Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 08-30-2009, 10:54 AM   #1
johnpaulm1208
Member#: 216505
2002 WRX Sedan
AWP
Default problems with my recently lowered forester. help!
I just lowered my 99 forester with Prodrive springs and front struts. (GR-2's in the rear). I also installed camber bolts in the top holes of the rear struts (per my friends advice). the problem is the camber is slightly positive and every time i try to adjust it, it seems to make minimal or no difference. Am I not adjusting something right? also when i installed my front struts the holes of the driver's side strut weren't aligned and i could not get it to align because the axle didnt seem to be moving in all the way. I ended up dropping the wishbone part and punching out the safety pin to remove the other end and realign everything. it fit perfectly but now when i turn there seems to be a knock every so often. Could this be caused by what I did? the tires clear the fender so I don't think that's the problem.
thanks!!
johnpaulm1208 is offline   Reply With Quote
Old 08-30-2009, 11:58 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
"wishbone part"? "safety pin"? not sure what your referring to there - pics?
usually the only thing that's sometimes required to get the holes to line up is to disconnect the swaybar/endlink
for the rear camber it sounds like the bolt is not installed correctly OR the tab on the washer got mashed - this may help Camber Bolt FAQ and Tutorial
UkNuck is offline   Reply With Quote
Old 08-30-2009, 09:20 PM   #3
johnpaulm1208
Member#: 216505
2002 WRX Sedan
AWP
thanks! i figured out that my axle just snapped i need a new one =(..cant imagine how that happened. but yea i shudve just disconnected the swaybar...never thot of that..and i did use that link to install my camber bolts its just that i have rear drums and i cant really see where the lobe is. i tried guessing using the space where the tab of the washer goes into the strut. im hoping i didnt mash the washer...new camber bolts (tho their $50) are still expensive to a college kid
PROBLEM WITH MY WRX STI - please help me bradsti Newbies & FAQs 33 03-28-2008 06:09 PM
Problem with my 92 Legacy please help!!! 92LegacySpOrT Newbies & FAQs 7 09-10-2007 11:20 PM
Problem with my 05 Saabaru...please help rdy4flt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-28-2006 12:50 PM
CAI problems with my 05 sti, need help kamyar311 Newbies & FAQs 32 03-14-2005 02:44 PM
problem with my profec A please help?? dana Engine Management & Tuning 3 01-23-2003 02:34 AM
