Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 09-09-2009, 10:41 AM   #1
kamil212
Member#: 90596
2009 Scrambler
Bitches love Scramblers
Default UTEC causing connection problems for the Subaru Select Monitor (dealer diag tool)
Has anybody experienced this?
I wanted to activate the impact sensor on my 08 Forester XT and the Subaru Select Monitor keeps throwing a connection problem when we try to hit the Keyless Entry Unit configuration screen. Some of the menu items work fine, but a few throw the same error. I can go into the impact sensor config screen and adjust the sensitivity but I can't turn it on since I can't get into the Keyless Entry Unit config
(I'll take the UTEC out if somebody can confirm that it is the actual problem)
Thanks
kamil212 is offline   Reply With Quote
Old 09-09-2009, 05:45 PM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I never had an issue but it's super easy to take the UTEC out of the picture. Just remove the ECU cover, 3-4 10mm bolts/nuts. Unplug the car's wiring harness from the UTEC, unplug the UTEC harness from the ECU and plug the car's wiring harness into the ECU directly.
If the Subaru select montitor still fails you have a harness of tool issue.
mick_the_ginge is offline   Reply With Quote
Old 09-09-2009, 05:55 PM   #3
kamil212
Member#: 90596
2009 Scrambler
yeah, I dont mind taking the glovebox and ECU cover off, just wanted to confirm that the UTEC is in fact the problem. I already had 2 dealers try to activate it off the books (no $100 work ticket), so if I try go in again I don't want to waste their time yet again. I want to be sure that it will solve the problem.
Old 09-09-2009, 08:54 PM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
I can't say if it will or won't but with the UTEC out of the loop at least you know it will not be affecting the results.
? - Why do you want to activate the impact sensor?
Old 09-09-2009, 11:04 PM   #5
kamil212
Member#: 90596
2009 Scrambler
because I ordered it, paid for it, installed it, and would like it to work
Subaru Select Monitor III - Available August Jon [in CT] Engine Management & Tuning 18 01-18-2011 02:01 PM
SOA Announces Subaru Diagnostic System (SDS) - Subaru Select Monitor Replacement Jon [in CT] News & Rumors 9 01-07-2005 01:41 PM
Utec hyperterminal connection problems... Homemade WRX Engine Management & Tuning 6 12-28-2004 01:10 AM
