Old 08-28-2009, 11:40 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Oil separator cover gasket replaced on 02 WRX (pictures)
Thought I would share some pictures of how gasket looks like after 90k miles.
Passenger side:
Driver side:
Old 08-28-2009, 11:53 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
its b-yootyfull
Old 08-29-2009, 01:26 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
The second picture looks like a tray full of poo butter.
Haelan is offline   Reply With Quote
Old 08-29-2009, 09:06 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by txl146 View Post
I replaced mine a little while back at around 40k-ish miles - they had been weeping oil for a while, but I didn't have anything like that in there.... what oil have you been running?
Old 08-29-2009, 09:35 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
~20k miles on conventional oil / ~50k miles on M1 and ~20k miles on German castrol.
Old 10-22-2009, 01:45 PM   #6
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
txl,
Thanks for posting....I'm leaking same spot on the passenger side.
Was it a pretty easy change?? pull the bolts and swap it out?? anything a pita in the process??
dm
dwmoss_68 is offline   Reply With Quote
Old 10-22-2009, 02:56 PM   #7
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
I'm doing this on Saturday. Got the gaskets from the dealership today. I'm at a bit of a loss as well . . . can't find the one on the driver's side, but the passenger one is definitely leaking.
Could anyone provide some instructions or tips to getting at it? Is it, as the above person said, just pulling the bolts, cleaning, and putting the new one in?
Pics are welcome, and thanks!!
magicstop is offline   Reply With Quote
Old 10-22-2009, 02:57 PM   #8
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Also, what torque should those be tightened to? I thought I remembered someone saying 4.1 ft-lbs, but that seems excessively low. My torque wrench won't even read that low, I don't think.
Old 10-22-2009, 03:06 PM   #9
audsyn
Member#: 26112
2002 WRX Wagon
WTF. That's gross. I just did mine (120k+ miles) and they were clean, just oily, nothing like that.
Have you opened the valve covers? Presumably you have that junk in there, too?
audsyn is offline   Reply With Quote
Old 10-22-2009, 03:08 PM   #10
audsyn
Member#: 26112
2002 WRX Wagon
The manual says 4.7 ft-lb. Yes that's super low. Use a small 1/4" socket wrench and don't crank on it.
Old 10-22-2009, 06:19 PM   #11
audsyn
Member#: 26112
2002 WRX Wagon
It was straightforward, except I found out why they call them green brackets of DEATH. You have to have the bracket off the bolt the breather down...but you need the breather off to get the bracket on. Whoever designed those brackets deserves a kick in the nads.
I'm not sure how the OP did it, but what I did was unbolt (but don't remove!) the GBOD, and lift/twist/tug it out of the way enough to get the smallest 1/4" wrench and socket I could find on that bolt. Even then it was on crooked, but it grabbed the bolt enough to tighten. Maybe a small 1/4" u-joint would help...?
Old 10-22-2009, 06:38 PM   #12
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
I say, everyone who feels that way should chip in, and we should hire someone to do just that. We'll find the person/people who designed the GBOD, and ship someone to Japan to give them a nice, firm, steel booted kick in the nuts.
My torque wrench doesn't even go down to 4.7 lb-ft. Gonna have to get a little itty bitty job that does inch lbs, a couple ft-lbs, and newton-meters.
Chi_San is offline   Reply With Quote
Old 10-22-2009, 06:42 PM   #13
Haelan
Member#: 151045
2013 Subaru STI
CBP
You don't need to screw with the GBOD for the breather gaskets. If you did, then you don't know what you're doing or you were using the completely wrong tools.
Driver side...unbolt the windshield washer reservoir and swing it out of the way.
Passenger side....unbolt and remove the airbox.
Old 10-22-2009, 06:50 PM   #14
audsyn
Member#: 26112
2002 WRX Wagon
^^ I couldn't get a wrench, socket, or anything else on that one bolt without loosening the GBOD. The one on the right in this picture. How did you do it?
Old 10-22-2009, 06:57 PM   #15
Haelan
Member#: 151045
2013 Subaru STI
CBP
Undo the power steering hardline bracket. It's the line at top the top of the picture...the rubber grommet bracket you see connects to the turbo coolant reservoir.
I fit a 1/4 in ratchet in there with a 10 mm low-profile socket. Had zero problems.
Old 10-22-2009, 07:02 PM   #16
audsyn
Member#: 26112
2002 WRX Wagon
^^ Well, with my tools the socket fits in fine but my ratchet wrench is too big...I guess mine is bigger than yours
Old 10-22-2009, 07:37 PM   #17
CT26SupraTurbo
Member#: 213393
2003 WRX
Tomei Powered
I did mine on 85k miles. Again for passenger side. I m assuming heat from turbo is making gasket to go out quickly than other side. mine showed very clean.(previous owner claimed m1 for 60k miles i assume that is true lol) job can be done without removing anything from the top. Just torquing down to proper spec needs some hands on feeling somewhat. I was manage to torque one of them down with t-wrench. others by hand. I also used new bolts
CT26SupraTurbo is offline   Reply With Quote
Old 10-22-2009, 09:48 PM   #18
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
The answer to the access issues is a 10mm flex socket - removing/reinstalling was a piece of cake.
For the torque thing, it seems low, but keep in mind the part is plastic (with metal sleeves where the bolts go) and it's not really pressurized.
Old 10-22-2009, 11:38 PM   #19
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
This is the same gasket which caused my "lean bank 1" code. I replaced the injectors at night, using a flashlight and the black gasket stuck to the black plastic cover, then dropped, without a sound...into the darkness...
2 months later, after I tried ... everything... I pulled the passenger cover, sure enough the gasket was not there anymore..
I give it as a posibillity that if you have a broken gasket or loosened screws, it will suck air and possibly throw a code.
I was very worried about the screws that fasten the cover and about not overtightening them, until i saw the steel sleeves. Although one should still be carefull, a small , but firm amount of torque on those should be ok.
Old 10-22-2009, 11:49 PM   #20
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Exactly what/where is the green bracket of death (GBOD)? Thanks for the tips, folks. Sounds like it shouldn't be too hard.
Old 10-23-2009, 01:04 AM   #21
audsyn
Member#: 26112
2002 WRX Wagon
Fuel pipe/injector protector bracket. You'll see it.
Old 10-23-2009, 01:37 PM   #22
GHK
Member#: 103886
2005 WRX
That is the only place my car leaks oil, the passenger side. do you guys change out the PCV valve also??
GHK is offline   Reply With Quote
Old 10-23-2009, 02:18 PM   #23
audsyn
Member#: 26112
2002 WRX Wagon
^^ The PCV valve is not near the valve cover.
Old 10-23-2009, 02:53 PM   #24
Chi_San
Member#: 53558
2005 Baja Sport
Wrong end of the PCV system. The PCV valve is where the blowby enters the intake and gets sucked into the engine, this is where fresh air gets pulled into the heads, and then pulled through to the PCV valve.
Old 10-23-2009, 07:01 PM   #25
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
ha seems everybody having this issue of the passenger side leaking. mine has leaked for like the last month or so. replacing it next week when the dealer gets it in.
karlknaupp is offline   Reply With Quote
Just replaced intake manifold gaskets on 02 WRX txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-09-2015 09:47 PM
02 WRX valve cover gasket replacement... 1fastser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-16-2013 06:30 PM
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
Oil separator cover gasket torque? PRIDExPL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2009 10:05 PM
