Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 09-04-2009, 02:01 PM   #1
skullnbaja
Member#: 220083
2003 Baja Sport
Smile Tie-down points at high point..
Brainstorming once agian....
I've always wanted tie down points in the bed that are located higher up, on the rail of the bed not near the floor. Sometimes the stock tie-down points are too low for really bulky items. One would need to remove the plastic cap and bolt some tie-downs directly to the metal bed rails. I'm thinking I would like to do this soon. Never seen anyone do this, but if you have lets see it, or share you thoughts.
skullnbaja is offline   Reply With Quote
Old 09-04-2009, 02:38 PM   #2
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
I've secured some things that were standing at least 4-6 feet ABOVE the roof line using the floor mounts and never had a problem.
That said, depending on how heavy the item is, I've also run nylon straps around the decorative chrome bars.
I guess what I'm saying is that I find it hard to believe the need is really there, but IF IT IS, I suspect you're on the right track.
Keep us posted.
kev m is offline   Reply With Quote
Old 09-04-2009, 02:46 PM   #3
steven765
Member#: 105920
2006 Baja 5 Speed
you're also going to have several problems.
The most challenging of which being there is little metal to bolt through up top. Weak unibody ect ect.
Second, you'd then be letting water, snow and ice in there.
Third removing those rails you have to break the plastic buttons hold them on, ~$7 each.
Good luck
steven765 is offline   Reply With Quote
Old 09-19-2009, 10:19 PM   #4
BajaByron
Member#: 224287
Default Tie downs
I had a pickup that I mounted tie downs onto on the outer upper edge of the bed. I don't have pictures, but I was able to purchase the tie downs at a local parts store. I just got a 2005 Baja Turbo and am contemplating doing the same thing with it, but it's in mint condition, and I cringe at the thought of drilling holes into it. That being said, the tie downs on my truck were worth their weight in gold.
BajaByron is offline   Reply With Quote
Trailer tie down points? pignoseSTI Motorsports 32 02-12-2007 04:36 PM
FYI - 12 Hours at the Point, Summit Point, WV - June 24th! Rice & Gravy Mid Atlantic Impreza Club -- MAIC 16 06-26-2006 08:30 AM
dyno tie down points crazycraig Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 10-26-2003 09:19 PM
SUBARU Ski Fest 2003 at High Point State Park - Feb. 9 Prime Mover Tri-State Area Forum 1 01-29-2003 12:35 PM
oct 27 meet at high point state park NJ WRX Tri-State Area Forum 24 11-03-2001 09:16 AM
