Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 09-01-2009, 06:28 PM   #1
Circuit Motorsports
Vendor Sales Rating: (149)
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Default BC Racing Coilovers ~ Package Deals- THE BEST Prices/Deals!
All of you guys know how good of a deal the BCR coilovers are at this point. There are hundreds if not thousands of happy Subaru customers driving around on these things, winning races, tearing up autocrosses, cruising the highways and attacking the mountains. Well we are here to give you guys and girls the best package deals and customer service we can on these awesome coilovers.
We are local to the BCR N.A. Headquarters and we are very familiar and well versed in their coilover systems. We can provide helpful info on setups, what spring rates work best for what setups, and when you want pillowball/camber plates/rubber mounts.
How familiar are we? Well just ask us We run the ER series on our CMS STI as well, so we have firsthand experience.
Ok so on to the package deals:
Buy a set of Coilovers and get a FREE upgrade, Just pick from one of these items~
-FREE Kartboy short shifter
-FREE Kartboy endlinks (front or rear)
-FREE Kartboy Pitch Stop
-FREE Kartboy lightened pulley
-FREE Whiteline Rear Camber Adjustment Kit w/ Bushings and Bolts (for rear camber adjustment on 08+ WRX & STI)
Coming soon: FREE CMS pulley cover or Hood Vent
Want to adjust your camber front AND rear? All these systems come with front camber plates, but the rears are a solid plate for OTS kits. Call us for AWESOME package deals on rear camber plates or rear camber kits.
ER Series: Double adjustable, rebound and compression, external reservoirs - $1750 shipped (Call for package deals) *FREE REAR CAMBER PLATES*
BR Series: The most popular series BCR sells -
$999 shipped (Call for package deals)
RA Series: Inverted setups - $1225 shipped (Call for package deals)
*Shipped prices are quoted for lower 48 States.
We can also spec different spring rates, and custom valving at no extra charge. If you want to switch around upper mounts for rubber or pillowball we have those services as well at no extra charge.
PM, email, or call us with questions on setups, price matching, or to place an order!
Available For:
'02-'07 WRX ............... '08+ WRX
'04-'07 STi ................ '08+ STI
'97-'01 GC8 ................. '02+ Baja
'97-'00 Legacy ............. '01-'03 Legacy
'05-'08 Legacy .............. '02+ Outback
'97-'01 Forester .............. '02-07 Forester
Here are the full specs on each system:
Systems;
"The BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and our patented concave lower locking ring keeps it locked in. All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
BC Racings Inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover setup we move the vital damper fluid away from detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The Inverted setup also handles high-g loads better and is much more durable under high stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than a conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune their setup using the separate, 30-way, rebound and compression tuning dials."
Specs;
General
- Mono-tube shock design
- 30 levels of damping force adjustment
- Pillowball mounts and adjustable camber plates included*
- Adjustable rear camber plates available
- Separate Full length height adjustable
- Inverted and Non-Inverted setups
- One year warranty
Rebuildable
Technical
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force.
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control.
- Patented concave lower locking ring, to prevent unseating
- Springs are made of SAE9254 high strength, durable steel. Compression tested at over 500,000 times with less than 5% deformation
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
- Iron lower brackets on MacPherson struts to ensure rigidity
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life.
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion
- Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation.
- An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself.
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Address - 2427 Forsyth Road Unit P
Orlando, FL 32807
Check Out Our Customer Reviews:
Circuit Motorsports is offline
Old 09-02-2009, 11:34 AM   #2
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
PM's replied!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-02-2009, 05:47 PM   #3
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
PM's answered
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-03-2009, 10:25 AM   #4
slvrsubie05
Member#: 222562
hey i have an 05 sti, wondering if the br series coilover fit on my car, also they are $999 shipped with front and rear camber plates?
slvrsubie05 is offline
Old 09-03-2009, 12:34 PM   #5
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
YES and YES.
PM's replied
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-03-2009, 08:29 PM   #6
reddoak
Member Sales Rating: (10)
Member#: 147628
2013 Beep beep
it's a Jeep.
I've got a friend with a Mazda Speed 3 (yeah, I know) who was asking about coilovers, I know BC makes them for other cars than subies, do they have Mazda fitment?
reddoak is offline
Old 09-03-2009, 11:42 PM   #7
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
They do, PM sent
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-04-2009, 12:04 PM   #8
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Friday bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-05-2009, 12:24 AM   #9
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
All PM's replied
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-05-2009, 05:59 PM   #10
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Saturday bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-07-2009, 12:33 AM   #11
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Late night bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-07-2009, 07:37 PM   #12
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Labor Day Bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-08-2009, 01:19 PM   #13
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
All PM's replied
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-09-2009, 09:55 AM   #14
newcomer
Member#: 101292
PM'd you about my delivery date
newcomer is offline
Old 09-09-2009, 05:09 PM   #15
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Pm's replied
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-10-2009, 01:13 AM   #16
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Late night bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-10-2009, 01:45 AM   #17
06-wrx-tr
Member Sales Rating: (15)
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
how long will this deal be goin on. do i have time to save?
06-wrx-tr is offline
Old 09-10-2009, 11:58 AM   #18
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Just shoot us a PM when you're ready and we'll set you up
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-10-2009, 05:35 PM   #19
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Evening bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-11-2009, 12:10 PM   #20
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
All PM's replied!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-11-2009, 10:21 PM   #21
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Nighttime bump
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-12-2009, 01:31 AM   #22
RexRexRex
Member Sales Rating: (20)
Member#: 37389
2003 gt35r wrx
Built not bought
how long will this deal last. also do you do express shipping?
RexRexRex is offline
Old 09-12-2009, 01:13 PM   #23
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
As long as we have interested Suby owners we'll be doing deals. And yes we can accomodate express shipping.
Just let us know when you're ready
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-13-2009, 12:25 AM   #24
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Nighttime bump!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Old 09-14-2009, 11:36 AM   #25
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Monday bump, all weekend PM's replied!
__________________
"Keep Attacking..."
Website -
AIM - circuitms
Email -
Phone- 407-325-2176
Orlando, FL 32807
Closed Thread
