Old 09-07-2009, 05:54 PM   #1
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
Default i bought fp green turbo (pics inside
used ewg only paid $600 but it look like something is missing
maybe oil line i also wanted the specs on that turbo
i couldent find it on the fp website i can tell its 2.4" inlet
but its 7cm or 8cm.....need to know what i need to be able to bolt it on my 2004 sti thanks!!
davidsti1 is online now   Reply With Quote
Old 09-07-2009, 07:06 PM   #2
9d2TSi
Member#: 84852
2007 WRX TR
CGM
This is an oil only turbo so you'll need a water line fitting to connect your factory lines together. Maybe someone else can chime in on the size of the fitting, because I don't recall the size of mine off hand. It's pretty much bolt on otherwise. I had to remove the larger of the two uppipe support brackets as well since the size of the compressor housing made it impossible to mount it otherwise.
I do however have a banjo bolt and crush washers for the oil feed I can let you get, the factory one won't thread into that turbo.
9d2TSi is offline   Reply With Quote
Old 09-08-2009, 04:42 AM   #3
mystilexzero
Member#: 154674
2007 wrx
ugm
yea you got an oil cooled only fpgreen
mystilexzero is offline   Reply With Quote
Old 09-08-2009, 01:41 PM   #4
VIsubi
Member#: 187834
06 2.5i impreza
Red
thats a small exhaust housing but I bet it spools up pretty dam nquick is that a garrett T28...
VIsubi is offline   Reply With Quote
bought fp green pics inside davidsti1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-07-2009 08:18 PM
* Help identify this Turbo, FP red 20G?? PICS inside! Lam Newbies & FAQs 11 01-23-2009 04:35 PM
Turbo Deathmatch: FP Green turbo vs. Deadbolt SuperZilla Unabomber Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 08-12-2008 09:19 PM
Un Clipped FP Green - vs - Clipped FP Green turbo. Need your help guys. ProdriveRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-26-2007 07:27 PM
New FMIC (TXS) and FP Green Turbo pics... =) SONIC_03WRX North West Impreza Club Forum -- NWIC 8 11-22-2005 11:39 AM
