Old 05-06-2002, 04:52 PM   #1
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Fuel Filter Question
I am beefing up my SVX fuel system and was wondering if anyone knows the recommended fuel filter micron size spec for our cars? I have the side feed injector system like the older RS models. It seems there are some aftermarket options of 6 micron all the way down to 1 micron. Anyone know what the stock system uses? It seems to work well, its just smaller than I want.
cdigerlando is offline   Reply With Quote
Old 05-06-2002, 09:21 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Just get one from your local dealer or Subaruparts.com it should be under 20 bucks
Old 05-06-2002, 09:29 PM   #3
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I wonder if the fewer the microns, the less the restriction? I don't know much about stock fuel filters, and don't know of anyone having to upgrade them to suffice fueling needs.
Graham
Graham is offline   Reply With Quote
Old 05-06-2002, 09:52 PM   #4
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Subaru Parts
As for subaru parts, I am rebuilding my fuel system. I am going to 1/2" fuel line for future HP of 650 HP. I am going to a new filter system. Subaru parts are not an option at this point.
The fewer microns, the more the restriction.
Old 05-06-2002, 10:47 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
what about a K&N fuel filter??? not sure what those are rated but maybe you could use from from a 300zxTT or a supraTT those would flow a lot i would imagine...
also are you using intake or out of tank pumps on your car?
Brad
STiTuner is offline   Reply With Quote
Old 05-06-2002, 11:59 PM   #6
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
I'm not too sure which pump I will be using yet. That will one of my last mods. The stock pump will support 450 HP. I would like the flexibility to go to 500 to 600 HP and may do a pump to handle up to 900 HP for extra fuel recirculation and rail cooling. That is why I would like a larger fuel system. Now is the time to do stuff like this.
Fuel Filter Question MASTERMIND65 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-14-2007 03:04 PM
Fuel Filter Question Mechkiller31st Service & Maintenance 1 09-27-2006 10:57 AM
Fuel Filter Question Keith99RS Service & Maintenance 3 06-06-2003 03:55 PM
Fuel Filter questions. Inline vs. Canisters IA Performance Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-06-2003 04:44 PM
fuel filter question BrsrkOrangutan Normally Aspirated with bolt-on Forced Induction Powertrain 8 10-23-2002 11:36 PM
