Welcome to the North American Subaru Impreza Owners Club Saturday April 18, 2015
Old 09-06-2009, 10:34 AM   #1
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
Default lowest offset for 02-03 wrx
i know there are threads about the sti and wheels that clear brembo, but how about the 02-03 wrx? what is the lowest offset that i can go?
vien is offline   Reply With Quote
Old 09-08-2009, 11:30 AM   #2
vien
Member#: 221538
2003 wrx/ylw wheels
anybody?
Old 09-08-2009, 11:54 AM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
low offset gives you more inboard clearance
the lowest offset you can run will depend on wheel and tire size / ride height / whether you are willing to roll fenders / how much you like your wheel bearings
what exactly are you trying to do?
UkNuck is online now   Reply With Quote
Old 09-08-2009, 11:58 AM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
Wirelessly posted (Opera/9.60 (J2ME/MIDP; Opera Mini/4.2.14320/866; U; en) Presto/2.2.0)
you need to do some research before we can answer that question. there are those that go as low as +18 but those that do are far more dedicated than others, and if they wanted they could go even lower.
your question has no definitive answer. you need tobtell us what you're looking for and what you use your car for.
Old 09-08-2009, 02:22 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d000000000000d
ya need the dubs on that rig.............+10 dubs
Old 09-08-2009, 02:24 PM   #6
Silverdc
Member#: 132230
03 Sedona Variety
10.85 @ 129mph
Why? That is my only question. Why is it that you want a low offset? Do you want to be herrafrush? Or do you want to take out your wheel bearings? Worry about the widest wheel/tire you can fit with a normal offset.
Silverdc is offline   Reply With Quote
Old 09-08-2009, 03:35 PM   #7
vien
Member#: 221538
2003 wrx/ylw wheels
the reason i ask is becuase i want to run a set of wheels that have a concave look to them but the problem with that is of course the wheel bearings and what not im not really trying to go for track use just a nice concave look to daily drive and size i would probly like to be anywhere in the 17x8 to 17x9 range
Old 09-08-2009, 04:04 PM   #8
Sleepy Wagon.
Member#: 132498
98 Lexus LS400/VIP
usVERSUSthem Krew!
Lowest on a bug i wagon is +35. That what i ran. 18x9 +35 all around. Ill show pix when i get home from school.
Sleepy Wagon. is offline   Reply With Quote
Old 09-08-2009, 04:15 PM   #9
Reaper04
Member#: 187601
2005 STi
yeah this is a good offset (+35) thats the offset I had on my TE37s(17x8), I was running 245/40R17
Reaper04 is offline   Reply With Quote
Old 09-08-2009, 04:41 PM   #10
Ruthless671
Member#: 150300
Chapter/Region: HIIC
2006 STi
^^I 2nd that, i ran the same offset on my wagon^^
Ruthless671 is offline   Reply With Quote
Old 09-08-2009, 05:35 PM   #11
nhat
Member#: 140163
03 STi
hellaflunctional
what size tire would you like to run? how much fender work are you willing to do? what are your suspension mods?
Old 09-08-2009, 06:30 PM   #12
vien
Member#: 221538
2003 wrx/ylw wheels
that sounds good did you guys have any wheel bearing problems? reason i ask becuase of the sticky by unibomber about 17x8 needing to have a +43 and up offset but if you guys have no problems then 35 is an ok offset
Old 09-08-2009, 06:31 PM   #13
vien
Member#: 221538
2003 wrx/ylw wheels
please do that would be great
Old 09-08-2009, 06:32 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
so far, there is no proof that low offset wheels will cause premature wear of the hub bearings. there are many guys on this forum running +35 and lower offsets for the past several years with no ill effects.
grippy monkey, for example, is currently running a +18 and has been at +35 or lower for many years.
Old 09-08-2009, 07:03 PM   #15
justinevan88
Member#: 181745
2003 Impreza WRX
I have a set of 16x7 +33 Volk TE37's and the only problem I'm having is rubbing in the rear. A roll and coilovers will be in order soon... But no bearing problems at all. And that's a low offset for a 7 inch wheel on Bugeyes.
justinevan88 is offline   Reply With Quote
Old 09-08-2009, 07:22 PM   #16
grippy monkey
Member#: 131067
your "stance"
sucks
true
+17
Like sleepy said a +35 in a 9" wheel is pretty much the lowest you'd wanna try unless you had some custom molded fenders like Shagon Wagon has. You'd still need to do alot of fender work to fit a 9" in +35 offset. I really like how a +42 or +44 17x9 fits a Wagon. You can run a 235/40/17 or 245/40/17 tire and roll the fenders flat with mild camber and call it a day. It's functional and looks flush also. I like people that push the envelope, but if you aren't familiar with this kind of stuff then I wouldn't even suggest trying something really aggressive on a wagon in the 9"+ and 30 offset+ range.
this wagon has 17x9 +44 wheels and wide 235/40/17 tires. It's perfectly flush
grippy monkey is offline   Reply With Quote
Old 09-08-2009, 07:35 PM   #17
vien
Member#: 221538
2003 wrx/ylw wheels
Originally Posted by grippy monkey View Post
true
+17
nice looks like the 5zigen zr20
Old 09-08-2009, 07:42 PM   #18
grippy monkey
Member#: 131067
your "stance"
sucks
kind of a newbie rule is you don't need to quote all the pics and stuff I just said right below me... it's a bit annoying. You can just point an arrow like ^ or simply post. People will know what you are talking about if it's right below me.
the wheels are WORK Emotion CR KAI
Old 09-08-2009, 08:32 PM   #19
vien
Member#: 221538
2003 wrx/ylw wheels
gotcha my bad^^^^^ so i would have to roll my fenders if i do a 17x9 with 35 offset
Old 09-08-2009, 08:44 PM   #20
vien
Member#: 221538
2003 wrx/ylw wheels
^^^ would this be a bad decision to run Work Emotion XT7 Wheel 18x8.5 5x100 with a +32 offset?
Old 09-09-2009, 12:07 AM   #21
grippy monkey
Member#: 131067
your "stance"
sucks
I guess I assumed you have a Wagon? or do you have a sedan? It does make a difference.
and yes.. you will need to roll your fenders pretty much whatever you run outside of the standard wheels approved for your car.
Old 09-09-2009, 12:46 AM   #22
vien
Member#: 221538
2003 wrx/ylw wheels
^^^ i have a sedan sorry
Old 09-09-2009, 01:45 AM   #23
Sleepy Wagon.
Member#: 132498
98 Lexus LS400/VIP
usVERSUSthem Krew!
Old 09-09-2009, 01:46 AM   #24
grippy monkey
Member#: 131067
your "stance"
sucks
^ well then...
You can go very low with the offset .. but it all depends on what you are going for? A car that handles well on the street for daily driving? A slammed ride with ultra low offset wheels? A track beast? A mix of a little of everything?
I personally run a 17x9 +17 with 225/45/17 tires, lots of camber, and the car is very low. This is 100% a street setup. If I were to track my car I'd switch out the wheels for some 17x9's in +30 offset and 255's. I can suprisingly push my car pretty hard on the street as it is though. For most people I'd recommend a 9" wide wheel in the +30 to +38 range. You can run a 235-255 tire with some fender work and useable amounts of camber. I've ran a 18x9.5 +22 with 255's also. It handled really well, but I wouldn't recommend it for daily driving to be honest. That's the only setup I've had that tracked really bad out on the freeway. You would get pulled quite a bit with lines in the road, and it made the car a two hand driver all the time. It was probably a combo of wide tires, low offset, camber, and big/wide wheels. I Don't notice that with my current setup with the 17x9's though. Like I said it did handle nicely though.
Something like the rota grid for example is a good option. you can get it in 18x9.5 +38 which doesn't require much fender work in the rear, and you could run a 255 width tire pretty easily. I am more of a 17inch wheels guy these days, but I always like the way my 18's looked previously. I would recommend you check out the Aggressive wheel thread in the member's gallery and start reading and researching alot. In the end you will have to make the decision on how much work you wanna do to the fenders, if you are going for looks or a performance setup, etc etc..
good luck
Old 09-09-2009, 02:35 AM   #25
Waking The Fallen
Member#: 125950
2010 BMW 135i/05 Sti
7.3 F350/06 Audi A4
WTF is up with the scoob with neon green rims man..Call that **** the hulk or something..
Waking The Fallen is offline   Reply With Quote
ap2 for 02-03 wrx sum0325 SCIC Private Classifieds 2 06-05-2010 02:04 AM
UTEC for 02-03 WRX and Ecutek for 02-03 wrx AWD_OWNS Private 'For Sale' Classifieds 12 04-29-2006 01:39 AM
Work Emotions with +43 or +47 offset for my 03 WRX 03twrx Tire & Wheel 4 06-08-2005 07:15 PM
Carbon Fiber Seat Panels for 02 - 03 WRX Part#CFI10-02 WRXerist Private 'For Sale' Classifieds 3 01-03-2005 04:13 AM
Will Tein S Tech Springs for 02-03 wrx fit on a 02 wagon? yeha Vancouver Impreza Club Forum -- VIC 7 07-21-2004 07:23 PM
