![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 149382
Vehicle:2004 Sti FP HTA68+Meth 368hp 25psi |
so im intrested in going with the "agressive" wheel look on my 04 sti but everyone ive talked to says the biggest wheel that will fit on the sti is 8" wide. is there a wheel or a specific offset i can get tha will allow me to utilize a 9" whde wheel without having to worry about rubbing or fender rolling...preferable im interested in the Rota G-forces in 17x.8.5 or 17x9.
#2 |
Member#: 150300
HIIC
Vehicle:2006 Grocery Getter OBP |
My bro has some 18x8.5 DPT's, +48, with 235/40/18 Dunlops without any fender work. After the setup, he can clearly tuck in some 245/40/18's. His suspension consists of Ground Control coilover sleeves over stock struts. Front and rear lower camber bolts. Good luck.
#3 |
Member#: 149382
thats awesome looks real good....what wing is that he has? is that the syms or a replica??
#4 |
Hoodbridge!
Moderator Member#: 560
Vehicle:2006 STi, '11 A4 Crystal Gray, Silver |
I really doubt you're going to be able to do a 17x9, and a correct size tire, and get it to fit without any fender rolling. You can probably get away with just a rear fender rool with something like a 17x9 +45 and a 245/40-17. I wouldn't go any thinner than a 245 on a 17x9.
#5 |
Member#: 45323
South East
Vehicle:MY05 Impreza WRX STi Pastelito Racing & SFSOC |
on the 04 STI you need to roll your fenders.
#6 |
Member#: 61536
NESIC
Vehicle:WRX' 04Road02gravel www.ToltecRally.com |
x9 is very tight. Depends on your camber and spring diameter too. If in doubt, roll.
#7 |
Member#: 149382
well im using the stock suspension/ stock struts...what would be the biggest width i could go with then to try to avoid any modification for fittment
| Thread Tools | |
| Display Modes | |
| Stupid question...can I run one wheel with a different offset than the others? | sovietjet | Tire & Wheel | 7 | 05-10-2008 05:32 PM |
| WTB/WTTF 5x100 alloys with the RIGHT offset | campsite428 | Private 'Wanted' Classifieds | 1 | 12-28-2007 09:49 AM |
| would 17x8.5 wheels with a 48mm offset fit a GC8? fenders rolled on tein flex's | scobaru | Tire & Wheel | 17 | 01-30-2007 05:59 PM |
| wheels with the best offset thread! | dodiox | Member's Car Gallery | 87 | 12-20-2006 04:26 PM |
| Can you "machine" a rim down ("up"?) to the right offset? | Tranzition | Tire & Wheel | 18 | 08-18-2004 01:31 AM |
