker
Member#: 201147
2006 Impreza 2.5ISC
M90 SUPERCHARGED
I would check with RedDevil to see what psi m62's are (consistently) good for- 10 may be a bit extreme for daily use. Isn't Skidd at 12,000RPMs to make 5.5 psi?
With whatever you do though, good luck brah
Spudchucker is offline   Reply With Quote
Old 09-25-2009, 02:26 PM   #5
anothernord
Member#: 193703
Skidd is just barley making 5 psi with a 2.75" pulley and a 2006 WRX TMIC. That's a 1.909:1 pulley ratio, which comes out to exactly 11931 RPM and redline.
I'm actually going with a 2.6" pulley for a 2.01:1 ratio, which lands at 12620 RPM at the very tip top of the rev range. Hopefully this will result between 5 and 6 psi.
So for 10 psi, you'll have to spin the SC at 14K + RPMs.
Old 09-25-2009, 03:05 PM   #6
Skidd
Member#: 1853
GC6 Supercharged
STM
^ some/most models of M62 are capable of 14k. And 15 for short bursts.
In fact, I believe the M62 is typically rated to maintain 14k. Unlike the M90 that is usually only designed to spin to 12k. Don't know exactly what 14k rpm on the M62 SC would make for boost though. reddevil might have an idea, even though he ran on a 2.2L.
Skidd is offline   Reply With Quote
FS: Texas Cobb Accessport 08+ WRX/STI, 07+ LGT, 07+ Forester XT rjacobs Engine/Power/Exhaust 2 11-15-2008 09:23 AM
FS: ATX Cobb AccessPort 08+WRX/STI, 07+Legacy GT, 07+ Forester XT rjacobs TXIC Private Classifieds 3 11-15-2008 09:22 AM
FS: 04-07 impreza rs or 03-07 forester starter haunt NWIC Private Classifieds 1 09-25-2008 04:42 PM
07 Forester we just got in crazyhorse South East Region Forum 35 07-07-2006 09:16 PM
Killer deal on ebay. Subaru WRX Impreza Forester Supercharger SuperRuWRX Forester Forum 22 10-31-2004 05:52 PM
