Old 04-30-2007, 07:01 PM   #451
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Originally Posted by hiremichaelreid View Post
Well now that I've read the entire thread and some associated links it's clear that this threads main thrust is the head gasket problems on 2.5 L EJ25 engines, regardless of vehicle.
My take is that a bad head gasket design is the source of the problems. It appears this affects model year 1996 (or 95?) to 1998 or 1999 phase 1 DOHC engines the worst (with internal leaks). Appears to be a little better (external leaks) with 1999 or 2000 to 2002 phase 2 SOHC engines.
Actually, what is not really stated here is a block change over the years as well. The phase-2's and up had support ribs from the external walls of the block to the top of the cylinders. The phase-1's didn't. This allowed the cylinders to wiggle around which "wore a hole" into the HG.
Using later model HG's helped this, but did not totally fix it.
I finally fixed it by using a rebuilt STi 2.5L SB and my original DOHC heads.
Old 05-01-2007, 01:20 PM   #452
LewBob
Member#: 19702
2002 GT Wagon
"This problem, and Subaru's lack of response to it, have soured me on the purchase of newer Subarus. I bought my wife's 1999 Legacy L w/ 2.2 L engine in 2000 knowing that even then there were "rumors" about 2.5 L engine reliability. I'm REALLY glad we went with the wimpy 2.2 L. I'm disappointed that we had to replace the 4EAT this week at 100 k miles.
I used to think that I'd buy a new or slightly used Legacy GT some day. Now if I got a Subaru it'd probably be a 98-99 Legacy L w/ 2.2 L and 5MT. And I'd avoid the dealerships in favor of a local independent Subie specialist."
Michael, A used GT might still be okay, you just need to find one that has had the head gasket replaced under warranty. I am thinking of selling my GT and getting a RAV4 V-6. I would hope that having all my service records would make it a preferred used car. Lew
LewBob is offline   Reply With Quote
Old 05-02-2007, 06:17 PM   #453
hiremichaelreid
Member#: 147029
My understanding is that fixing it might buy time, but that the HG will eventually go again (perhaps 50-100 k miles, but could be any mileage?). Or is this just for the Phase 1 motors, and the Phase 2 motors can be fixed completely ?
hiremichaelreid is offline   Reply With Quote
Old 05-02-2007, 08:20 PM   #454
LewBob
Member#: 19702
2002 GT Wagon
I don't have a definitive answer for that, but the design of the gasket was changed, so I would hope it would go longer than the 60,000 I got on the original. Lew
Old 05-05-2007, 11:19 PM   #455
driftingouttosea
Member#: 127819
89 GL Hatch
W
MY-96
Miles - 151K
2.2l
Trans 5-spd
no problems
driftingouttosea is offline   Reply With Quote
Old 05-07-2007, 05:31 PM   #456
LewBob
Member#: 19702
2002 GT Wagon
Guys, I just sold my 2002 GT and bought 2007 RAV4. Thanks to everyone here who has given me help with mods and fixes. This is a great website.
Anyone know any similar sites for Toyota owners? (I splurged and got the V6 for driving in the mountains. It is supposed to get good gas mileage if you don't drive it hard. I hope that is true). LewBob
Old 06-20-2007, 07:29 AM   #457
engineer&mechanic
Member#: 151916
1998 Outback
green
Charlie-III Where did you get the STi short block? Any particular problems lining things up? Do you still have the piston rattle? Did you use the stop leak additive with the new block? (I hate that stuff)
engineer&mechanic is offline   Reply With Quote
Old 06-26-2007, 12:15 AM   #458
engineer&mechanic
Member#: 151916
1998 Outback
green
Default Open deck - closed deck
Did some research on the subject of why these head gaskets fail: Found that the 2.5 liter engine block is/was designed with an open deck. The cylinders just stick up into the air. I have never seen such a design. Cylinder blocks have a solid deck with holes for circulation of coolant and oil. It is of no surprise to me that the head gaskets fail. There is much vibration and when the cylinders are unsupported at the block/head interface, the gasket will fail. The failure will be earlier where the sealing area is narrow. When internal combustion engines were first built, the seal between the block/head was a big problem. Many engines were built with the head an integral part of the block. It makes for a less expensive casting when the deck is left open.
Old 07-20-2007, 06:09 AM   #459
95AWDrifter
Member#: 132226
1995 Legacy L
Wintergreen Metallic
MY95 LSI
157,374
M/T
Runs like a champ everything is original with the motor and trans (internal) that is. No leaks good compression, my shifter is wobbles in gear but i have the bushing to cure it. other than brakes and serp belt its great *knock on wood* ran into problem with my exhaust flange cracking apart between the mid-pipe & cat-back..... gotta love launches and engine twist! anywho i just cured it with a custom bent flowmaster dumped side pipe exit.... growls like a monster!
95AWDrifter is offline   Reply With Quote
Old 09-19-2007, 06:59 PM   #460
BakedPotato
Member#: 159677
1996 Legacy Outback
Default head gaskets
MY-96
Miles-153,000
Trans- Auto
Name-BakedPotato
I've been told it's got a HG leak but I don't see the classic symptoms (e.g. low coolant level with no external leak). It does leak oil though, can't find the source of that leak.
BakedPotato is offline   Reply With Quote
Old 09-21-2007, 10:34 AM   #461
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The classic symptom is overflowing coolant from the reservoir after you have run hard for a while. If you want to see action try flooring it while going up a long hill. Then pull over and look for bubble from the rad into the overflow.
Also take a good look at the bottom of the overflow. If there is an abundance of black goop...
Oil Leaks:
cam seals
crank seal
rear separator plate
rear main seal
cam cover gasket
cam cover bolt
spark plug gasket
oil pan
oil drain if you reused the crush washer or didn't use one
All these leaks are a design feature to prevent rust in your engine bay.
linsavy is offline   Reply With Quote
Old 09-21-2007, 04:24 PM   #462
Kapex
Member#: 159614
2006 Evo IX MR
Graphite Gray
MY97
~113k miles
2.2L
Auto Tranny
No problems.. the only thing is that there's a quiet clicking noise when I'm accelerating.. doesn't happen while I'm standing still and revving though.. any idea what this could be? I recently had everything looked at and fluids changed etc. and the mechanic didn't seem to think there was a problem. It's just sort of annoying.
Kapex is offline   Reply With Quote
Old 09-21-2007, 04:47 PM   #463
linsavy
Member#: 11620
The 2.2l doesn't have the headgasket problem. Its the most reliable motor subaru made in the 1990s.
The clicking is OK, there is more clearance in the valves so they make more noise. Not much you can do about it unless you spend big $$ to reshim the valves. Just roll up your window and turn up the tunes. The EJ motor will never win any prizes for quietness or smoothness.
Old 09-21-2007, 07:04 PM   #464
coolbreeze
Member#: 91599
2000 outback ltd wgn
"birch"
MY 96 outback 2.5 about 150k with no problems(fingers crossed)
coolbreeze is offline   Reply With Quote
Old 09-24-2007, 08:53 PM   #465
doomonu
Member#: 70155
1999 Legacy 2.5 GT
Brilliant Silver Metallic
MY-99 2.5L
Miles- ~164,000
Trans- 4EAT
Age-8 years
Name-doomonu
doomonu is offline   Reply With Quote
Old 09-25-2007, 12:13 AM   #466
Dumbscout
Member#: 126393
1997 Impreza OBS
Blue and Gold
MY - 97
miles - 156k
5 speed tranny
HG went today
Dumbscout is offline   Reply With Quote
Old 10-12-2007, 09:30 AM   #467
96legacy28
Member#: 140158
1996 Legacy
Green
my- 96 ls
miles- 189,000 and still going
5 spd tranny
did camseals, rear main, valve covers, oil pan, new clutch and it runs smooth and quiet
96legacy28 is offline   Reply With Quote
Old 10-12-2007, 11:38 AM   #468
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Well, with the earlier EJ22s, it's hydraulic lash adjusters, and it's actually a pretty simple DIY and about 100 bucks in parts to fix it.
Mine have gotten noisy again. It's too bad, I was enjoying the smooth purr it used to give me
Wiscon_Mark is offline   Reply With Quote
Old 10-12-2007, 05:08 PM   #469
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Still haven't blown my '98 GT. 120k now...
did get a CEL yesterday, so need to figure out what that is.
monovich is offline   Reply With Quote
Old 10-13-2007, 03:27 AM   #470
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default 3 blown head gaskets...
...2 do to the dang purple bottle that sprays this funny type of gas (one time in a race and one time on beltway-495) ...1 do to removing this purple bottle for some aggressive cams, aggressive torque convertor and aggressive throttlebody...instead of breaking it in properly...tried to play with a ZR-1 and lost! Engine kapputt!
That's my horror stories with the '99 GT
CRAZY KEN
BTW, I sold it in 2003 and it didn't even have 100,00 miles on it.
CRAZY KEN is offline   Reply With Quote
Old 11-03-2007, 02:14 PM   #471
crAppAchic0
Member#: 125253
2000 Impreza 2.5RS
Sedona Red Pearl
'98 Legacy GT DOHC 2.5, 5 spd; blown HG @ 98K; replaced and now @ 146K and still good.
'99 Legacy L 2.2 SOHC 4EAT; blown when I bought it @90K (yeah, I wish I read this thread before I got it) - replaced HG (no resurfacing) and ran fine for about a year - then again @ 111K - still trying to figure out what's cheapest/quickest to do. Not sure if anything's cracked or not, but coolant is in oil in the oil pan.
crAppAchic0 is offline   Reply With Quote
Old 11-07-2007, 11:19 AM   #472
gforce
Member#: 130004
'97 Supra (Maria)
'08 STi, '03 Zx6r (Luis)
my- '98 legacy gt ltd
miles- 150k and change
Auto
HG and block on the way out
Gf's legacy 2.5 gt beater just started overheating and after a new timing belt and water pump the mechanic thinks the hg is on the way out....and saw hairline cracks on the block.....anyone wanna provide assistance on what short blocks i can buy from another model subie maybe in the near future? She luvs the car for what it is and wants to keep it so we are lookin for ideas......we both wanna swap a ej25 from the sti but $$$ and time isnt in the cards lol
gforce is offline   Reply With Quote
Old 11-12-2007, 09:39 AM   #473
Kickerz
Member#: 14149
1999 Legacy SUS
Black Cherry/Silver
99' SUS
2.5 L
4EAT
176K
Just blew the passenger side HG. In for repairs today. $700 parts and labor.
Kickerz is offline   Reply With Quote
Old 11-22-2007, 03:45 PM   #474
WJM
Guest
Member#:
My 1996 Outback blew at 200k. Original engine.
Did both sides at the same time.
Eventually all EJ25D's will eat atleast one set...usually the originals. Once the new metal ones go in...zero problems.
Old 11-27-2007, 03:12 AM   #475
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Sorry, haven't been on here much lately.
The STI SB is a modded block from Crawford with higher CR pistons.
No issues bolting things up.
Used newer version Subaru HG's.
Heads are redone 2.5L DOHC ported and polished by COBB Tuning with COBB street cams, upgraded springs and light weight spring retainers.
No "stop leak" used in the new engine.
Are there any beaches in Hilton Head I can drive my car on? Silver_04_WRX_SC South East Region Forum 7 05-25-2010 09:09 PM
WTB Mass Area Any subaru with blown head gaskets 0202Subwrx Private 'Wanted' Classifieds 0 04-01-2008 11:23 AM
those that have driven both 2nd gen Legacy turbo and ~2002 WRX lag Legacy Forum 9 10-07-2005 09:05 AM
Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? whtlegacy Brakes, Steering & Suspension 2 06-24-2004 02:38 PM
Any 2nd gen MR2 owners here? Dealer Xing Tri-State Area Forum 7 12-09-2002 08:55 AM
