Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 05-07-2002, 03:02 PM   #1
SPeeDSiN
Member#: 4667
Black (well kinda)
Default Update on P5 Turbo
Again, thanks for everyones help.
Don't know if anyone cares, but my brother found the source of the problem.
After we talked for a while about problems with MAFs, he went to inspect his. To his suprise, his air filter had completely folded in on itself and clogged the intake.
Now, instant boost!!! No stumbling!!!
He says the car can break traction in first gear just getting on it. Those P5s are really lightweight.
Jewbaru and I talked for a while yesterday and also discovered that he has the vacum source for the FMU coming from before the TB. He hasn't fixed this yet (hard head) but other than that it seems to be running great now. Thanks jewbaru!
Next problem: Oil in the intake pipes!!! He has a brand new T25, but we both are coming to the conclusion that the seals are bad. Anymore suggestions?
SPeeDSiN is offline   Reply With Quote
Old 05-07-2002, 03:18 PM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Oil in the intake is relatively normal in a boosted car. High RPM, full boost gives you a bit of valve float and you'll start smoking out the head.
The fix: An oil catch can that's higher or equal to the valve cover.
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 05-07-2002, 03:19 PM   #3
Jewbaru
Member#: 1994
2013 Impreza WRX
Oil in the intake is caused by a few things:
Bad piston rings, causing blow by,
Over filling the oil pan,
Bad oil return from the turbo,
the Turbo sucking oil into the intake from the breather hoses,
maybe a bad turbo (they usually dump in the exhaust too, and he'd see blue smoke).
Jewbaru is offline   Reply With Quote
Racecomp Engineering pre-order-Updates on swaybars and camberplates dalesalignment&brake VIC Vendor Classifieds 62 07-23-2010 02:06 AM
Update on t3/t4 turbo on STi blue&gold Proven Power Bragging 33 09-09-2005 02:01 PM
GOD: Update on your turbo kits? KnightWRXRider_ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-04-2004 11:02 PM
Updates on Turbo-Xs chips, please. redrex3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-07-2001 08:49 PM
What's the update on the "Battle of the Turbos"? Jonathan Kent General Forum Archive 5 08-29-2000 10:29 AM
