Old 05-06-2002, 03:10 PM   #1
decepticon
Member#: 18129
1999 2.5RS-T Impreza
Silverthorn metalic
Talking i need more power!
ok i've had my 99 impreza for about 2 weeks now, so far i've got lightened crank pulley, cat-back exhaust, and short shift. I was going to get an intake but Larry Ganz has none in stock
So i've decided to eventually go turbo, but until i have about $4000 to spend on that i want to do some other stuff to get more power before i get a turbo (probolly won't happen til end of summer or next spring) so what else should i get done? i can't decide!
please provide links with answers because i'm having a hard time finding parts for a 99 impreza
Thanks to everyone that replies in advance!
oh yeah...anyone know of a full brake kit that comes with front and rear rotors and calipers? (please provide link!!!)
decepticon is offline   Reply With Quote
Old 05-06-2002, 03:21 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
what do you need all this power for? do you regularly visit the track? maybe visit the Skip Barber school or something?
JGard is offline   Reply With Quote
Old 05-06-2002, 08:35 PM   #3
decepticon
Member#: 18129
Silverthorn metalic
i just want more power than stock, i go to the track sometimes, and i also go to car shows. i just want the most performance i can get out of my new car because i love it so much, but i don't feel it has reached it's full potential
Old 05-06-2002, 10:14 PM   #4
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
headers, hi-flow cat, S-AFC (or proecm/torque II chip), lightened flywheel
SubyRacer is offline   Reply With Quote
Old 05-06-2002, 10:57 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
yeah just go out and buy a Used ITC and a S-afc and call it quits untill you get your turbo. cances are most of the parts you get now will probably be replaced by something else when you get a turbo anyway.
Brad
STiTuner is offline   Reply With Quote
Old 05-07-2002, 08:06 AM   #6
Oquipah
Member#: 9689
1998 Legacy GT
Post
mmmmm....turbo.
What about upgrading the suspension and braking power so that when you do go with the turbo it will handle well?
As far as exhaust goes..wouldn't you want to wait until you get the turbo to upgrade to a larger diameter exhaust? I have a N/A car so I'm not really too familiar with mods associated with a turboed car.
Peace,
Oqui
Oquipah is offline   Reply With Quote
Old 05-07-2002, 06:53 PM   #7
Vestas
Member#: 7166
2000 Impreza 2.5RS
Saab Monte Carlo Yellow
It's been posted time and again on this site that if you want more power out of your car, you better lay out a plan and definately talk to a reputable shop near you about how to achieve it.
How much horsepower do you want?
How much torque?
Do you want to go turbo?, supercharged or stay N/A?
How much money do you have to spend?
All at once or in stages?
Usually upgrading in stages is the best way to go that way you can afford steps in the process, however at various points in time you may have less power than stock depending on how you stage it etc. But a carefully thought out stage plan will keep you from buying parts you'll need to replace down the road.
You're best bet would be to improve the suspension BEFORE doing serious power upgrades, no point in all that power if the car doesn't handle right in the first place. New springs and struts etc. Sway bars, endlinks, bushings, etc. You'll see better results in your class at the track. Unless you primarily drag race *shrug*.
If you want power or handling it's going to cost money, lots of it. Easily $4-10k before you're done depending on what you want done. Keep in mind, that there's a limit to the "bolt on" power you can get before you need to start considering things like a new gear box, driveshaft, cams etc.
Vestas is offline   Reply With Quote
Old 05-07-2002, 08:14 PM   #8
Daveish
Member#: 8935
2001 Impreza 2.5RS
Just something to consider...
Gains made by bolting on an N/A part are usually very slight and barely noticable (compared to FI upgrades, at least). Since you're set on going turbo, I'd ask yourself if the money you'd be spending on N/A upgrades would really be worth the slight HP gain -- since no decently priced N/A upgrade path would really satiate a (presumably) power-hungry fellow like yourself.
I speak from experience here, since now that a decent supercharger kit is in development, I wish I hadn't bought some of the N/A stuff I have now.
Daveish is offline   Reply With Quote
Old 05-08-2002, 02:36 PM   #9
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
You should just save up the few hundred bux for the small bolt on things and just put it in your turbo fund. intake/exhaust, etc, you'll probably end up replacing these once you get your turbo. How about upgrading your suspension, brakes and tires? -- Tires are a must IMO.
-vic
cRayZee is offline   Reply With Quote
Need More Power! Just got smoked by S2000 Tuning Factory Inc. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 05-12-2001 01:08 PM
NEED MORE POWER!!!! jacksplat Normally Aspirated Powertrain 9 04-24-2001 02:32 AM
I Need More Power!!! NYEJ25 General Forum Archive 8 01-16-2001 12:22 AM
Need More Power!!! CRAZY KEN Legacy Forum 1 05-04-2000 04:17 PM
