Old 08-31-2010, 02:35 PM   #51
xJIMMYSTIx
Member#: 171698
2006 WRB
WRX COBBtuned
nice write up man!,,hey guys i have a 06wrx with the 4/2 pot subaru calipers and i was trying to find pads for them and the pads they showed me were not even the same! but i found these on tirerack
http://www.tirerack.com/brakes/brake...06&autoModClar=
here are the part numbers
front - HB178F.564
rear - HB179F.630
those look more like it but i want to make sure before i go and buy them you know?, so if anybody thats running the 4/2 pot subie calips lmk man would be a great help thanks!
xJIMMYSTIx is offline   Reply With Quote
Old 08-31-2010, 03:00 PM   #52
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
I don't recall all of the vendors who sell brake pads, but 'WRXBrakes' is usually on here and helping people out. They carry those as well as several other options. I'm certain they can match you up with the best product for your needs.
There are plenty of people who have used the HPS pads. If you search for HPS in this forum I'm sure you'll find plenty of discussions and reviews that can help you out.
Scooby921 is offline   Reply With Quote
Old 09-14-2010, 02:47 PM   #53
amigabill
Member#: 144210
2007 STI
Urban Gray Metallic
Correction, that's $1450 OEM or $700 after market for REAR pads and rotors (NO front, today I'm told their records say my front stuff is fine), they still haven't told me which aftermarket parts exactly. Waiting for their parts person to call back.
Need to make time and call WRXbrakes. Not sure if I'll have time to work myself, but this is getting ridiculous.
Originally Posted by amigabill View Post
Sorry, they want to do rotors and everything, not just pads. Some friends think I'd be OK with just pads and turn the rotors this time though. I'm just trying to find out if OEM is worth the money or not compared to aftermarket pads&rotors
amigabill is offline   Reply With Quote
Old 09-15-2010, 09:30 AM   #54
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
I always have HPS Pads here if you need any, as well as a few others you might be interested in.
KNS Brakes is offline   Reply With Quote
Old 09-24-2010, 07:18 PM   #55
LGT Kirby
Member#: 257795
1993 Legacy SS
Whinestone
Good read.
LGT Kirby is offline   Reply With Quote
Old 11-21-2010, 04:45 PM   #56
rconti
Member#: 264675
2008 Impreza Hatch
Can anyone provide some suggestions for what to look for in a pad to avoid shuddering due to pad material build-up (commonly referred to as 'warped rotors') on a fairly gently street-driven car?
I've read all of the braking threads and most of them are targeted at keeping n00bs from buying blinged-out rotors to solve their Starbucks street cred issues, and rightly so
I've got a bit of a different problem that I haven't seen addressed -- Base '08 Impreza (yes, rear drums and hubcaps all 'round). The brakes keep having pad build-up problems. First surfaced at ~20k miles, bedded in the brakes, all was good.. for a few thousand miles.. then it came back. Sure, I can keep bedding the pads, but it shouldn't be happening to begin with, so I'd like to solve the root cause once and for all.
Dealership "fixed" the problem (likely by turning the rotors), but that solution only worked for a few thousand as well.
Not a technique issue; the car is generally street driven short distances and the brakes aren't either hammered on, nor dragged (no left-foot braking, no riding the brakes, etc).
It most often surfaces when coming out of the mountains. I take care to brake moderately hard but briefly before the corner, then stay off the brakes for a long time. There's no reason they should be heating up excessively, I don't ride the brakes all the way down the hill like the clueless. Yet this problem keeps coming back. I've never even had brake issues in other cars on the track, so I don't think my technique is the problem (and no, the Impreza has not been on the track).
I'm thinking of something like the Axxis Deluxe or maybe the Ultimate Ceramics, as I've used both with good results (a fine street pad, no issues with cold bite).
My problem is that, ultimately, I don't understand the root cause. I don't think technique is an issue, but I have a really hard time believing that I'm overheating the pads with street driving like this. At this point (over 40k miles), the rotors may be going as well. I'll have to check it out and consider replacing those as well. But I don't want to throw on new rotors and pads and find the same issue.
thanks for any suggestions to keep this from coming back!
rconti is offline   Reply With Quote
Old 11-21-2010, 04:48 PM   #57
KNS Brakes
Member#: 125739
2015 WRB WRX
The root cause is the stock brake pads.
They can't take heat w/out crapping all over the rotors.
3200 lbs/small brakes/mountain driving = hot brakes
Old 11-21-2010, 05:37 PM   #58
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Stock pads are notorious for leaving deposits, especially cold deposits. Meaning, even when the pads arent warmed up to operating temperature, if you sit stopped at a light, the pads will leave crap on the rotors.
Next time you get home after driving somewhere, sit in the driveway holding the brakes for about 60 seconds, roll the car back a foot, and then get out and look at the imprints of your pads on your rotors.
I ditched the OEMs (which were done anyway) for the Stoptech that Ken sells. I had to re-bed the OEMs every 10k or so to get the pulse to go away. I havent had that problem with the Stoptechs, and to be honest, if youre not hammering on the brakes, they will likely be more than sufficient for you.
cucamelsmd15 is offline   Reply With Quote
Old 11-22-2010, 02:49 PM   #59
rconti
Member#: 264675
2008 Impreza Hatch
Thanks for the replies guys, I'm glad to have a simple, confident explanation that the pads are indeed the issue.
I looked at Ken's site yesterday and also thought the Stoptechs looked like a great option, especially for the price. I'll have to take a look at the rotors before buying pads to see if those need to go too; at 40k that's a solid possibility.
I see no need for aggressive pads; I've been fine with stock pads on BMWs, even for the track, though I currently run Axxis Ultimate Ceramics on my 'fun' car. Honestly only 'upgraded' those because when I did pads and rotors at 70k I thought it was time to try something different. So I'm sure quality street pads are all I need for the Impreza.
Old 12-28-2010, 01:17 AM   #60
rconti
Member#: 264675
2008 Impreza Hatch
As a followup, I bought a pair of Centric standard rotors and the Stoptech street pads from WRXBrakes's KNSBrakes.com site. I put them on about 3 weeks ago. They actually worked before I bedded them in which is more than I can say about most pads I've used!
Once bedded in, they perform great. Seem to have great initial cold bite, better than stock. No shudder yet. Will have to report back after I bomb down out of the mountains a few times, but I'm considering my braking issues solved.
Thanks for the advice WRXBrakes and cucamelsmd15!
Old 01-01-2011, 04:27 AM   #61
confusion
Member#: 268585
Thanks for the awesome Info.
confusion is offline   Reply With Quote
Old 08-01-2011, 09:38 PM   #62
martin_montreal
Member#: 286526
excellent article
martin_montreal is offline   Reply With Quote
Old 10-14-2011, 06:26 PM   #63
lleo1
Member#: 297895
Default Great article
Very well-written, informative article. Thank you for all the useful details...you just saved a newb from "inevitable mind-numbing fanboy brand warfare". You're the man.
lleo1 is offline   Reply With Quote
Old 10-30-2011, 08:42 AM   #64
belacane
Member#: 284180
1986 BRAT
I'll join the chorus to say thank you! super helpful!!
belacane is offline   Reply With Quote
Old 11-04-2011, 09:22 AM   #65
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Just what i WAS LOOKING FOR!!!!!
MARKSTIV8 is offline   Reply With Quote
Old 05-18-2012, 06:50 PM   #66
Exideglow
Member#: 306262
thanks helps alot
Exideglow is offline   Reply With Quote
Old 05-21-2012, 04:02 PM   #67
Johnais123
Member#: 320869
This is great! Too bad I did not read this before doing the brake job on my 2002 wrx .
Quick question for anybody since I now have issues with the (I think it's the rotor). When I changed the rotors from Stock to AC Delco with Hawk HP pads, the 2 bolts/screws that were sort of holding the Rotor to the knuckle did not fit with the new Rotors. I let them out because I figured the wheel would hold them well on there but It seems to have a little bit of loose when I hit a bump I can hear it bounce (metalic noise) and when I hit the brakes, I do hear it clicking back in (fairly loud noise).
I could use a little help on how to solve this issue...
Thanks!
Johnais123 is offline   Reply With Quote
Old 06-27-2012, 05:38 PM   #68
A.childress
Member#: 324437
2007 Impreza
Thanks so much for the information
I like how the article went in depth with the differences. You see I have been told before that Ceramic were simply the best pads to get, but it seems semi metallic would be far more to my liking. A very good thing to know!
A.childress is offline   Reply With Quote
Old 09-13-2012, 02:43 PM   #69
Lex Brown
Member#: 331143
Great article it has helped me with buy buying decisions!
Lex Brown is offline   Reply With Quote
Old 01-19-2013, 07:01 PM   #70
seto519
Member#: 290325
Which hawk is good?
seto519 is offline   Reply With Quote
Old 01-20-2013, 02:07 PM   #71
KNS Brakes
Member#: 125739
2015 WRB WRX
Originally Posted by seto519 View Post
Which hawk is good?
If you don't tell anyone what you want they have no way to recommend a pad.
Old 03-27-2013, 12:00 PM   #72
KensImpreza
Member#: 201077
2015 WRX
Thank you for the article! I sticky'd this article awhile back read it and now I am in need of brakes!
So I read the thread again and am looking for some advice on front pads and rotors. I have an 08 2.5i Premium with disc brakes all the way around. I purchased larger caliper brackets as I am looking to upgrade to WRX rotors and a better pad for the car. I would say I mostly DD the car, but I do have a lot of suspension goodies and I do like to have fun on the weekends or after a ****e day at work. Any suggestions? I know nothing of aftermarket pads, as I see people referencing hawk, ebc and the like. Any help would be appreciated!
KensImpreza is offline   Reply With Quote
Old 03-27-2013, 01:51 PM   #73
KensImpreza
Member#: 201077
2015 WRX
also going to check out this website that this thread mentions as well^^
Old 09-10-2013, 02:27 AM   #74
landforscher
Member#: 367934
Post
Recently, I pay some attention to the brake pads linings, this artical seems very useful and great readability. I notice there is another excellent artical show this topic through another side, I maybe a brake pads factory, or somethings like this.
landforscher is offline   Reply With Quote
Old 09-10-2013, 02:48 AM   #75
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well hello there, Mr. Spammer.
DIY - How to replace Stock STI Brembo brake pads CLR4ILS Brakes, Steering & Suspension 17 11-14-2015 01:55 PM
Article: How To Clean your Exhaust Tips blue-sun Mid West Subaru Owners Club Forum -- MWSOC 20 05-15-2012 02:04 PM
Endless Brake parts for Street and Track dentsport NESIC Vendor Classifieds 4 04-11-2009 12:52 PM
Brake pads for lazy butts who street and track chimchimm5 Brakes, Steering & Suspension 50 12-21-2008 03:51 AM
FS: Carbotech Panther Plus - street/track brake pads - BRAND NEW eclip5e NESIC Private Classifieds 10 04-18-2006 09:54 PM
