Old 09-05-2009, 10:57 PM   #1
motoryder
Member#: 111268
.... MLTMFA2
Default Valve stem seal color?
Quick question, which color valve stem seals(oem) go on which side? Black on exhaust side green on intake? Most recent build I just did a buddy of mine gave me some special viton seals to use and they are absolutely horrible, oil puking from almost every exhaust valve stem. I'm going to put some stock seals on and need to know which color for which valve.
Thanks,
-Mike
motoryder is offline   Reply With Quote
Old 09-06-2009, 12:13 AM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
green for intake black for exhaust
john 1badSTI is offline   Reply With Quote
Old 09-06-2009, 12:18 AM   #3
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
If you forget just look very closesly at the seal and it they will be marked, EX and IN.
Burnout is offline   Reply With Quote
Old 09-06-2009, 07:08 AM   #4
motoryder
Member#: 111268
.... MLTMFA2
That's what I thought as well.
But..........
I'll be damned, you're right, thanks for clearing that up.
Old 09-07-2009, 01:30 AM   #5
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
wrong. Factory service manual says gray for intake and green for exhaust
06rexwagon is offline   Reply With Quote
Old 09-07-2009, 02:58 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
He's not "wrong"...... Different years use different colors. My '00 EJ25/EJ22 FSM says black for intake and brown for exhaust.......
Jay
Old 09-07-2009, 10:15 AM   #7
bertune
Member#: 107290
+1
bertune is offline   Reply With Quote
Old 09-07-2009, 07:14 PM   #8
06rexwagon
Member#: 114730
[email protected]
Jay
I didn't know that. Since he didn't say what car he has either of could be right.
Old 09-07-2009, 07:18 PM   #9
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
why does it matter which ones are used on the intake or exhaust valves?
kevinh211 is offline   Reply With Quote
Old 09-07-2009, 11:34 PM   #10
06rexwagon
Member#: 114730
[email protected]
The exhaust one is designed to withstand more heat.
Old 09-08-2009, 12:40 PM   #11
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Same on my 05 STi, gray for intake and green for exhaust
Old 09-08-2009, 02:38 PM   #12
Mechie3
Member#: 120152
My 06 did green exh, gray intake. I didn't see the note at first in the FSM and put them on backwards. I though black..hmm..exhaust is black....ok. Had to take them all off and redo them.
Mechie3 is offline   Reply With Quote
Old 09-09-2009, 01:16 AM   #13
ASF
Member#: 218500
1997 OBS
Green
On most makes, the black goes on intake and the odd color on the exhaust.
ASF is offline   Reply With Quote
Old 02-10-2011, 12:04 AM   #14
twkd
Member#: 57683
2015 BRZ Premium
Ice Silver Metallic
Just did some research on this myself, because using aftermarket parts for a budget HG job for a friend.
Most of the aftermarket kits come with Viton seals and don't seem to have different valve stem seals for intake and exhaust. Viton is typically more expensive and is unnecessary on the intake side. For an aftermarket parts vendor, I would imagine this small difference in the price is just passed on to the customer. For a bean counter at a major auto manufacturer, saving a tiny amount of money for an intake valve stem seal that's made out of nitrile (or something cheaper than Viton) can save hundreds of thousands, if not millions of dollars.
I suspect the only real difference in Subaru factory valve stem seals are the material. Intake does not need the heat resistance, hence does not need to be Viton. These links show that they are physically the same dimensions (although they have two different P/Ns - going to find out if the only diff is color):
http://keithtwitchel.net/part.php?pid=122-1180 (13207AA120 - intake)
http://keithtwitchel.net/part.php?pid=122-1181 (13211AA110 - exhaust)
Any thoughts?
twkd is offline   Reply With Quote
Old 04-30-2011, 04:04 AM   #15
benjileo
Member#: 277385
1996 Subaru Legacy
Ok I bought an aftermarket engine gasket set and viton seals for my 97 jdm ej25d rebuild, with no mention of exhaust or intake on any seal. I see black springs on a brown or greenish base, and silver springs on a grey or silver base. I just don't want to find later that I put them on wrong. any input would be great.
benjileo is offline   Reply With Quote
Old 07-31-2011, 12:35 PM   #16
HappyEeyore
Member#: 29400
@benjileo - did you ever get feedback on this or figure this out ... I'm having the same problem ...
HappyEeyore is offline   Reply With Quote
Old 07-31-2011, 01:30 PM   #17
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
When I got my seals in they had in. On one color and ex. On another. Very small letters on top of the seals. These were oem replacements tho.
wrxsubiemod is offline   Reply With Quote
Old 03-22-2012, 06:48 PM   #18
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
There must be different size seals for different models. I grabbed some seals from the dealer that were lying around. Turns out the ones i used are bigger than the ones im putting in now. This was a costly mistake. Check those part numbers.
SubiSam is offline   Reply With Quote
Any difference between STi valve stem seals and 2.0L WRX valve stem seals? CoolRex Built Motor Discussion 3 10-02-2009 11:57 AM
Ferrea 4G63 Valve Guides/Locks/Valve Stem Seals ITSME4G63 Non-Subaru Stuff 0 02-07-2007 12:02 PM
Bad valve stem seals??? fishheadback Normally Aspirated with bolt-on Forced Induction Powertrain 6 11-18-2004 11:30 PM
Replacing valve stem seals? Tony Normally Aspirated Powertrain 0 09-27-2001 02:53 PM
Valve Stem Seals davidjohnclark General Forum Archive 0 12-09-2000 04:34 PM
