Old 12-19-2009, 10:26 PM   #526
gsteclipse33
Member#: 72859
166k 5spd 98 legacy gt wagon original head gaskets and full jdm front end headlights grill foglights side markers
gsteclipse33 is offline   Reply With Quote
Old 11-11-2010, 11:02 PM   #527
richygot1
Member#: 181333
Default 2.2 Hg
MY 972.2 LSapprox 200Kreplacing cam, oil pump seals and timing belt.Should I replace head gaskets? are there any recommended?ThanksRich
richygot1 is offline   Reply With Quote
Old 03-20-2011, 03:08 PM   #528
subierod
Member#: 259140
I have recently been having over heating problems with my 98 lgt. So far the thermostat water pump and radiator have been replaced. Somehow there is still air getting in the system. Any opinions
subierod is offline   Reply With Quote
Old 03-20-2011, 07:42 PM   #529
soloz2
Member#: 260128
2014 WRX 5 Door
Ice Silver Metalic
My 98 Outback just blew the headgaskets. 216k
soloz2 is offline   Reply With Quote
Old 03-21-2011, 01:26 PM   #530
brakemans
Member#: 22859
2005 Legacy GT
My 99 Limited blew a head gasket at 147k miles while I was doing wheelies in an empty Just For Feet parking lot full of snow a couple of years ago. I had my brother replace it for me and it's never been the same since. Intermittent overheating and such. I traded it for my wife's car.
I heard the dealerships were using in WRX head gaskets to replace those that were blown? Anyone can confirm that?
brakemans is offline   Reply With Quote
Old 12-13-2011, 08:59 PM   #531
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Just blew my second gasket @210k. This time though, I'm swapping in my JDM EJ20 block and heads, until I have time to do the wiring and pop the turbo on there.
Speedwagon is offline   Reply With Quote
Old 12-15-2011, 12:38 PM   #532
legy the legacy
Member#: 281188
MY-96 bd
Miles-172,345
Trans- auto
original and No problems =)
legy the legacy is offline   Reply With Quote
Old 12-15-2011, 06:51 PM   #533
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Originally Posted by legy the legacy View Post
MY-96 bd
Miles-172,345
Trans- auto
I'm guessing you have a 2.2L engine though. The HG issues were mostly focused on the 2.5L engine.
Wiscon_Mark is offline   Reply With Quote
Old 03-15-2012, 02:03 PM   #534
twrenwick
Member#: 313641
MY-2000 Legacy GT Wagon
Miles-170,000
Trans- Auto
Age-12 years
Name-twrenwick
Left side HG started leaking, ~$1500 to repair, plus had a few other things replaced while it was opened up.
twrenwick is offline   Reply With Quote
Old 07-31-2012, 04:15 PM   #535
cracky
Member#: 181399
05 STi
so a 98 rs is not a good idea for a beater?
cracky is offline   Reply With Quote
Old 08-11-2012, 09:11 PM   #536
DohcEj22e
Member#: 289011
My 2.5 had a head gasket leaking issue & then it was repaired but the repairs came too late. The constant overheating caused the internal bearings to break down & rod #3 punched its way through the top of the block, necessitating my need to create a hybrid (25D heads/22E block). I did it because I never wanted those previous issues to ever happen again.
DohcEj22e is offline   Reply With Quote
Old 09-20-2012, 08:39 PM   #537
Aashaw
Member#: 332805
2013 Legacy 2.5 prem
white
I got the extended warrenty cause i got bad luck.
2013 legacy 2.5
1000 miles
Aashaw is offline   Reply With Quote
Old 09-22-2012, 07:03 AM   #538
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
Outback 1 owned since new:
MY-1997
Trans manual
Head gaskets went at ~275000 kms. caught early when oil showed up in antifreeze.
Head gaskets replaced. Now at 380000 kms and running strong.
Outback 2 bought used.
MY- 1997
Trams manual
Head gaskets blown when I Bought the car with 260000 kms. Replaced the head gaskets right away. At 290000 something bad and noisy happened to the crank. I suspect the previous owner had driven for a while with the head gaskets swapping oil and antifreeze and bearing damage had begun. Replaced engine with jdm turbo ej20k.
CBXJ is offline   Reply With Quote
Old 10-05-2012, 04:11 PM   #539
tunedbysti
Member#: 334146
1998 Honda Accord LX
2000 Chevy Silverado 1500
MY-99
Miles-126k
5MT
Name-tunedbysti
No Problem
tunedbysti is offline   Reply With Quote
Old 11-10-2012, 11:44 AM   #540
Edmund101
Member#: 337511
Default Head Gasket
My-04
Miles - 129,000
trans - Auto
Age - 8 years
Name Outback
Head gasket obviously a problem at about 125,000 miles - rapid overheating and a strong smell. It may have been failing much earlier because that "sweet smell" was present for a very long time - as early as 40,000 miles. we always had it serviced at the Subarau dealer so I always assumed that the specified coolant additive was used.
Edmund101 is offline   Reply With Quote
Old 11-14-2012, 06:52 PM   #541
burkart
Member#: 305000
2005 Legacy GT 5MT
Bright Silver Metallic
i dont know if i replied to this yet. but
YES
my LGT blew them at 60k miles and luckily was covered. the service appt was $2,000 even with the warranty.
cylinders 2 and 4. took three weeks to get the car back.
burkart is offline   Reply With Quote
Old 11-21-2012, 12:31 AM   #542
Wagon Fodder
Member#: 332286
1997 Legacy Wagon
MY - 2011
Miles - 210,xxx
Trans - 5mt
Age - 15 years
HG was replaced at 160k as preventative maintenance. Good to go. EJ22 ftw.
Wagon Fodder is offline   Reply With Quote
Old 11-21-2012, 06:50 AM   #543
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Are you a time traveller? It's 2012, and you've already got 210,000 miles on your 15-year-old 2011 car?
Old 12-23-2012, 06:24 PM   #544
05wagon
Member#: 96293
05 Forester XT
AW
I'm considering the purchase of an '03 Legacy wagon with the 2.5 non-turbo... From what I've read the '03 supposedly isn't affected (according to Subaru). I don't see any signs of external HG failure and the coolant looks clean, the car's got 130K on it... I should be in the green as far as HG is concerned, no?? That's my only real issue with the car, it looks to be in great shape! Any input would be greatly appreciated from 03 owners or those knowledgable
05wagon is offline   Reply With Quote
Old 12-30-2012, 12:20 AM   #545
EnderDragoon
Member#: 300176
MY - 1997
Miles - 220k
Trans - 5MT
Age - 15
The previous owner said Subaru had an engine recall and went in for an engine swap at 40k miles (I purchased her at 80k miles). Therefore only 180k on this engine but zero issues with the head gasket, or really anything with the car. As far as things that have been replaced that wore out on their own (stuff I didn't break) I've replaced the radiator, alternator, a set of front wheel bearings and the driven gear that turns the VSS. Funny thing about that is the shop I took it to tore the trans apart to get to it and they said all the gears were in perfect condition as of 170k miles.
By 2003 they changed to the multilayer HG that weren't prone to the common HG failures of the EJ25s I believe. I cannot recall what year that went into place however so I hope someone else can corroborate this.
EnderDragoon is offline   Reply With Quote
Old 01-01-2013, 10:29 AM   #546
buddy110
Member#: 210469
just bought an oo with 169K. I'm considering pulling the motor and changing the HG's now as a precaution. It needs a timing belt anyway...
buddy110 is offline   Reply With Quote
Old 01-17-2013, 10:40 PM   #547
Soupysuby
Member#: 262052
2001 Legacy
Wintergreen
Got an 01 automatic L sedan with a blown seal somewhere, dripping oil slightly and hitting the exhaust at the Y pipe when I drive, anyone got a fix for it? Or should I just let it be bc it only seems to leak about a half a quart every 3000?
Soupysuby is offline   Reply With Quote
Old 01-19-2013, 11:06 AM   #548
98wag
Member#: 51823
98 legacy GT
blk
98 gt wagon first blew at 170, I didn't do the work and it only lasted to 210, I did the work this time and replaced it with the six star gaskets. 223 thousand now and looks good.
98wag is offline   Reply With Quote
Old 01-21-2013, 08:40 PM   #549
fenrir1
Member#: 344373
2006 Forester XT
Steel Grey Metallic
no CEL light but i think the head gasket is leaking. what does that say?
fenrir1 is offline   Reply With Quote
Old 01-21-2013, 09:32 PM   #550
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
What does what say?
Are there any beaches in Hilton Head I can drive my car on? Silver_04_WRX_SC South East Region Forum 7 05-25-2010 08:09 PM
WTB Mass Area Any subaru with blown head gaskets 0202Subwrx Private 'Wanted' Classifieds 0 04-01-2008 10:23 AM
those that have driven both 2nd gen Legacy turbo and ~2002 WRX lag Legacy Forum 9 10-07-2005 08:05 AM
Will a 1st gen Legacy rear sway ('92) fit a 2nd gen Legacy ('99)? whtlegacy Brakes, Steering & Suspension 2 06-24-2004 01:38 PM
Any 2nd gen MR2 owners here? Dealer Xing Tri-State Area Forum 7 12-09-2002 07:55 AM
