Old 09-08-2009, 05:20 PM   #1
yurka89
Member#: 221900
Default please delete
please delete
yurka89 is offline   Reply With Quote
Old 09-08-2009, 05:32 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
245/40/18 will get you more rubbing issues than a 255/35/18 will. 245/35/18 or 255/35/18 would be better sizes to run.
don't worry about the hubs. if you're worried about your struts, find better springs.
Old 09-08-2009, 07:15 PM   #3
grippy monkey
Member#: 131067
your "stance"
sucks
like nhat said you will not want a tall tire like the 245/40/18. I believe someone is on springs and 18x9.5 +38 Grids on a 08+ WRX already with 235's. I think a 18x9 with a 245/35/18 would be a good fit. You will probably need a rear fender roll only. Get some camber bolts if you don't already have some so you can have some camber dialed in. It shouldn't take anything extreme to make it work.
grippy monkey is offline   Reply With Quote
Old 11-02-2009, 10:30 PM   #4
Rhymenocerous
Member#: 228765
did you try this setup and if so have you run into any issues?
Rhymenocerous is offline   Reply With Quote
to do or not to do, mbc plus 1 psi? DubURX05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-13-2005 02:27 PM
to do or not to do? WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-07-2004 03:39 AM
Whiteline Rack Bushings...to do or not to do? DDMan Brakes, Steering & Suspension 5 12-19-2002 12:47 AM
