Old 08-30-2009, 10:05 AM   #1
creedm66
Member#: 112189
2006 wrx
wrb
Default Need help with new wheels
I purchased a set of gram lights off of a forum member not to long ago and finallyt put them on. Along with the wheels i bought rays lug nuts and hub centric rings from tire rack.
Now onto my issue, after drivering roughly a mile the lug nuts are beggining to loosen. On my way to work today i had to stop twice and tighten the lugs because they were loosening so badly.
Any input greatly appreciated.
creedm66 is offline   Reply With Quote
Old 08-30-2009, 03:22 PM   #2
creedm66
Member#: 112189
2006 wrx
wrb
Anyone have any input/advice?
Old 08-30-2009, 03:27 PM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
Wirelessly posted (Opera/9.60 (J2ME/MIDP; Opera Mini/4.2.14320/554; U; en) Presto/2.2.0)
what torque are you using to tighten the lugs?
Old 08-30-2009, 03:44 PM   #4
creedm66
Member#: 112189
2006 wrx
wrb
Don't have a torque wrench available I read that eight turns is good for the wheels/lugs I have. I forgot in the first post they are +48 offset if that has any bearing which I'm sure it could.
Old 08-30-2009, 04:34 PM   #5
flukewrx
Member#: 75081
2003 WRX
Tightening down "eight turns" is not a specific torque setting. Especially since "eight turns" on a regular set of wheel studs vs a long set of wheel studs would end up putting the lugs at a different point on the stud all together instead of tightened down properly.
Either purchase a torque wrench or swing by a local tire installer and have them torque down your wheels for you. Typically new wheels and lugs are supposed to be re-tightened after driving the first 50-100 miles anyways as they do have a tendency to "back out" or loosen up.
flukewrx is offline   Reply With Quote
Old 08-30-2009, 06:31 PM   #6
creedm66
Member#: 112189
2006 wrx
wrb
Had them torqued down by local tire shop let's see how it goes from here still gladly accepting input.
Old 08-31-2009, 11:17 AM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
What ft-lb did they torque them too? And please don't say "they just used an air wrench".
Old 08-31-2009, 11:53 AM   #8
creedm66
Member#: 112189
2006 wrx
wrb
He used a torque wrench and a thin walled socket knew what he was doing. He looked up the specs in a book before hand I don't know exactly what he tightened them to although they seem to be good. I do think they need rebalanced though vibrate a little bit over 40 mph.
Old 08-31-2009, 02:34 PM   #9
mosc
Member#: 177401
2015 STi White
You say that like you've never seen them do it. Soooo many shops do it. 175 ft-lbs all around!
mosc is offline   Reply With Quote
Old 08-31-2009, 05:03 PM   #10
creedm66
Member#: 112189
2006 wrx
wrb
seems like they are holding strong now i must have had the, over tightened now on to the alignment and getting the tires rebalanced im sick of my seat vibrating at 45mph
Old 08-31-2009, 05:57 PM   #11
littlewhitewagon
Member#: 103068
11 STI sedan
You need to make sure the lugs are torqued properly, uneven or overtorquing makes vibrations.
Unless you maintain your lugs and studs well, get rid of those Aluminum lug nuts.
littlewhitewagon is offline   Reply With Quote
Old 09-01-2009, 07:59 AM   #12
mav1c
Hoodbridge!
Member#: 560
I said it because I know shops do it all the time. Sounds like the OP found someone that was competent.
need help with new wheels george872 Member's Car Gallery 2 10-09-2007 03:21 AM
Please help. Need help with new home buying. Dr. Zevil Mid West Subaru Owners Club Forum -- MWSOC 13 03-05-2003 02:53 PM
need help with Volk wheels crowbar Brakes, Steering & Suspension 6 03-04-2002 08:43 PM
Need help with steering wheel install Freeskier Interior & Exterior Modification 9 10-02-2001 11:42 AM
Opinion: Tire Rack needs help with custom wheels 63Alpine Brakes, Steering & Suspension 1 06-28-2001 10:15 AM
