Old 01-22-2012, 06:15 PM   #51
CrazyButHappy
Member#: 58545
2003 WRX
Originally Posted by magicstop View Post
I'm hoping this will work:
http://www.craftsman.com/shc/s/Produ...atalogId=12602
That, plus a 10-inch extension or else a thin profile ratchet.
Dude, this tool made it so much easier! Thanks, I swapped out my driver's side gasket in no time. I did slice open a knuckle real good, so watch out: there are sharp edges down in there.
CrazyButHappy is offline   Reply With Quote
Old 02-04-2012, 12:47 AM   #52
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
That's a handy tool there... I am going to look for one on Amazon.
Old 02-04-2012, 10:14 AM   #53
passion4JC
Member#: 46389
2003 WRX Stg 2
Local Sears has it...
passion4JC is offline   Reply With Quote
Old 07-18-2012, 11:34 PM   #54
Jaybfox4
Member#: 316662
2002 Subaru WRX
Awesome Thread, i noticed that my passenger side valve cover gasket was leaking for a while now, and also noticed a little bit on the drivers side. Called the dealership and some auto places locally and DANG, they wanted over 400 dollars to do it. Definitely gonna do this with one of my mechanical buddies. Thanks for all info and tips!!
Jaybfox4 is offline   Reply With Quote
Old 12-14-2012, 09:44 PM   #55
Tavery92
Member#: 312331
Sedona Red
Hey guys, sorry to up a dead thread, but I saw my passenger side one weeping pretty good when changing my plugs, could this also be the cause of my burning oil smell?
I saw part of the gasket protruding from the outside of where the plate bolts onto the manifold.
Cleaned it up pretty good, was alright for a few days tonight it got worse, as far as smell goes.
I won't get the part until Monday, and won't get a chance to get it in until probably Tuesday or Wednesday. I have to drive 80miles each way tomorrow, and work on Monday and Tuesday. Is the car safe to drive until that point?
EDIT: I checked around the rocker cover(?) and didn't see any sort of oil leaking from there.
Tavery92 is offline   Reply With Quote
Old 12-21-2012, 05:45 PM   #56
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
$400 to replace gaskets?
Stealership.
Old 01-19-2013, 08:09 PM   #57
corbett
Member#: 87203
04 wrx
Replaced both of mine today. +1 on the 10mm flex socket. I got the 1/4" drive one at sears and it made it super easy. Not sure where one would get the low profile 1/4" socket that was mentioned before aside from snapon or grinding down a standard socket. Cleaning everything up was the longest part of the job.
corbett is online now   Reply With Quote
Old 03-15-2014, 08:11 PM   #58
Udigod
Member#: 384258
05 Impreza WRX
Obsidian Black
did any of you use new screws for this? I'm about to do this for the first time next week. obtaining this gasket for a 05 wry is almost impossible
Udigod is offline   Reply With Quote
Just replaced intake manifold gaskets on 02 WRX txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-09-2015 09:47 PM
02 WRX valve cover gasket replacement... 1fastser Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-16-2013 06:30 PM
Strange "overheating" problem on 02 WRX TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 07-07-2010 12:41 PM
Oil separator cover gasket torque? PRIDExPL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-14-2009 10:05 PM
