Old 09-02-2009, 11:27 PM   #1
tunamius
Member#: 200473
04 STI
Default 255/40/ 17X9 Tire Question
Did my search and got some results but not exactly the answers I was looking for. I'm planning on getting some Rota Torques 17X9 +30 and wonder if I would rub with the above tire size. I'm on RCE yellows with stock struts and plan on rolling at least the rears fenders if necessary. I don't want to rub at all whether I'm at a slight turn or full turn. In other words, I would like it to never rub.
Advice? Should I go narrower? Do I have room to go wider? Pictures of peoples 17X9 torque set-ups with tire size and suspension mods would be greatly appreciated.
Also, I'm looking for good summer tire suggestions that don't bust the bank.
Thanks for all your help.
Tung
tunamius is offline   Reply With Quote
Old 09-02-2009, 11:41 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ya want the +42 and you WILL have to roll the fenders and use camber bolts
the new hankook ventus v12 seems to be the hot new inexpensive tire
Old 09-02-2009, 11:44 PM   #3
tunamius
Member#: 200473
04 STI
Do they make Rota Torques 17 X 9 +42? I don't mind rolling the fenders, just don't want to have to do much more modification beyond that. Would you suggest going to 245/40/17 then?
Tung
Old 09-03-2009, 01:27 AM   #4
boostfed247
Member#: 158807
Default rubbing
I just put on my 17 x 9 Rota Torques with a 30+ offset and the front doesn't rub at all. As for the back there is the tiniest bit of rubbing, but im on Tanabe DF210 springs and stock struts (soft ride).
I just got a hold of a fender roller so im takin action this weekend.
boostfed247 is offline   Reply With Quote
Old 09-03-2009, 01:59 AM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
you'll need to roll and pull the rear fenders, shave the rear bumper where it meets the rear fender, and add some rear camber. i would suggest rolling the fronts as well and maxing out the front camber. going to a 245/40 will still require as much work because of the offset.
for reference, i'm on 17x9 +39 with 255/40/17s with rce yellows and i had to roll and pull the rear fenders but i didn't have to add camber to the rear. with the +30, you'll need to pull the rear fender more than me, or get camber bolts for the rear.
Old 09-03-2009, 02:12 AM   #6
grippy monkey
Member#: 131067
your "stance"
sucks
If you don't want it to ever rub you may just need to choose another wheel. I would go for DPT's in 17x9 +42 or even +35 is a little better. I've personally had Torque R's in 17x9 +30, and I only ran a little wider than normal 235/40/17 on it. You will need to add a good bit of camber front and rear with fender work on a 245 or 255 tire. In order for the +30 not to rub you will have to do the work to make it perfect. You can do it (or a professional can) but you will have to make that decision.
grippy monkey is offline   Reply With Quote
Old 09-03-2009, 03:36 AM   #7
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
I just cut the rear fender lip right off then pounded the **** out the fender and then used seam sealer adhesive to glue the layers back together. And then clamped and did the same with the the fender mounding. Then I re-under coated everything.... I tell you it's not for the fait of heat and there is no going back.
I'm running Falken 615's in a 255/40/17 which is over 10" of rubber contact per wheel on a 17"x 9 " wide rim with 35* off set. I get a little rub in the front as I have a APS CAI.
If you are running a APS CAI and antilift you are going to have major rubbing issues on the fender liner on the right front.
dasnowman is offline   Reply With Quote
Old 09-03-2009, 08:42 PM   #8
tunamius
Member#: 200473
04 STI
Hmm, I may consider running a 235 series tire then. Like I said, I don't really want to have to do much modification beyond rolling the fenders. Would 235 be stretched on a 9 inch wheel?
Would I help my situation much by going with the 18X9.5 +35 torques since it's higher offset?
WTB: 245/40 or 255/40 18 Tires Stockers Welcome 08GRSTi SCIC Private Classifieds 3 09-15-2009 04:56 PM
17x9 dpt (+42 offset) and 255/40/17 tires scooby_wooby Tire & Wheel 8 08-16-2009 02:14 PM
WTB: 235/45/17, 245/40/17 or 255/40/17 tires BLACKWRX03 NWIC Private Classifieds 1 04-05-2009 07:11 AM
WTB: Used/New 245/40/17 or 255/40/17 tires joenationwide Private 'Wanted' Classifieds 2 12-01-2005 02:40 AM
255/40-18 tire on 04 sti crazycraig Tire & Wheel 4 02-08-2005 06:09 PM
