Old 08-31-2009, 09:34 PM   #1
SausageCat
Member#: 220965
Default Hot weather vs Warm Weather vs Cold Weather - RPM issue.
Just got my 05WRX back from short block swap after spun bearing issue. The Engine appears to run smooth and strong. I have one issue thou.
When I start the engine on a cold engine the rpm goes to about 1500 then slowly goes down to 500 - 600. I can speed up the process by sharply pressing on the gas pedal... and right after that the rpm goes to 500-600 range (Warm weather, Cold Engine). But, as soon as the weather gets hot - I have an rpm freak-out. The startup is still fine but then when I'm driving sometimes the rpm doesn't go down below 1500 - 2000rpm when the gear is disengaged and the car is in full stop (red light, no foot on gas)... I can sharply kick the gas pedal and right after the rpm settles again around 500-600 rpm. This only happens when its hot outside. When I'm driving at night (Cold weather) the rpm's are fine all the time.
Any idea what it could be? Again, I just had the short block swapped.
SausageCat is offline   Reply With Quote
Old 08-31-2009, 11:00 PM   #2
Hawkeye_Chaw07
Member#: 219155
2007 Wrx
Do you pull a CEL? If so, it might be your IACV.
Also, check the tightness of your throttle cable/cruise control cable.
My car has the same problem in hot weather stop and go traffic, eventually I found wire showing on the harness into the IACV.
Hawkeye_Chaw07 is offline   Reply With Quote
Old 09-01-2009, 01:23 AM   #3
SausageCat
Member#: 220965
No CEL, the IACV looks clean from outside. Car is all stock and has only 30.000km. I'll check the wires next...
Old 09-01-2009, 01:55 AM   #4
toconn
Member#: 166656
2002 WRX Wagon
This sounds completely normal to me?
A high idle is normal while the engine is warming up in a cold-weather start.
Your A/C is probably on in the hot weather (if you have the "AC" button off but the car set to one of the defrost-vent settings, your A/C will still cycle).
toconn is offline   Reply With Quote
Old 09-01-2009, 09:28 AM   #5
SausageCat
Member#: 220965
That I know, Im talking hot weather + hot engine = 1500 - 2000 RPM periodically. The A/C and vent system is off. Open windows instead
Old 09-01-2009, 02:15 PM   #6
phishninmn
Member#: 199831
2003 wrx wagon
psm
i have the same problem it sucks
phishninmn is offline   Reply With Quote
Old 09-01-2009, 03:20 PM   #7
windozer
Member#: 213473
2004 WRX Wagon 19t
San Remo Red
You should try loosening the cruise control cable. Sometimes when it's really warm out and the engine gets nice and toasty that wire can snag and such. I only have the problem sitting in stop and go traffic for 15+ minutes.
windozer is offline   Reply With Quote
Old 09-01-2009, 08:51 PM   #8
van_dutch
Member#: 198633
2004 WRX
The high idle in the heat is most likely due to the cruise control cable as was mentioned. There is a bracket that warps as it heats up (sitting in traffic, a particularly hot day, etc). It then pulls on the cruise control cable, forcing the idle. Adding some slack to the cruise control cable can help. Try searching for "high idle" and "cruise control cable" to get more details.
van_dutch is offline   Reply With Quote
Insane RPM cold weather problem Exit8aNJ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-16-2006 02:09 PM
Insane cold weather RPM problem Exit8aNJ Transmission (AT/MT) & Driveline 3 03-16-2006 12:53 PM
Cobb stage 2 cold weather boost vs warm weather OvrClkdPmp Engine Management & Tuning 4 04-22-2005 07:54 PM
Very cold weather clutch issue semabe Transmission (AT/MT) & Driveline 4 03-04-2004 03:24 PM
cold weather -- gas smell issue wrxdriver North West Impreza Club Forum -- NWIC 17 01-15-2004 02:42 PM
