Old 05-07-2002, 07:23 PM   #1
Jessie James
Member#: 2072
Default JC Sports turbo kit - do you have it and do you like it?
I am just trying to find out who has (or had) the JC Sports turbo kit, and if you like(d) it or not.
Any significant issues? Let me know...
Jessie James is offline   Reply With Quote
Old 05-07-2002, 07:51 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
JC Sports has suck!
kastle is offline   Reply With Quote
Old 05-07-2002, 08:00 PM   #3
Rovah
Member#: 1375
2003 WRX Rally Car
Please tell me they're not back in business?! :-( Do a search and see how JC Sports screwed a bunch of us out of thousands of dollars in their great turbo GB.
Buyer beware...
John
Rovah is offline   Reply With Quote
Old 05-07-2002, 08:04 PM   #4
Jessie James
Member#: 2072
No, I was just talking about the hardware, not the business. Was the hardware any good?
Old 05-07-2002, 08:06 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
IIRC, it was decent at best. Personally, I'd go with Vishnu, Ludespeed or FAT before I go with JC Sports... Hell, I wouldn't even take a JC Sports turbo kit for free if you gave it to me. Why?
'cause JC Sports has suck!
Old 05-07-2002, 08:23 PM   #6
Rovah
Member#: 1375
2003 WRX Rally Car
What he said! :-) Honestly, I never saw one of their kits(although I paid for part of one). I would go with one of the other obviously reputable vendors out there. There must be some guys in your neighborhood with a JC kit that you can look at?
Good luck! John
Old 05-07-2002, 09:54 PM   #7
Andrew
Member#: 1170
2005 STi
i dont know what you guys are talking about. the JC sports kits were very good, they just had piss-poor customer service.
James, i will be selling my kit soon, PM me for details.
Andrew is offline   Reply With Quote
Old 05-07-2002, 10:22 PM   #8
Rovah
Member#: 1375
2003 WRX Rally Car
Andrew,
Glad you got a kit and like it. I never said that the quality was poor. We were commenting on the fact that JC Sports accepted thousands of dollars as deposits for kits and never produced them and issued very few refunds.
This far exceeds any definition of, "piss poor service." There are many other terms I can use for it, but service is not on the list anywhere.
Regards, John
Old 05-07-2002, 10:24 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, their kits were actually excellent in quality. Not that they made them themselves or anything, just shopped them out. But they are VERY well pieced together and fit very well in my dealings with the kits.
Old 05-08-2002, 12:10 AM   #10
Jessie James
Member#: 2072
Okay, that is what I was looking for - that the hardware was actually decent. Thanks folks!
Old 05-08-2002, 03:08 AM   #11
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
I have most of the piping for my current kit. And 8Complex has seen the quality of that kit.
JC Sports business practices bordered and passed over the boundries of legality and fair practices, but most of their products were good.
Some of the best parts of the kit include the fact that it does have all the cats and sensor bungs for the stock O2 sensors.
The fittings needed for the coolant feed/return and oil feed are all well thought out and routed, including oil feed from the block and coolant feed from the block. The crank case breather catch tray is a nice touch as well. No need to cut the stock hoses as the Y fitting and extra bit of hose just plugs right in.
The way I'm redesigning the whole system should allow me to get away with zero CEL. Which will help immensly when I go for my pollution check.
The only few things that I will probably change and some parts address in the future include the blow off valve position, moving it to the intercooler if possible. Changing/modifying the intake tract and filter.
Some things already addressed:
Rain shroud for turbo.
Jethot all pipes.
Additional O2 port for TecII sensors.
TecII and larger injectors for fuel system and ignition control
Cold air baffle for filter.
Larger ball bearing turbo (My pick VF23)
3" cat back
Larger Spearco intercooler
I should note that I didn't get the JC tapped oil pan and am regretting it every day. We are still trying to figure out a good way to route the return.
Checking my notes from the previous owner, this setup should allow the turbo to fully spool (8psi) by about 2300-2500 rpm. But at 9psi, the turbo will be past its efficiency point by 6000 rpm. If I need more boost, I'll probably need to install that Chalak gearset first!
Revision is offline   Reply With Quote
Old 05-08-2002, 03:26 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
EXACTLY...the kits were impressive(the few that were complete)...GodSpd6 had one on his RS before he ditched it for the WRX...very inpressive kit minus the crappy BOV mouting they had.
Just my $.02
jeremy
Old 05-08-2002, 05:19 AM   #13
Ethan
Member#: 246
I have a ball bearing upgrade, or so they said, and I get 8psi by about 3200rpm...I'm not sure if you could get it much lower. I run a tec-2 also.
Yes I think the kit was very good...though to tell the truth, I've only seen 1 other aftermarket kit on another RS and you can't get that kit anymore either (minnam). On the JC Kit the only fitment issue was the oil return line, needed a little bending, but that was it. Everything went in smooth.
Its too bad they ran their company the way they did, I think I was the very last person to get a kit, and I count my blessings that I did get it.
Ethan is offline   Reply With Quote
Old 05-08-2002, 08:21 AM   #14
Revision
Member#: 242
MY05 PSM GGA !STOCK
RS25.com here is trying to decide if he wants to make more.
Old 05-08-2002, 11:09 AM   #15
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default My Kit
Overall my kit was pretty good. I make the car nice and quick and once I called JC Sports everyday I got it and all the parts. My only thing was I never got a bracket to help support the down pipe. I also never clocked the trubo do make for a cleaner install. This kit will be in my next car but I will have the expericance for a cleaner install. I have also heard that 8psi is the max effiancy for this turbo. Does anyone know if that increases when I got to a 2.2l instead of my orgional 2.5?
Joshua
yebokmj is offline   Reply With Quote
Old 05-08-2002, 03:17 PM   #16
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Well, with the 2.2L, boost is going to be a bit more lagging than the 2.5, so technically you should have some increased efficiency due to less exhaust gas driving the turbo and/or smaller displacement engine.
Graham
Graham is offline   Reply With Quote
Old 05-08-2002, 05:07 PM   #17
yebokmj
Member#: 2213
Brilliant Red
Default My thoughts
Yeah that's what I figured thanks for the response.
Joshua
JC Sports turbo kit is burning oil and IC is not working (its cold!) Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-08-2001 10:55 PM
JC Sports Turbo kit disponible nativo Puerto Rico Impreza Club Forum -- PRSIC 0 02-09-2001 04:21 PM
Why buy a JC Sports turbo kit? read here! Pimp-sube General Forum Archive 17 11-14-2000 10:39 PM
JC Sports turbo kit.......$1,999.00!! ChúSacSVT Puerto Rico Impreza Club Forum -- PRSIC 7 10-03-2000 08:05 AM
Does anyone here have a Jc Sports turbo kit? ImprezaRX281 Technical Forum Archive 0 09-21-2000 03:15 PM
