Old 09-05-2009, 12:22 AM   #1
jnmarshall
Member#: 40500
11 wrx
Virtual
Default Rota quality?
I have a set of Rota Torques I bought about 4 years ago. I usually only drive on them for autox's and during the summers. This year I finally go and replace my original tires. During the balancing I'm told one of them is bent and has a bad hop. I decide to go and just buy a new one. I'm impressed after 4 years, the new one is still an exact match! All is good for 6 months. I go and have my tires rotated and balanced. Now another wheel is bent and has a hop. I'm starting to think what is happening, do these wheels only last for 4 years and about 35K miles and wear out? There's no other damage to the wheels and tires. Never been curbed or driven in harsh weather. The wheels were mounted in different locations, one was on the rear, the other on the front. I'm starting to worry that during every rotation I am going to have to replace another wheel.
Is this common with Rota's?
jnmarshall is offline   Reply With Quote
Old 09-05-2009, 01:02 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
no
this is NOT common and bent wheels are usually due to too little pressure in the tires
Old 09-05-2009, 08:33 AM   #3
jnmarshall
Member#: 40500
11 wrx
Virtual
It's definitely not a low pressure issue. I check it every month and maintain 34-35f/33-32r. AutoX I jack it up to 45-46f/44-42r.
Old 09-05-2009, 03:07 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
i have found this to be too low
Old 09-05-2009, 06:24 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Still, that shouldn't result in bent wheels. Those sorts of pressures are OEM on just about every car in America, and there aren't hundreds of millions of people running around on bent wheels.
I don't know what to tell you, jnmarshall, but Rotas should not be prone to being bent.
Old 09-05-2009, 11:18 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Wheels just don't get bent. You hit something.
If the wheel was bent, you probably would have noticed some sort of vibration before getting them balanced.
Old 09-06-2009, 11:39 AM   #7
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
Not common at all, unless of course you hit something pretty hard (pothole, uneven surface, curb, etc..). I've never damaged a Rota Wheel and I've hit some nasty potholes, they are definitely very strong wheels. You must have hit something at the right angle to cause it to bend, I had a similar situation with a Volk Racing CE28 on my car.
dan avoN7 is offline   Reply With Quote
Old 09-06-2009, 11:53 AM   #8
Damon
Member#: 2902
where is that dead horse... we can all pass around this baseball bat i have here.
Damon is online now   Reply With Quote
Old 09-06-2009, 06:50 PM   #9
kay95
Member#: 45494
95 impreza L awd
green
Ok how about this question. Did you feel a vibration or anything? If the answer is no then that makes me wonder too things. Who was doing the work and by how much are they talking about?
kay95 is offline   Reply With Quote
Old 09-06-2009, 07:03 PM   #10
48mpg
Member#: 58405
2004 Element GT65'd
Hydra, Hydramist'd STi
i see where you are going.
did you buy the new rim from the place that did your balancing??
48mpg is offline   Reply With Quote
Old 09-06-2009, 07:17 PM   #11
grippy monkey
Member#: 131067
your "stance"
sucks
I'm somewhere close to 10 sets of rotas over the years. I even accidentally launched my road going 06 WRX on coilovers and rota gforces. I've never bent a single wheel, and that's why I can vouch for them.
Any wheel can bend. It usually comes from hitting something.
grippy monkey is offline   Reply With Quote
Old 09-07-2009, 07:09 PM   #12
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Volks are t3h bettar!
Smoke is offline   Reply With Quote
Old 09-07-2009, 07:28 PM   #13
WrxRcr
Member#: 218050
2009 Wrx sedan
i have had two sets of rotas, one has over 75k on them with no problems.
WrxRcr is offline   Reply With Quote
Old 09-07-2009, 08:00 PM   #14
jnmarshall
Member#: 40500
11 wrx
Virtual
Well hopefully I just have two that have gonna bad. The worse I've hit with them are cones and highspeed RR crossing. Wheel Tech. will be repairing both if they can be repaired.
Thanks for the feedback!
Old 09-07-2009, 08:49 PM   #15
rougeben83
Member#: 115154
2005 Outback XT
White on grey
are these the new wheel or were all the bent ones from your old set?
rougeben83 is offline   Reply With Quote
Old 09-07-2009, 10:47 PM   #16
jnmarshall
Member#: 40500
11 wrx
Virtual
My original set. I only bought a single wheel to replace the first bent one.
Motorsport quality wheels that will fit 355mm ST-60 BBK? turboICE Motorsports 72 07-09-2010 06:25 PM
rota quality kh15 Tire & Wheel 15 02-12-2008 05:18 PM
Wheels: Rota quality + price, but different brand ? Sausage Tire & Wheel 0 11-06-2007 07:39 AM
Quality (strength) of Rota Rims? subarex Brakes, Steering & Suspension 20 09-11-2002 06:14 PM
Quality of Rota Wheels Scoobie Newbie Brakes, Steering & Suspension 29 07-05-2002 02:17 PM
