Old 09-04-2009, 01:25 AM   #1
mems3
Member#: 188617
Chapter/Region: PRSIC
2008 WRX Sedan
Default Turbocharging an RS
I'm on my way to turboing my RS, its a 2002 2.5 RS. I have:
wrx headers
wrx up-pipe
wrx down-pipe
wrx td04 turbo
wrx crossmember
wrx catback
anything else i'm missing? Im looking forward to buying a EMS hydra so i can carefully tune it so it doesnt break... im looking for at least 5-6 Psi... will i need bigger injectors of fuel pump. can i run for now without stock ecu? can i just slap all those things on and magically work? my mechanic has done this before but I personally want to know from you guys before he tells me what i need?
thanx
no turning back now
mems3 is offline   Reply With Quote
Old 09-04-2009, 02:18 AM   #2
rolosti
Member#: 200590
mas facil... walbro 255, 10:1 o 12:1 FMU, turbina wrx, wastegate externo, intercooler culakiera front o top, up y downpipe de moflera, y computadora de fabrica e inyectores de fabrica. vas a star super contento creeme. saludos!
rolosti is offline   Reply With Quote
Old 09-04-2009, 07:46 AM   #3
Odyknuck
Member#: 192866
2006 Impreza
A $1600.00 Hydra is overkill for a 6 PSI Boost motor. A $500.00 Greddy Ultimate will do 6 psi just fine. Unless of cource you are planning a lower compression higher Boost motor in the future. If money is no object then go with the Hydra. It will take the Piggy Back pain away however it will take longer to learn how to tune the Hydra. You will get many opinons on what to do for an ECM.
Odyknuck is offline   Reply With Quote
Old 09-04-2009, 11:21 AM   #4
2milehi
Member#: 81633
'98 RS-T
Does you car have a MAF sensor? With a MAF, the ECU can sense the extra air flow and compensate. A MAP based ECU is a whole different ball game.
You'll also need a WRX water pump, an intercooler, and some various silicone hoses/couplers.
2milehi is offline   Reply With Quote
Old 09-04-2009, 11:46 AM   #5
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
megasquirt it if you want standalone EMS
as mentioned earlier, you're going to need a walbro, and quite possibly injectors. also, check to see if the WRX fuel pressure regulator is different than the RS one. if it is, you're going to want the WRX FPR, or an aftermarket one.
also, I'd try and find a shortblock from a turbo car and rebuild it for when you blow up your stock bottom end
SomeoneWhoIsntMe is offline   Reply With Quote
Old 09-06-2009, 03:12 AM   #6
mems3
Member#: 188617
2008 WRX Sedan
im in doubt because i have no idea what kind of sensor my car has.... any one know?
Old 09-06-2009, 09:57 AM   #7
Abest10
Member#: 190962
00 STM RS
04 FXT
Another thing is Coolant/oil lines for turbo. And finding a place to plumb those into. and I think 02 RS's are MAP based. Can't confirm though.
Abest10 is offline   Reply With Quote
Old 09-06-2009, 02:12 PM   #8
silentt
Member#: 119995
2004 Outback XT
Peachy
silentt is offline   Reply With Quote
turbocharging an outback... not a good idea? TiMiN8R Newbies & FAQs 12 02-06-2009 04:01 PM
turbocharging an ej25 wrxtuner02 Normally Aspirated with bolt-on Forced Induction Powertrain 5 05-18-2003 05:01 PM
turbocharging an 02 RS jojor512 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-14-2002 11:58 AM
Turbocharging an Impreza 2.5 TL seafred Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-08-2002 09:41 PM
does anyone here have a turbocharged 2001 RS? Iron Man Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-21-2001 01:55 PM
