Old 08-31-2009, 08:49 PM   #1
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
Default stock 07 sti - rear 02 sensor on its way out?
Hey guys, ive been reading up on these CELs?, but it seems everybody who gets it is running a later model subaru with an aftermarket exhaust.
I got the codes pulled and i had 2 CELS
P0137 cat efficiency rear o2 sensor low voltage
P2096 the dreaded too lean code rear 02 sensor
I had a TBE installed with the mechanical cel fix (plug anti fouler) which is a prime candidate for these codes from what i understand. i would get them once in a blue moon. It started to do it more frequently and finally i just put the stock exhaust back on.
I was driving today, and these CELS popped back up... could my rear 02 sensor be going out? the low voltage CEL leads me to beleive that..
would a bad 02 sensor cause an actual too lean condition (dont beleive its likely but thought id ask), or is the sensor just reading off?
Thank you in advanced... all of you knolegeable and experienced subaru owners!
Turbo9000 is offline   Reply With Quote
Old 09-02-2009, 05:45 PM   #2
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
bump.
could this be the front 02 sensor?
I do notice a bit of a ticking sound coming from what seems like the front left, maybe like a small exhaust leak at the ehaust manifold. It could also be mechanical valvetrain noise It would be odd that it could be leaking because i havent touched a wrench the exhaust manifold.
i know these CELs can be associated with exhaust leaks.
Tranny on its way out? Noise in first 04 WRX (NJ) Transmission (AT/MT) & Driveline 0 05-22-2009 01:21 AM
Suspension on its way out? Ekeenan86 Newbies & FAQs 5 04-09-2009 07:54 AM
Bad Detonation Still- Is my engine on its way out? JeffrWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-04-2006 01:29 PM
power steering on its way out? AJ711 Service & Maintenance 3 03-03-2005 05:23 PM
Turbo on its way out? DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-05-2002 03:10 PM
