Old 11-27-2007, 03:29 AM   #476
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
98 GT 105k miles
Burning coolant
Does anyone have the part numbers for everything that needs to be replaced? I have a family member that is a mechanic and will do the work for cheap. He just did my clutch less than 3k ago.
subiekid is offline   Reply With Quote
Old 12-11-2007, 04:46 PM   #477
HPP
Member#: 166175
My 98 Outback
2.5L
4eat
94k miles
No blown gasket yet.
But the tranny or differential or something is shuddering during sharp turns or when slipping on snow. Any ideas? I'm going to change the fluids and see what happens.
And should I be expecting HG issues for sure? I will be doing the timing belt by mid spring time probably, and am wondering if I should just pull the engine and do HG's at the same time?
Originally Posted by engineer&mechanic View Post
Did some research on the subject of why these head gaskets fail: Found that the 2.5 liter engine block is/was designed with an open deck. The cylinders just stick up into the air. I have never seen such a design. Cylinder blocks have a solid deck with holes for circulation of coolant and oil. It is of no surprise to me that the head gaskets fail. There is much vibration and when the cylinders are unsupported at the block/head interface, the gasket will fail. The failure will be earlier where the sealing area is narrow. When internal combustion engines were first built, the seal between the block/head was a big problem. Many engines were built with the head an integral part of the block. It makes for a less expensive casting when the deck is left open.
Honda blocks are open deck, and do not have HG issues.
HPP is offline   Reply With Quote
Old 12-11-2007, 04:49 PM   #478
snowone
Member#: 6035
05 92-X Saabaru
87 VW Westfalia
I like Mike's write up on the headgasket issue here, good high level overview from one of the best local subaru specialists
snowone is offline   Reply With Quote
Old 12-24-2007, 03:50 PM   #479
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
98 lagacy gt wagon
124,xxx miles
mt
i have had no problem with my engine as of yet.
gtbensley is offline   Reply With Quote
Old 12-28-2007, 04:31 PM   #480
jonm
Member#: 107704
97 Outback Limited
90k miles
5MT
After a year of poor gas mileage and unexplainable oil consumption, my wife's Outback decided it wanted to keep it's oil in the radiator and it's coolant in the oilpan! Bugger! Thankfully triple-A's extended tow service (through my brother-in-law) works at the top of a mountain, in 23F weather, with disappointed kids, on Christmas day.
A swap from the 2.5 to a 2.2 looks like the cheapest option.
At least my 85 GL works!
jonm is offline   Reply With Quote
Old 12-30-2007, 12:41 AM   #481
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
'99 GT, 96,000 miles and counting. My '96 also has yet to blow an HG last I heard.
SLegacy99 is offline   Reply With Quote
Old 12-30-2007, 10:34 PM   #482
SiouxBe1
Member#: 157247
1991 Legacy L+AWD BJ
Phase I MY'91 BJ 2.2l SOHC 254,000 original Owner miles Head-gaskets blew Temp. outside 7 degrees F ,altitude 5,200 feet
SiouxBe1 is offline   Reply With Quote
Old 12-31-2007, 02:22 PM   #483
wallytoo
Member#: 139836
95 legacy L wagon
member, NHTOA
Originally Posted by 95AWDrifter View Post
MY95 LSI
157,374
M/T
my shifter is wobbles in gear but i have the bushing to cure it.
i'm having the same problem. showed up at about 214,xxx miles. a bushing, huh?
wally
wallytoo is offline   Reply With Quote
Old 01-01-2008, 04:32 PM   #484
unirevolt
Member#: 167972
97 Legacy/Impreza
Mine: 97 Legacy GT
158xxx miles
Blown gasket
Parents: 98 Legacy Outback
125xxx miles
Blown gasket
unirevolt is offline   Reply With Quote
Old 01-01-2008, 08:38 PM   #485
Gasaraki
Member#: 64090
2008 Legacy GT
Unhappy
97 Legacy 2.5 GT
Current miles: 148950
Blown Gasket at ~103000
Gasaraki is offline   Reply With Quote
Old 01-02-2008, 03:46 AM   #486
RusEvo
Member#: 82000
1995 Legacy
95 Legacy TX-S
2.0 Litre N/A
254,000 Kilometres
No sign of a problem
RusEvo is offline   Reply With Quote
Old 01-03-2008, 06:47 AM   #487
jeff_x
Member#: 164305
1998 Legacy OBW
4T6 Mica Ruby Prl
MY-98 OBW
Miles-163,xxx
Trans- 4EAT
Eng- EJ25D
Name-Jeff_X
Cracked block! Fortunately all other services done on schedule.
Remedy: New used shortblock. Machined original heads (C-Tech Performance). New H gaskets, belt, tensioner, waterpump, seals, etc.
This engine is one hothouse flower, isn't it? I still can't bring myself to hate it, though. Meanest sounding sub engine I've ever owned.
jeff_x is offline   Reply With Quote
Old 01-04-2008, 09:50 AM   #488
Kickerz
Member#: 14149
1999 Legacy SUS
Black Cherry/Silver
175,xxx
blown head gasket
coolant caused a main journal to wipe and caused one cylinder to score. In the market for a running 2.5 out of any compatable Subie. I just want to get the car running and send it down the road. Its been a good car in all fairness....time for something with a touch more power....300c w Hemi
Kickerz is offline   Reply With Quote
Old 01-16-2008, 11:16 PM   #489
blackmedal
Member#: 89475
1999 Legacy GT
Quick Silver
99 LGT
EJ25D
Purchase: 78xxx (9/05)
Now: 105xxx (1/08)
Manual
Car was purchased, heater didn't work, thermostat, and soon after, the head gaskets were replaced. I assume the car had a blown head gasket while on display for sale, shady business. She runs smooth as hell now.
blackmedal is offline   Reply With Quote
Old 03-21-2008, 08:16 PM   #490
MinnGreenGT
Member#: 103019
1992 Legacy Turbo
Burnt 'shmellow/WhiteRust
MY 98 Legacy Outback "Limited"
EJ25D
Prior Owner Replaced HG @ 165k miles
Currently @ 212k miles... and needs another HG
Just found oil in the coolant overflow
MinnGreenGT is offline   Reply With Quote
Old 03-22-2008, 12:38 AM   #491
Integra663
Member#: 175235
1997 Legacy GT
1997 Legacy GT [Black Sunshine]
EJ25D
5-Speed
* Previous Owner had HG's replaced at 92,### by general mechanic shop (not sure which HG's used...)
* I Purchased at 97,###
* Had HG's replaced at 111,### at Subaru Dealer (who used the OE 610's) last winter
* Just this week I have oil in the coolant and coolant in the oil at 127,###
I really want to love this car, but...DANG....
Earlier tonight I saw a photo of the open deck design of these blocks. Does not look like the cylinders would be very stable. Does anyone know how much to have block modified to close the decks?
Looks like a blemish on an otherwise (mostly) decent record....
Integra663 is offline   Reply With Quote
Old 06-25-2008, 05:20 PM   #492
subiekid
Member#: 25516
Is there a list of parts that need to be purchased before doing the HG on a 98 GT?
HG Part #: 11044AA610; also thinking of the coolant additive.
Anything else?
I might just sell this car and my 95 project car and get an STI.
Old 06-28-2008, 02:28 PM   #493
huckedup16
Member#: 20612
2012 Impreza Sedan
99 Legacy GT
4eat
187k
Oil in Coolant, crappy gas mileage, bogs down on occasion.
Also, oil leaks from both valve covers, main cam seal, crank seal, and timing belt is oil soaked...
...oil decided to leave engine bay through driver side wheel well...leading to no brake pads and some lovely burnt oil scented rotors...
time to sell it.
huckedup16 is offline   Reply With Quote
Old 06-28-2008, 11:46 PM   #494
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
99 LGT, 101k miles. Got home yesterday and I was leaking oil bad which was then burning off and smoking. Coolant is fine. All signs point to cam seal.
Edit: Nevermind, it was bum oil filter/seal. Thankfully no damage was done to the engine.
Old 08-07-2008, 11:35 AM   #495
subarusleuth
Member#: 186351
Default News investigation
Subaru of America is saving millions of dollars by responding inadequately to known problems with leaking head gaskets in its 2.5 L 1999-2002 engines. Information is being compiled for publication of newspaper and magazine reports and a class action lawsuit in connection with WWP-99, Subaru’s service bulletin, which acknowledges the external coolant leak problems.
In transparent, profit-motivated efforts, Subaru is hiding behind a smoke screen with a band-aid coolant approach to pushing engines beyond the 100,000 mile mark, at which time warranties expire and the ‘stop leak’ coolant creates critical damage to engines. This product stops up radiators and causes engines to overheat. The number of Subaru engines with recurring head gasket and overheating problems needs to be documented, and brought to the attention of the public and National Transportation Safety Board.
Subaru’s inadequate Customer Service response to these costly head gasket repairs is turning many loyal Subaru owners away. Subaru owners with leaking head gasket and overheating problems may send their reports and comments regarding such problems to: [email protected]. Please include your e-mail and telephone number.
I purchased a Subaru 2001 Forester after doing extensive research to find a car with low maintenance costs, longevity, good fuel economy, and safety. My Forester has been the most expensive vehicle I’ve ever maintained. This car began having overheating problems as soon as I purchased it. The radiator was replaced. Soon after, I received the recall for adding special ‘coolant’ to postpone the ultimate damage caused by leaking head gaskets. This car leaked incessantly and I was always adding coolant. In 2007, my Forester began smelling hot. $3,000 later, a number of repairs were made including a new water pump, oil cooler, timing belt, and head gaskets. In June 2008, coolant was still leaking. My Subaru overheated, leading to a complete meltdown of the engine. The repair bill is $6,000-$7,000.
Please help me in documenting head gasket and overheating problems and taking action to make Subaru pay for its irresponsibile handling of these problems.
subarusleuth is offline   Reply With Quote
Old 08-07-2008, 09:27 PM   #496
SLegacy99
Member#: 117504
2015 WRX Limited
Lighting Red
If you get em to pay for the failing speedos, let me know.
Old 08-07-2008, 10:46 PM   #497
iluvdrt
Member#: 46248
82 Brat
Tan
my98
4EAT
miles 197549
pushing coolant
2x headgasket replacement
replaced w/ STi gaskets takes a beating keeps on ticking. driven VERY hard w/ manual shifting at auto-x.
HG's or not, I wouldnt trade it, (unless it was for somehting boosted with the stars)
iluvdrt is offline   Reply With Quote
Old 11-14-2008, 04:04 AM   #498
aliasgace
Member#: 194281
Hello,
I'm looking to buy a 99 legacy outback wagon 30th edition, with 74,821 on it. DOHC H4 PFI 2.5. After reading all of this I am a bit leary. Do you think I should request the HG is changed before I purchase it or will that just prolong the process until it blows? Should I just look for another year? Someone ran into my car and I need to make a reasonable purchase without spending over 10k and this is at 7400 so I figure it would be a good deal if it runs at least 50k.
Sorry to hear of all these troubles. Subaru have always seemed really reliable to me.
aliasgace is offline   Reply With Quote
Old 11-14-2008, 06:47 PM   #499
Black Sunshine
Member#: 183617
1997 Legacy
'97 Legacy L
2.2L SOHC/ATX
181k miles
Good head gaskets
This has been the toughest car I have ever owned. I put 100k miles on it in three years. I replaced the cam and crank seals at 160k, I also went ahead and did the timing belt and water pump. Only took about an hour. Despite the ATX mine has spent alot of time over 4k rpms. Most of my mileage has been pizza delivery. I bought it from a retired mail carrier, so the second part of it's life was mail delivery. It was a program car when she bought it, which is code for rental car. I want to lift it and do a WRX conversion on it, but I think I should replace the *original* struts first.
Black Sunshine is offline   Reply With Quote
Old 11-15-2008, 05:02 PM   #500
SpongeBob87
Member#: 194432
Default Blown head gasket
97 Legacy O/B
Auto
107K
SpongeBob87 is offline   Reply With Quote
Are there any beaches in Hilton Head I can drive my car on? Silver_04_WRX_SC South East Region Forum 7 05-25-2010 08:09 PM
WTB Mass Area Any subaru with blown head gaskets 0202Subwrx Private 'Wanted' Classifieds 0 04-01-2008 10:23 AM
those that have driven both 2nd gen Legacy turbo and ~2002 WRX lag Legacy Forum 9 10-07-2005 08:05 AM
Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? whtlegacy Brakes, Steering & Suspension 2 06-24-2004 01:38 PM
Any 2nd gen MR2 owners here? Dealer Xing Tri-State Area Forum 7 12-09-2002 07:55 AM
