Old 09-01-2009, 07:09 AM   #1
joebush44
Member#: 163483
2007 STi
Default What the heck is this? 257/205 Build Question HELP
A buddy and myself are now assembling the rest of my hybrid motor. We put the intake manifold on and noticed an extra inlet/outlet coming from the block. It is right next to the seam of the block halves and back closer to the flywheel (see pics)
It is a brand new ej257 2.5l shortblock...ej205 2.0l heads. I looked at the 2.0 block and there isnt this "thing" protruding out of the top of the block. What is supposed to go to that? Can I just plug it? Did i miss something?? What gives
In the red circle...whats that??
Doesn't have it here on the 2.0...
Another shot with the intake manifold on from the back looking over the flywheel...goes to nothing but strait into the BPV return hose to the turbo inlet...
HELP
Thanks guys
Not sure if this is the right place to post, but it is a hybrid build after all
joebush44 is offline   Reply With Quote
Old 09-01-2009, 09:16 AM   #2
scprs
Member#: 172359
2005 STi
I want someone to answer this two.... im finishing my hybrid now.
scprs is offline   Reply With Quote
Old 09-01-2009, 09:42 AM   #3
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
most people just block it off. it's just another crank vent i believe.
ownnij is offline   Reply With Quote
Old 09-01-2009, 09:57 AM   #4
scprs
Member#: 172359
2005 STi
sorry for kind of thread jackin but this is a good question.
So if you are using a catch can would you T those two top breather ports?
Old 09-01-2009, 10:00 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Yes, it's another crankcase vent. It's a light press fit in, I pulled mine out and JB welded a cap over the hole when doing my NA build with DOHC heads in my Legacy.
Old 09-01-2009, 11:20 AM   #6
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
i took and t-ed it with the pcv breather and ran those to my one catch can, then of course the heads are already t-ed together into another catch can..
Twiztidunreal is offline   Reply With Quote
Old 09-01-2009, 11:27 AM   #7
scprs
Member#: 172359
2005 STi
I thought the pcv was to be blocked off? guess it wouldnt hurt anything.
Old 09-01-2009, 01:31 PM   #8
joebush44
Member#: 163483
2007 STi
I was thinking it was just a breather...
So, this can just be blocked off with no problems?
If so, what would be the best way to do that?
Thanks for the help everybody!
Old 09-01-2009, 01:39 PM   #9
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You need to be careful if you tee both together. One vent is baffled, the other is not. If you have them both tied back into your intake its very easy to suck up oil through the unbaffled vent. If you don't have STi heads to plumb it right most just cap off the center one.
kellygnsd is online now   Reply With Quote
Old 09-01-2009, 02:22 PM   #10
ownnij
Member#: 70459
does anyone have the size of that vent? i want to go buy a plug at the hardware store on the way home.
Old 09-01-2009, 02:54 PM   #11
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I got the assorted plug plenty pack at my autozone that had the correct size. I don't know the exact size off hand though.
Old 09-01-2009, 10:30 PM   #12
Twiztidunreal
Member#: 63249
2004 2.5 STI Wagon
05 FXT Black
o i know, exp. during a brake in....
my cans are VTA for now as my 35r doesnt have an intake
Old 09-02-2009, 01:42 PM   #13
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
I don't remember the size of it, but I plugged it.
Thug Nasty is offline   Reply With Quote
Old 09-02-2009, 05:51 PM   #14
Vmiz
Member#: 115744
i believe it's a 5/8 freeze plug i use
Vmiz is offline   Reply With Quote
Old 09-03-2009, 05:26 PM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
FWIW, the EJ207 also has this additional crankcase vent, and I've had it T'd for 30,000 hard miles with no problem.
jblaine is offline   Reply With Quote
Old 09-05-2009, 07:57 AM   #16
joebush44
Member#: 163483
2007 STi
I see, good info here...i ended up just capping it with a metal cap and ample JB weld - flipped the motor over (on engine stand) and let it set overnight. Done.
Thanks all
Hopefully this doesn't cause any problems
Old 10-09-2009, 07:31 AM   #17
Gamers
Member#: 220701
2004 White STi
For Sale!
whats the pros and cons of removing this part off an sti?
Gamers is offline   Reply With Quote
Old 10-09-2009, 03:42 PM   #18
Maxwell Power
Member#: 190729
5/8 freeze plug.
Pull the nipple out with vice grips. Get a 5/8" freeze plug from napa/advance/shucks/carquest and push it in.
/thread.
Maxwell Power is offline   Reply With Quote
what the heck is this? JDM smart people help (Duo) supermoose Subaru Conversions 9 11-08-2005 06:51 PM
Help! What the heck is this? help ID this for me? gezebo General Community 22 03-12-2004 03:18 AM
what the heck is this part on ebay? Is it B.S.? Newbie can't tell. tiltrite General Community 4 05-14-2003 07:40 AM
('93-'01) What the heck is this thing behind the wheels? Andrew Impreza Forum 18 07-08-2001 11:58 AM
('93-'01) What the heck is this? iBlueVirus Impreza Forum 32 04-06-2001 10:32 PM
