Old 09-02-2009, 08:02 PM   #1
mcganz121
Member#: 138569
2010 A4 Quattro <-
06STI <- 09WRX <- 06WRX
Default Tire pressure light issue
Hey everyone,
The tire pressure indicator in my 09 wrx has came on and off for a while now. Recently, it has came back on (and stayed on) yet the tire pressure is fine. Talked to my service rep at the dealer today. Was told it could be in result to an issue with the ecu leading it to be replaced.
Has anyone ever heard of this??
Only mods are tbe and reflash...
mcganz121 is offline   Reply With Quote
Old 09-02-2009, 08:59 PM   #2
Web Foot STi
Member#: 39086
2004 STi
Nope, and oh hell...
Web Foot STi is offline   Reply With Quote
Old 09-02-2009, 09:04 PM   #3
mcganz121
Member#: 138569
2010 A4 Quattro <-
thinking its just a bad sensor then.
Old 09-03-2009, 05:44 PM   #4
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
mine came on randomly and they had to clear it - programming thing they told me. If you have reflashed your ecu - good luck getting a new one under warranty! Sounds like more of a sensor issue than an ecu issue though
subygirl is offline   Reply With Quote
Old 09-03-2009, 09:28 PM   #5
badmeat
Member#: 213680
2004 STI
inflate them to 45-50 psi, drain them, then inflate to proper pressure. This was the process that the Lexus dealer that I used to work for did when they come off the truck. doing this resets the sensors. 32psi front/33 rear i think. It's on the driver side door jam.
badmeat is offline   Reply With Quote
Old 09-03-2009, 11:31 PM   #6
Subarudave09
Member#: 209316
14 XV
this happened to my 08. take it to ur dealership and tell them u want 4 new sensors. its what i did it was under warranty
Subarudave09 is offline   Reply With Quote
Tire Pressure Light Flashing DubyaSTi Tribeca Forum 3 11-17-2008 09:53 AM
08 Spec.b Tire pressure light after putting after maket wheels Taras Tire & Wheel 15 08-14-2008 01:11 PM
Tire pressure light in 2008 WRX Troa Service & Maintenance 9 07-06-2008 06:56 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 10:33 PM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 06:12 PM
