Old 09-04-2009, 01:53 PM   #1
subiedriver4444
Member#: 152872
2002 Impreza RS
white
Default re-painting already painted stock wheels
hey guys,
just was wondering...i have already painted my stock wheels gold about 2 years ago..and the paint is just now starting to come off...i was wondering if there was anything specific i need to do different? or can i just spray the same gold over it again without it looking like crap...hahaha
also...was thinking bout painting the lug nuts red or blue?? just a thought...i didnt think the red would go bad with gold wheels and white car personally..
Thanks!
-Kyle
subiedriver4444 is offline   Reply With Quote
Old 09-04-2009, 02:53 PM   #2
BoardRider
Member#: 32059
1997 Legacy GT sedan
CBR600, WR400, Z50R
Just sand off the old the best you can and clean, prime, and paint... It's all about the prep work.
BoardRider is offline   Reply With Quote
Old 09-04-2009, 03:30 PM   #3
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
^yep...painted lugs don't turn out so good...they scratch when you tighten or loosen them...although maybe i suck at painting
King of Poop is offline   Reply With Quote
Old 09-04-2009, 03:41 PM   #4
BoardRider
Member#: 32059
CBR600, WR400, Z50R
^ Yeah, the lugs might look cool painted, but they will scratch when you remove/replace the wheels. You could always go to a local craft store and get a paint marker that will closely match the lug's paint color and touch them up if/when this happens. Just a quick, easy fix, and it will probably be hard to notice the touchups (at least less so than the scratches from the lug wrench).
Old 09-04-2009, 03:42 PM   #5
subiedriver4444
Member#: 152872
2002 Impreza RS
white
hmm..all i did the first time was clean the wheel, and used this aircraft strip remover and then painted them..could i just get away with that again? or should i probably prime it this time? (not really the painter guru..haha)
Old 09-04-2009, 03:48 PM   #6
suub07
Member#: 163702
2007 impreza 2.5
UGM
You should try to sand everything off of them. Get them totally stripped down, then prime and paint.
Its true, prep work is key for it to look its best and last longer.
suub07 is offline   Reply With Quote
Old 09-04-2009, 10:07 PM   #7
Boostinbildo
Member#: 163892
05 AW STI:SOLD
Black 93 Singled tt Supra
Normally, you do not need to sand everything off, but you DO need to sand everything enough to make it a rough surface. But since you didnt sand it before you painted them last time, you will need to if you dont want this to happen again. Sand/steel wool every square inch of the surface to be painted. Thats why your paint is coming off in the first place, because you didnt sand last time. The paint needs a CLEAN rough surface to really bond to.
After you sand everything, clean it really well with soapy water and rinse, then you will be set to paint. You dont really need primer, but it cant hurt.
This is coming from a guy who has painted many many things, so I do have experience.
Boostinbildo is offline   Reply With Quote
Old 09-04-2009, 11:18 PM   #8
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
Heres what i did when i repainted my wheels the same color,
buy a bottle of goo gone and just wipe away all the chipping paint
this way you dont miss a spot or have certain spots with 2 coats rather then just 1 coat (blotchy paint spots)
thatkhmer is offline   Reply With Quote
Old 09-05-2009, 01:03 AM   #9
E85 WRX
Member#: 219412
aircraft remover is ur friend. i used that before, and works like a charm stripping old paint off. can be really messy though
E85 WRX is offline   Reply With Quote
Old 09-05-2009, 09:48 PM   #10
subiedriver4444
Member#: 152872
2002 Impreza RS
white
thats what i used the first time...haha. worked good for 2 years...probably will sand off what i can for this time, prime and then repaint..maybe do the lug nuts too..think that could a pretty cool idea.
Old 09-05-2009, 11:48 PM   #11
oly kenji
Member#: 211299
2005 STi
going into 2001 gc
sand it all off first. i didn't sand my painted wheels before and painted over, it chipped all day and didn't stick properly
oly kenji is offline   Reply With Quote
Old 09-06-2009, 02:01 AM   #12
jphillis89
Member#: 197786
06 2.5i
CGM
hey..what kind of paint do you guys use because I was told Duplicolor was good but every location it says it is carried at does not have it near me
jphillis89 is offline   Reply With Quote
Old 09-06-2009, 03:22 AM   #13
Momosaurus WRX
Member#: 214737
you don't need to sand all of the paint off. and you don't need to prime it unless raw metal is showing. sand it with some 400, and then paint over top, and lay down some clear coat if you really wanna do it right but make sure that it is clean after you sand it
Momosaurus WRX is offline   Reply With Quote
Old 09-06-2009, 01:25 PM   #14
UnholyPaper
Member#: 219677
06 Legacy GT
Ti White
Default pwdr coating
Powerdcoating is pretty nice, I did it to my old 2.5i rims, turned out great...cost around $350 at a normal coating shop.
UnholyPaper is offline   Reply With Quote
Old 12-04-2012, 08:13 PM   #15
Tenament
Member#: 246813
sand it with 300 then 1000 grit
hit it with two light coats of self-etching primer
three coats primer
three coats paint
clear!
you done. Enjoy for the next couple years.
Tenament is offline   Reply With Quote
Will stripping cheap paint off of stock wheels with a heat gun damage the wheels? sburck Interior & Exterior Modification 6 11-10-2008 03:35 PM
WTT Wheels: painted black bugeye stock wheels for silver bugeye wheels bugeyeblue SCIC Private Classifieds 11 12-29-2007 11:36 AM
Paint/powder coat stock wheels? Rock_Strongo New England Impreza Club Forum -- NESIC 25 07-11-2005 08:54 AM
WTT painted stock wheels for non painted stockers ErikAnderson North West Impreza Club Forum -- NWIC 19 05-04-2005 07:47 AM
Does anyone have pictures of painted or powercated stock wheels? 03SubaWRX Tire & Wheel 2 05-26-2003 04:36 AM
