Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-11-2009, 08:21 PM   #26
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I still have a problem with you guys wrapping the Y pipe part of the hose into the IC. The air coming from the turbo is HOT. You don't want to keep the heat inside the pipe/hose... JMO
wrxdrvr is offline   Reply With Quote
Old 09-11-2009, 08:28 PM   #27
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
But do you want it radiating up under the ic? The ic is made to cool hot air...
TDagen is offline   Reply With Quote
Old 09-11-2009, 08:53 PM   #28
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yea, but the IC is only about 60% to 70% efficient so, cooling down hotter air is harder than cooler air if the pipe can cool itself off, when not under boost, and not heat up the air more when/if it stays hot & not just under boost. JMO but that's why you NEED, a temp probe when you do things like this.
Old 09-11-2009, 10:20 PM   #29
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
The stock Y pipe is all metal, being as it sits under the intercooler and is really close to the hot turbo, tranny, and engine, we thought the reflectice tape would be a good idea to ward off heat. If the pipe gets heated it will transfer heat into the intercooler core, which is what we don't want.
However, we are using reflective heat tape. It will reflect heat off of its outer surface. It doesn't do a very good job of keeping heat in. That's where people get confused.
Heat wrap is used for keeping heat IN.
Reflective tape or material is used for keeping heat OUT.
They cannot be used to do both. Which is why you wouldn't use heat wrap on your intercooler, or a reflectice material on your exhaust manifold.
So I think the tape on our y-pipe is doing more to keep heat out rather than in.
Circuit Motorsports is offline   Reply With Quote
Old 09-12-2009, 07:20 PM   #30
prometheum
Member#: 92003
04 bicycle!
how many rolls is required to do the up pipe and headers?
prometheum is offline   Reply With Quote
Old 09-12-2009, 11:23 PM   #31
SatinWhitePearl
Member#: 170780
2007 STi
Satin White Pearl
That intercooler looks like it got into a fight with Paul Wall, while he was selling "grills" or something other rap item-
I didn't read the whole thread, but hopefully you got some solid results!
SatinWhitePearl is offline   Reply With Quote
Old 09-13-2009, 12:27 AM   #32
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Haha yeah, it's definitely nice and shiny now.
And it definitely works, keeps the heat out during regular driving. We haven't track tested it yet. We will soon though....
Old 09-14-2009, 11:34 PM   #33
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Nice write-up guys, as usual
slowscooby is offline   Reply With Quote
Old 09-15-2009, 04:29 PM   #34
Boogaloo
Member#: 219280
Originally Posted by Circuit Motorsports View Post
It *should*, it is a low profile blanket with a tight weave. I am not runing one on my car because there isn't enough room with my large turbo, water line and big TMIC.
The stock heat shield is in place on my car and I run a GT3076
Boogaloo is offline   Reply With Quote
Old 09-16-2009, 12:38 PM   #35
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Stock heat shield is pretty tight. Being as this blanket is such a low profile item, I think you will still be able to get it to fit, you need about an 1" or so of clearance.
Old 09-17-2009, 04:49 PM   #36
OBPNUT
Member#: 114652
06 OBP WRX
86 VW Scirocco
Ive got the blanket and just heat wrapped my Grimmspeed manifolds and EWG kit. I used about 65 ft of the wrap on just that alone. I have yet to install everything (need funds for turbo), but DEI makes some awesome stuff.
BTW, What could you do for an EWG?
OBPNUT is offline   Reply With Quote
Old 09-17-2009, 07:08 PM   #37
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
remember to not wrap the flex joints!!
Justin
GrimmSpeed is offline   Reply With Quote
Old 09-17-2009, 08:07 PM   #38
OBPNUT
Member#: 114652
06 OBP WRX
86 VW Scirocco
Justin
Oh I didnt. Cant wait to get everything on. Damn recessiion!!!
Old 09-17-2009, 09:31 PM   #39
Daluv
Member#: 159325
Does the turbo blanket can affect the life of a stock IHI turbo?
Daluv is offline   Reply With Quote
Old 09-17-2009, 11:37 PM   #40
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
If it did affect it, it would be negligble.
Old 09-20-2009, 06:27 PM   #41
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Justin
Good advice
Old 09-20-2009, 09:28 PM   #42
OBPNUT
Member#: 114652
06 OBP WRX
86 VW Scirocco
I still want to see what you guys can come up with for an EWG.
Old 09-21-2009, 01:14 AM   #43
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Are you trying to wrap the external wastegate up-pipe and associated piping or the actual wastegate unit itself?
The unit itself might be able to use the turbo blanket for ease of installation, but the regular heat wrap could be wrapped around it with similar results if you are looking to retain heat.
Old 09-21-2009, 11:23 PM   #44
OBPNUT
Member#: 114652
06 OBP WRX
86 VW Scirocco
The UP is wrapped. Just wondering what you guys could come up with. You did so well with the top-mount.
Old 09-22-2009, 12:04 PM   #45
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Oh we can come up with something
I don't have an external wastegate on my car so I don't really know where it sits exactly, size, space, etc.
BUT.....DEI has a universal turbo blanket, it's made to be able to wrap around a turbo and custom fit it. This could probably be cut down to size and wrapped completely around your EWG.
We didn't use this because their new Ti Turbo blanket is fitted and lower profile. But this should work great for what you need.
Feel free to PM us
Old 09-22-2009, 09:40 PM   #46
OBPNUT
Member#: 114652
06 OBP WRX
86 VW Scirocco
Not a bad idea. You guys are pretty inventive.
Old 09-23-2009, 07:40 AM   #47
bannerd
Member#: 110771
2006 WRX
black
I need a turbo blanket with ties; hit me up!... I have my down pipe already wrapped. I didn't get those fancy ties though, I had to use stainless steel clamps I bought off amazon for 4$.
bannerd is offline   Reply With Quote
Old 09-23-2009, 01:03 PM   #48
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
PM sent
Old 09-23-2009, 04:26 PM   #49
oguitar
Member#: 206720
2002 WRX Wagon
I bought a bag of those stainless steel tie wraps at harbor freight for about 8$. There were quite a few tie wraps in the bag.
oguitar is offline   Reply With Quote
Old 09-23-2009, 04:45 PM   #50
Circuit Motorsports
Member#: 220868
2005 STi Urban Camo
Orlando, FL
Any steel locking ties will work, just make sure you get at least a 14" tie, or it will not wrap around the Downpipe.
I checked Lowes and the longest they carry are 11", they dont work.
You can always put two ties together, but sometimes that doesn't quite work right.
SCCA AUTO-X: Bartlett Beat in the Heat Bonanza JordyB Alaskan Impreza Club Forum -- AKIC 65 08-13-2008 12:57 AM
Beat the Summer Heat With the All-New Portable Seat Cooler! NYCshopper Non-Subaru News & Rumors 5 01-06-2007 12:05 PM
How are you beating the heat? upnygimp Off-Topic 9 09-27-2006 05:34 PM
Beat the Heat iWayner South East Region Forum 5 07-25-2003 06:13 AM
Austin: Beat the Heat TriniTuner Texas Impreza Club Forum -- TXIC 7 02-14-2002 10:20 PM
