Old 09-04-2009, 03:29 PM   #1
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Default Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?!
So i recently got the Tokico D-Specs installed.
At the same time I decided to do camber bolts all around as well.
And saggy butt shims but that's not the issue since the rear camber is ok.
Yes, I installed the camber bolts at least correctly!
Camber bolts, tabs and all go on the bottom hole of the strut/knuckle joint. They should be set to max and the stock camber bolt up top should be used to adjust.
Well i took it in for an alignment and the guy says he can only get -.9 out of the front camber! That's less than the -1.2 I had with my stock struts + no camber bolts. He tried twisting both camber bolts around on both sides and -.9 is all he can get.
Can anyone tell me what wrong? Or is it just supposed to be like that....
formula91 is offline   Reply With Quote
Old 09-04-2009, 03:43 PM   #2
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
It's also settled quite good. I mean I got the alignment 2 days after the installation. I don't think it's going to settle any more than that?
Is it because the struts are slightly differently sized? I'm not sure....
--edit--
I meant to edit, and yet I quoted.... My bad.
Old 09-04-2009, 03:43 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
sedan or wagon?
UkNuck is offline   Reply With Quote
Old 09-04-2009, 03:44 PM   #4
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Originally Posted by UkNuck View Post
sedan or wagon?
05 sedan
Old 09-04-2009, 04:39 PM   #5
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
This is your problem. The camber bolt should be in the upper of the two holes mounting the strut to the knuckle. The front should have had a camber bolt in this position as an OE piece. You could add an aftermarket bolt to replace the stock lower bolt, but it makes adjustments more complicated. It'd be easier to slot the upper hole with a grinder and push the hub inward to get a little more negative camber. I've done this as well as slot the top three holes in the strut tower to try and get some amount of camber while using stock struts and springs.
Scooby921 is offline   Reply With Quote
Old 09-04-2009, 04:54 PM   #6
bzbuzz
Member#: 116052
2011 STI ( Sold )
i live in same town, which alignment shop did you go?
bzbuzz is offline   Reply With Quote
Old 09-04-2009, 06:48 PM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Unless i read it wrong, that's what he did.
What springs? Is it obviously lower than it was before?
My car has a tough time hitting -1.5 with plates and stock bolts, since it's lifted very slightly. Front camber is very sensitive to ride height.
sniper1rfa is offline   Reply With Quote
Old 09-04-2009, 07:42 PM   #8
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
No currently, I am on stock springs.
But if you're having a hard time even with camber plates, I suppose nothing is out of the normal? Though I suspect I have some toe issues, it might be just memory steer. Meh.
Also, in all the guides I've read about camber bolts with subarus, it's a BAD idea to replace the stock camber bolt with this puny 14mm SPC Camber bolt. From what I understand there is a large chance of it failing and having very bad consequences from doing so.
All of them say I MUST put it into the lower slot.
http://www.iwsti.com/forums/gd-suspe...-tutorial.html
Old 09-05-2009, 07:08 AM   #9
EdHilario
Member#: 137398
2004 Impreza 2.5RS
lol I could have sworn the camber bolt when on top while the strut locking bolt was in the bottom hole
EdHilario is offline   Reply With Quote
Old 09-07-2009, 12:56 AM   #10
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Wait, so am I wrong?
Old 09-07-2009, 12:59 AM   #11
viper74656
Member#: 84758
'04 WRB WRX
You are right. Stock camber bolts go in the top hole, aftermarket ones in the bottom.
viper74656 is offline   Reply With Quote
sold 12sechatch NWIC Private Classifieds 21 06-08-2010 10:57 AM
stock struts and camber plates rotarydelight Brakes, Steering & Suspension 4 12-26-2007 11:38 PM
Tokico D-spec, Espelir GT, RCE front camber plates, rear camber bolts Scooby921 MWSOC Private Classifieds 4 04-26-2006 07:45 AM
Stock strut loose? [Visible bolt length] ncr100 Brakes, Steering & Suspension 15 10-28-2001 01:46 PM
Review: Rotrex pads-better and less dust than stock. Albert Brakes, Steering & Suspension 9 09-23-2001 10:16 PM
