Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 10-24-2009, 12:37 AM   #26
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Is the part number the same for both sides?
morrocco88 is offline   Reply With Quote
Old 10-24-2009, 12:48 AM   #27
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Yep, it is. Gaskets are the same.
magicstop is offline   Reply With Quote
Old 10-25-2009, 01:44 AM   #28
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
zaaahhhhh! So, I changed out my passenger side gasket today (with a lot of ****ing around to get to the back bolt), but I COULD NOT get to the back bolt on the driver's side. Bracket was definitely in the way. It offers NO clearance. I spent an embarassing amount of time trying to remove it. So now my car sits dead, as I destroyed the gasket trying to remove it (thinking that would buy me some clearance and spin on the bolt).
Tomorrow I'm borrowing a car and am going to buy a flex socket, a tiny ratchet, and a long-ass extension. Maybe that'll get the job done. My sockets didn't even really want to fit on due to lack of clearance between bolt and plastic housing.
Old 10-25-2009, 02:19 AM   #29
Chi_San
Member#: 53558
2002 WRX Wagon
Just love how they built these things to be easily serviceable.
Chi_San is offline   Reply With Quote
Old 10-25-2009, 02:25 AM   #30
DeathPool
Member#: 186966
2004 WRX Sedan Stg.2
I just did mine today. I also had the problem of getting the one bolt that is closest to the front of the car off of each of the plastic housings because of it being right under the GBOD and not enough clearance on the plastic housing. A minute or two of brainstorming and I created...the oil separator cover bolt removal tool!
Unfortunately I have no pictures for you but essentially what I did was find a small 1/4" drive, 10mm socket that had no clearance issues with the plastic housing. I then took an allen key (just a single key, with a 90 degree bend), stuck the "small" end of the key into the socket, and then turned the socket with the "long" end of the key.
Your obviously going to need a "thin-walled" and "short" socket that will fit over the bolt without bumping into the plastic housing and wont be tall enough to get into the way of the GBOD. Then you need an allen key that is large enough to fit snug into the socket (as if it were a socket wrench), yet wont be too big.
I had both and it saved me a headache and a trip to the hardware store.
Oh, by the way, I replaced mine because one of them was weeping oil badly. I HIGHLY recommend changing these when you get a chance, there was SO much gunk underneath mine (refer to the first page for an example image.) I have a much smoother idle as well.
DeathPool is offline   Reply With Quote
Old 10-25-2009, 11:16 AM   #31
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Yeah, mine are a bit gunky. Not as bad as the OP, but there is some gunk. I'm at 75k miles. i just wiped mine out with a rag to clear the gunk. I thought about soaking the gasket in Rotella before putting it in, but I don't think it matters. It'll get plenty soaked when I crank it
Interesting idea, DeathPool! I dont have any sockets that fit that description, so I'm still going to the hardware store. I'm really hoping a flex socket will work well enough. I haven't been able to find any specifically thin-walled sockets or short-profile sockets like mentioned on here.
I'm hoping this will work:
http://www.craftsman.com/shc/s/Produ...atalogId=12602
That, plus a 10-inch extension or else a thin profile ratchet.
Old 10-25-2009, 02:35 PM   #32
Farnk
Member#: 91093
2002 Wrx
Originally Posted by karlknaupp View Post
ha seems everybody having this issue of the passenger side leaking. mine has leaked for like the last month or so. replacing it next week when the dealer gets it in.
This helped me nail it down. Pass side is leaking on mine too.
Farnk is offline   Reply With Quote
Old 10-25-2009, 06:45 PM   #33
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
I got mine swapped today on the drivers side.
The trick for getting at that inaccessible bolt:
10" wobble extension + 10mm flex socket
It worked like a charm!
Old 12-03-2009, 06:15 PM   #34
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
bah! thank goodness i'm not the only one with this issue. been leaking from the pass side for a while now. thanks for the tips everyone!
Bishop is offline   Reply With Quote
Old 12-15-2009, 09:12 AM   #35
HungryHippo
Member#: 187891
1999 STI version 5
Is that the same part number for an EJ207? Ive got a 1999 JDM STi thats leaking oil from there too
HungryHippo is offline   Reply With Quote
Old 12-15-2009, 11:45 AM   #36
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
I been hunting down an oil leak for over a month, this passenger side oil seperator seems to be the most likely culprit. How much did the dealer rape you guys for a pair?
happs subi is offline   Reply With Quote
Old 12-15-2009, 12:03 PM   #37
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
hmm interesting. Never replaced it and I have 178k.
Old 12-15-2009, 02:11 PM   #38
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
I have 132K miles and haven't replaced mine either... though I do use fujibond to seal them up, as they were weeping.
paintbing is offline   Reply With Quote
Old 12-15-2009, 06:47 PM   #39
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
yea that works too
Old 12-15-2009, 08:17 PM   #40
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
They weren't much. Maybe 16 or 20 for both, I think.
Old 12-19-2009, 12:47 AM   #41
HungryHippo
Member#: 187891
1999 STI version 5
I just got a pair from the dealer. Cost 340 yen each
Old 12-19-2009, 08:58 AM   #42
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
As I've said, any leak from these is also possibly a sign of a small vacuum/pressure leak. It's a good idea to replace them.
My driver's side was missing, so that was a huge difference, but I decided to also replace the passenger side.
At the time I was watching the short term fuel trim like a hawk (was fighting the bank 1 lean code), so I definitely saw before/after changes to the trim. Before the passenger side replacement, the trim was hovering in the appropriate range, but only on the positive side. After replacement, I started to see negative numbers too, It became centered on zero..
Old 12-20-2009, 08:41 AM   #43
HungryHippo
Member#: 187891
1999 STI version 5
Just changed mine. My drivers side one (right hand drive) had been leaking and had a bit of gunk in it. Nowhere near as bad as the OP though. Passenger side wasnt leaking but i replaced it too and it was clean except for a tiny bit of oil.
Old 10-07-2011, 12:57 PM   #44
ktmhk53
Member#: 17497
Greetings,
Sorry for bringing this post back from the dead, but I just found my passenger side Oil Separator gasket leaking, as well as oil seepage around several of the passenger side valve cover bolts. As all of the bolts were tight, is this a sign of the engine being over-pressurized, or do these items just leak when they are at 226,000 miles?
Otherwise than that, the engine is oil-tight and runs just like new.
ktmhk53
ktmhk53 is offline   Reply With Quote
Old 10-07-2011, 01:00 PM   #45
Haelan
Member#: 151045
2013 Subaru STI
CBP
Originally Posted by ktmhk53 View Post
Greetings,
ktmhk53
The gaskets are rubber and go bad over time. I'm surprised yours lasted until 226k. My passenger side gasket started leaking around 75k. Replaced it and no more problems.
Haelan is offline   Reply With Quote
Old 10-07-2011, 01:05 PM   #46
ktmhk53
Member#: 17497
Sounds good, but why do I have a leak around the valve cover bolts as well?
Is there somehow too much pressure being built up in the area under the cover?
ktmhk53
Old 10-07-2011, 01:11 PM   #47
2.5ReallySexy
Member#: 167943
There is seals on the valve cover bolts that can go bad.
2.5ReallySexy is offline   Reply With Quote
Old 10-07-2011, 01:35 PM   #48
ktmhk53
Member#: 17497
OK, good to know. I'm still wondering about a pressure problem, but not sure what could possibly malfunction to cause this. Normally I would look to the PCV valve, but I read in these forums that a bad one shouldn't cause this problem.
ktmhk53
Old 10-07-2011, 04:21 PM   #49
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
This makes me want to change mine on my 03
Chris
GrimmSpeed is offline   Reply With Quote
Old 10-07-2011, 06:08 PM   #50
Bishop
Member#: 59993
Ass, grass or cash
Chris
I know right? I'm a lazy mofo to do it. I've had the gasket sitting in my tool chest since forever.
Just replaced intake manifold gaskets on 02 WRX txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-17-2014 02:22 PM
02 WRX valve cover gasket replacement... 1fastser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-16-2013 06:30 PM
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
Oil separator cover gasket torque? PRIDExPL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2009 10:05 PM
