Old 08-31-2009, 03:11 AM   #1
sgiord86
Member#: 212715
Default Finally bought ej257 block, What else do i need ?
OK so finally after weeks of trying to find the best bang for my buck engine rebuild due to a spun bearing on my 2.0 i finally purchased a new EJ257 i am going to list the parts i also purchased along with it, so if you see anything i am missing please post, Keep in mind i went 2.5 because it was the same price as a new 2.0, so my power goals are nothing more then conservative, i have no intentions of the engine ever seeing 300 HP.
New 2009 EJ257 with nitrided crank
STI oil pump
Sti water pump
new timing belt tensioner
new timing belt
OEM head gasket
ARP head studs
Heads checked out ( were redone 6 months ago)
Tune from AKUMA motor sports
When i purchase the oil cooler which one do i buy the STI or WRX one?
I have the head gasket, But what other gaskets do i need ?, i find paying almost 300 for a gasket set is crazy, considering from the parts store most small gaskets are 4 bucks at most.
Dont hate on me for not putting pistons in, as i said my power and boost goals are low, and stock STI internals are good for 400 hp. so im guessing hp under 300 wont be a problem for the ringland, especially with a good knowledgable tuner doing my tune.
sgiord86 is offline   Reply With Quote
Old 08-31-2009, 08:35 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
oil cooler must be purchased for specific block. newer blocks use slightly different from older. If the ringlands are gonna break, they are gonna break.
headgaskets
exhaust manifold gasket
intake manifold gasket (if yours look bad)
cams seals
front crank seal
ANY gasket that you see LEAKING
FuJi K is online now   Reply With Quote
Old 08-31-2009, 06:34 PM   #3
sgiord86
Member#: 212715
cant's get the 09' oil cooler yet, what about the 05-06 you think they will fit.
Old 08-31-2009, 06:39 PM   #4
sgiord86
Member#: 212715
also , oil pan wise, will the 2.0 pan fit, or will i have to get an sti one
Old 09-01-2009, 11:40 PM   #5
shwoop_soobie
Member#: 102323
99 power poles
beware
i am pretty much in the exact same boat as you and my list looks quite similar except i am going with forged pistons (a block from raw 1 performance)...
i am wondering if the 300 dollar gasket kit is worth it....
and also about the oil cooler... never thought of that... hopefully ron will know what to do
shwoop_soobie is offline   Reply With Quote
Old 09-02-2009, 01:44 AM   #6
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
The $300 gasket set includes a bunch of stuff you probably won't use, so you can sell them to offset the cost. Since you have heads and the block is pre-assembled, you can sell all of those gaskets, and you probably won't need any of the manifold or TGV gaskets as well. However, you'd probably still save money and trouble by checking out the master gasket thread in this forum and ordering only the gaskets you'll need.
Merp is offline   Reply With Quote
Old 09-02-2009, 09:15 AM   #7
ryan_west06
Member#: 139045
05 STI SnowmanTune
wow your wasteing alot of money for a suby to never see 300hp
ryan_west06 is offline   Reply With Quote
Old 09-02-2009, 02:28 PM   #8
cpturbo
Member#: 49175
2004 STI
I'll sell you my Moroso oil pan, cheap. You could use that and it comes with it's own pick-up!!
cpturbo is offline   Reply With Quote
Old 09-02-2009, 02:52 PM   #9
wrxdrivr04
Member#: 156619
2004 WRX 2.5 hybrid
FP EVOIII 16g
+1 if you wanna stay under 300 shoulda just went back to ur 2.0 block saved a lot of money and time!!
wrxdrivr04 is offline   Reply With Quote
Old 09-02-2009, 03:09 PM   #10
sgiord86
Member#: 212715
I didn't want to buy used, in the end would of been around the same price to put a new 2.0 . Got the car for $5000, spent $3000 on hybrid build w/ rebuilt heads and new clutch . The 3000 includes the tune . So $8000 total on a clean ass subie with a 0 mile hybrid. Still sucks my engine blew. But now I got an almost like new car.
How much for the oil pan ?
Old 09-02-2009, 03:41 PM   #11
AWDWRXLOVER
Member#: 50267
02 built hybrid
sr55/meth/sick speed
hes right. if you want new the price between a 2.0 and 2.5 hybrid are almost the same. few hundred extra for the tune but the tq is well worth that.
AWDWRXLOVER is offline   Reply With Quote
Old 09-02-2009, 03:44 PM   #12
ryan_west06
Member#: 139045
05 STI SnowmanTune
Well you for sure dont need ARP head studs ROFL
Old 09-02-2009, 04:19 PM   #13
sgiord86
Member#: 212715
Lol I know , only an extra 20 bucks then oem so why not . Just to think I almost put pistons in ...
Old 09-02-2009, 04:44 PM   #14
Merp
Member#: 199106
Patches on OEM ECU
To each his own. Nothing wrong with overbuilding a motor especially when the OE bolts should be replaced if they have any significant mileage. The easier head installation and smaller chance of losing a head gasket down the road is worth the $20 alone.
Finally decided to go with the Blouch 18G, what else do I need to get? lateralus1082 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 03-24-2009 06:49 PM
just ordered some STi heads to go wiith my EJ257 block...what else do I need? ted dibiase Built Motor Discussion 10 10-04-2007 01:40 PM
Help, need a new clutch, what else do I need?? xenonk Transmission (AT/MT) & Driveline 0 09-21-2003 11:41 PM
What else do I need when I get a pulley? BrysImpreza Normally Aspirated Powertrain 4 04-23-2001 07:25 AM
V5 Springs/struts . . . What else do I need? PRODRIVEN Brakes, Steering & Suspension 13 03-17-2001 01:50 PM
