Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 09-08-2009, 03:44 PM   #1
spooling impreza
Member#: 161782
Default obd 2 port
the other day i took my car to auto zone to check the codes it was throwing and now my obd 2 plug isent working can someone help me out and tell me what i should do frist so i can fix this asap thanx justin
spooling impreza is offline   Reply With Quote
Old 09-08-2009, 03:46 PM   #2
anothernord
Member#: 193703
I think we'll need some more information from you. Was the code reader not reading the code? Is the port not getting power? It could have been a bad reader on their part.
anothernord is offline   Reply With Quote
Old 09-08-2009, 04:39 PM   #3
spooling impreza
Member#: 161782
i know the reader was working because right after they tryed it on my car they used it on a nother car and it was working idk if its getting power how do i check that just turn the key on and see if there is power there with a voltes meter
Old 09-08-2009, 04:45 PM   #4
scprs
Member#: 172359
2005 STi
ive been through this before and for somereason the code reader they use wont work with subarus (at least both of mine). Then I took it to work the next day (at subaru) and they could see it fine.
scprs is offline   Reply With Quote
Old 09-08-2009, 09:06 PM   #5
spooling impreza
Member#: 161782
ok thanx i'll try that i appreciate the advice alos what if they cant read it is there like any fuses in the wires that go to the obd 2 port and they can be blow thanx Justin
Need a how to on removing the OBD 2 port for install of psi 3 harness? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-15-2003 12:39 AM
Swaps and obd-1/obd-2 issues Cert Subaru Conversions 15 11-19-2003 11:17 PM
has anyone connected to their OBD-II port? FormerSubTech Normally Aspirated Powertrain 11 11-30-2001 11:20 PM
OBD-1, OBD-2, Obi Wan Kenobi What? chyisan Technical Forum Archive 1 09-10-2000 12:31 AM
