Old 08-30-2009, 05:25 AM   #1
HungryHippo
Member#: 187891
1999 STI version 5
Default help with whine
my 1999 jdm sti has started making a whining noise. it only happens when the car is warmed up and ive been doing some spirited driving for a while. the noise only occurs when im turning the wheel and the pitch of the whine changes with rpm. Im thinking power steering pump but all the threads about whining noises on here happen when its cold and dont seem to be steering angle related.
Anyone have any suggestions?
HungryHippo is offline   Reply With Quote
Old 09-08-2009, 11:04 AM   #2
HungryHippo
Member#: 187891
1999 STI version 5
anyone?
Old 09-08-2009, 11:26 AM   #3
Aphex28
Member#: 11506
2015 WRX
have you checked your power steering fluid reservoir? Chances are you just need to put some power steering fluid in.
Aphex28 is offline   Reply With Quote
Old 09-08-2009, 11:37 AM   #4
HungryHippo
Member#: 187891
1999 STI version 5
I havent checked it hot but i checked it cold and its 3/4 of the way up the cold mark.
Old 09-08-2009, 12:44 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
how old are your belts?
Old 09-08-2009, 01:32 PM   #6
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
^^^ yes and check the tension...I had that problem....it needs to be checked about monthly for tightness
Cbgrandtheftauto is offline   Reply With Quote
Old 09-08-2009, 09:58 PM   #7
HungryHippo
Member#: 187891
1999 STI version 5
not sure how old the belts are, ive only had the car for a year now. I'll chek the belt tension this weekend. thanks for the advice
Old 09-09-2009, 09:04 AM   #8
HungryHippo
Member#: 187891
1999 STI version 5
had a quick look at the belt. it still seems to be in very good condition and seems to be nice and tight,not too tight but not loose.
I also got a CEL this evening. When I started the car up the CEL was on for about 3 seconds then went off. it came on again when i was at a steady 80km/h for a second then came on again about 10 seconds later for about 10 seconds then went off. The car didnt seem to behave any differently when it came on.
I found too that when i was mid corner in gear the whine was there and would become louder and higher with more revs but completely disappeared if i put it in nuetral mid corner.
Is there any way to check my CEL or do i need an obd-ii machine? my car is a jdm 1999 version 5 sti
Old 09-10-2009, 10:08 AM   #9
HungryHippo
Member#: 187891
1999 STI version 5
Found a way to check my fault codes. It's putting out code 22 which looks like knock sensor. Are they expensive to replace?
Old 09-10-2009, 10:47 AM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
About $100. Takes about 15 minutes to replace but you've got to pull off the intercooler.
Old 09-10-2009, 10:50 AM   #11
HungryHippo
Member#: 187891
1999 STI version 5
cool. Ive been googling but cant find a diy to change the knock sensor. Once I get the intercooler off is it pretty obvious which is the knock sensor?
Old 09-15-2009, 12:40 PM   #12
HungryHippo
Member#: 187891
1999 STI version 5
got a new knock sensor from subaru today for 7500yen. hooked it up and reset the ECU. Thats fixed the CEL but still got the whine. Any more ideas on what to do?
Old 09-20-2009, 12:48 PM   #13
HungryHippo
Member#: 187891
1999 STI version 5
took the car out last night for a test run. tried cornering quite quickly to load up the steering. at first i kept the revs low but cornered hard, no noise. As soon as i reved it out to near redline at full boost though the very next corner had the whine noise and it continued as long as i kept the revs and boost up between corners. after letting the car idle for a while or just driving sedately the noise goes away.
A buddy of mine came with me in his car which has a supercharger and it sounds just like that.
Im at a loss as to what could be causing it
Old 09-20-2009, 03:44 PM   #14
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Alternator or steering pump bearing noise?
Marnix is offline   Reply With Quote
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 06:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 09:53 AM
Help loud whine when I turn the steering 03silverblt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 12-26-2008 12:56 PM
need help with a weird whining noise..... crosta21 Service & Maintenance 10 05-16-2006 03:25 PM
Help with CD player motor whine please! Ratdog Car Audio, Video & Security 1 07-25-2002 08:09 AM
