Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-11-2009, 08:29 PM   #1
nostra
Member#: 219274
2009 STi
DMG
Question STU legal downpipe for GRB STi ?
I'm wanting to stick in the STU class for my new 2009 STi and am trying to get current info on the best downpipe options to consider for a GRB STi. I've seen a number of old threads on the subject but nothing current to consider new products and SCCA rule changes.
Is this only the Cobb DP? Perrin DP? Any specific experience with these working correctly/legal for STU on a GRB you can share? Also, if this rule passes that won't allow ANY custom mapping, does this basically mean getting a downpipe is pointless for STU AutoX as it can't be tuned to work correctly?
From an STU rules stance this mainly effects 4 areas for those that don't know:
(1) inlet of the single replacement converter may be located no further downstream than 6" along the piping flow path from the original exit of the final OE converter.
(2) this downpipe needs to not cause a CEL and mapping cannot be used to keep CEL from triggering.
(3) STU doesn't allow for any change in mapping that affects boost levels (and shortly due to May fastrack submission maybe illegal for ANY illegal mapping)
(4) Heat shield requirements that I can't seem to find right now, but effectively right now requires custom heat shield trimming to be STU legal.
Thanks in advance!
nostra is offline   Reply With Quote
Old 09-12-2009, 11:44 PM   #2
nostra
Member#: 219274
2009 STi
DMG
From other posts, I assume that a DP like the Invidia and Helix are fine for STU assuming they don't throw a CEL because the replacement high flo cat is further upstream in the pipe than OE so this doesn't violate the following rule:
4) Be used in the same location(s) as the OE converter(s).
This does allow for high performance replacements, provided they meet all restrictions herein.
STX, STU:
Any high flow catalytic converter(s) are allowed, but must attach
within six inches of the original unit. Multiple catalytic converters
may be replaced by a single unit. The inlet of the single
than 6"
final OE converter
Old 09-13-2009, 08:17 AM   #3
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
You are allowed per rules to modify the heatshield cover the turbo and downpipe for fitment.
2superblus is offline   Reply With Quote
FS in GA: Invidia Q300 CBE for GRB STI shu_chen4 Engine/Power/Exhaust 1 06-21-2012 05:04 PM
Sold law MWSOC Private Classifieds 2 06-10-2010 12:03 AM
Installing springs for GRB STi ? Boostedwrxsti Brakes, Steering & Suspension 2 06-05-2009 12:04 AM
AEM Cold Air Intake system for GRB STI SoCalMonarch Car Part Reviews 3 05-20-2009 03:18 PM
Any C.A.R.B. legal intakes for 2006 STI? e-zee Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 07-13-2007 07:17 PM
