Old 05-07-2002, 08:37 PM   #1
ImpreziveRS
Member#: 6312
2001 Impreza 2.5 RS
Blue Ridge Pearl
Default WRX motor swap into GC8....
Ok, i'm doing this swap this summer. I'm getting the motor, ecu, tranny and engine mounts from my friend who's putting the STi motor in his WRX. My question is what other parts do i need for this swap? Do I even need his tranny or his mounts? Will I need a new/different crossmember. I'm trying to figure out all the parts I need so I can get ahold of them before I attempt the swap. Any help would be greatly appreciated.
Thank ya much,
Kyle
ImpreziveRS is offline   Reply With Quote
Old 05-07-2002, 09:26 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I don't mean to be an @$$, but have you tried searching yet? I found these good threads by searching...
EJ20 turbo engine transplant in an RS
and
Are there any websites that document Impreza engine swaps?
and
MY02 WRX into RS
kastle is offline   Reply With Quote
Old 05-07-2002, 09:26 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
whoops... one more
STI engine swap questions
Old 05-07-2002, 09:34 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
One more from RS25.com
wrx conversion
Old 05-07-2002, 10:29 PM   #5
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
This is on Kastles behalf...........
jetfan8178 is offline   Reply With Quote
Old 05-07-2002, 10:35 PM   #6
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
LMAO
Old 05-08-2002, 01:38 AM   #7
SubaFastR
Member#: 5786
Kevin, always the meanie moderator! Did you read those threads? They are totally useless. I am considering this myself. I read somewhere today that someone has ecu plugs that could allow a plug and play solution to wiring harness issue. Once there is a wiring diagram made for us to follow, I am so there.
Kevin
SubaFastR is offline   Reply With Quote
Old 05-08-2002, 10:36 AM   #8
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Sorry Kevin, but those threads answer his questions, as they were typed out above.
Old 05-08-2002, 12:07 PM   #9
SubaFastR
Member#: 5786
Maybe, but you're still a meanie!
Old 05-08-2002, 12:11 PM   #10
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
and to think, I was being extra nice....
Old 05-08-2002, 12:16 PM   #11
SubaFastR
Member#: 5786
I know, you posted the links and everything. I am just against telling people to search because every day, people learn new things and have new ideas. If we only search, and not ask again, those ideas never come out.
Old 05-08-2002, 12:43 PM   #12
Charge
Member#: 3313
I don't think he was being mean. And no one is against discussing this stuff all over again. It's just, there are some basic facts that a lot of people don't understand. No one wants to keep repeating those over and over again. Read up. Then, come in, and ask more specific questions. Oftentimes, the questions asked are a little too vague/open-ended for anyone to give you a definitive answer. That's why everyone suggests a search. If you come in with a question and say: I know this is true, and this, so if I want to do "X", is there another way to do it without doing "Y"?
Questions that indicate the user has either really thought about what they are asking or possibly searched on it, are usually discussed freely. If someone suggests doing a search, they usually direct them to a thread that addresses that exact issue. And that's more efficient for everyone. No re-typing of information. Also, all the posts are already there. You don't have to wait days for someone to come in and make their comment. It's already been made(hopefully).
You can continue to discuss it as well, possibly reviving the old thread, so to keep all the information in one location(which is a huge bonus when searching).
Kyle, we need to talk
I wanna know what you're doing.
Neil
Charge is offline   Reply With Quote
Old 05-08-2002, 01:37 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I believe the front diff. ratio is different then your car, so you'd either want to not swap in the trans, or swap in the trans and the rear diff at the same time.
You won't need his mounts, but a good set of STI's or GroupN mounts would work well. You will need a turbo crossmember, though... and you won't be able to use a new-style WRX's. I think the Legacy turbo crossmember will work though. Junkyard or dealership should be able to get you that.
Old 05-08-2002, 04:54 PM   #14
christoph1371
Member#: 1090
ImpreziveRS
We have done 3 swaps here in Sunny CA. To answer your questions:
1.Yes you'll need his engine mounts (unless you decide to upgrade)
2. no you do not need his tranny
3. new or differcrossmember??? compared to what!? despite what you here on this board from people who have never done this conversion...yes you can use the wrx crossmember. you can also use the legacy turbo xmember
Here are some other tidbits I will give you:
Donít forget the wiring harness, get the fuel pump and get a set of Subaru owners and maintenance manuals. you'll need those too
good luck,
Chris
i-speedusa.com
christoph1371 is offline   Reply With Quote
Old 05-09-2002, 01:50 PM   #15
RimRockaz
Member#: 2947
2000 GC6 ej20 swap
fast n furious pt III
Here is my car, one of the three wrx conversions done by I-Speed USA.
http://members.i-club.com/ViewMember...?MemberID=2771
Calvin
RimRockaz is offline   Reply With Quote
Old 05-09-2002, 01:54 PM   #16
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
damn you guys... beat me to it... I was just reading your thread over in BAIC... Questions for those who have done the RS->WRX engine swap... and am going to add it to the FAQ... good info there....
Calvin, sending you a PM
Old 05-10-2002, 03:03 AM   #17
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
I just wanted to say that swap is incredibly clean. Good work by all those involved.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 05-10-2002, 01:49 PM   #18
gypsymoth
Member#: 6072
01 Silver 2.5 RS
04 Silver WRX STi
Hi Chris,
How much does it cost to do this swap?
Chieh
gypsymoth is offline   Reply With Quote
Old 05-10-2002, 02:32 PM   #19
christoph1371
Member#: 1090
Chieh,
It really depends on a few things.
1. Where are you getting your parts
2. What you actually WANT in the swap
3. What aftermarket components will you be buying (clutch,flywheel, exhaust etc)
4. The availability of a donor car (supply and demand)
FYI it takes us ~40hrs (start to finish) to do the whole thing.
No job yet has went over 8k (and no they weren't 7999.99). There are a few I am working on now that will exceed that 8k amount because that person wants A LOT of aftermarket goodies put in too.
Old 05-10-2002, 04:54 PM   #20
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Does 8000 include the parts?
Engine,tranny and such
Old 05-10-2002, 05:13 PM   #21
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
By the way,Does anyone know if there is someone in Jersey doing these swaps and what kind of prices?
Old 05-10-2002, 05:45 PM   #22
christoph1371
Member#: 1090
Yes, when I said that no job YET had went over 8G.... I meant EVERYTHING including the kitchen sink...if they bought one
FYI if you did a bone stock conversion, it would be a lot less.
how much less you say, well review points 1 and 4 above.
ps. jetfan8178 - read my post in this thread. it will answer your tranny question.
Old 05-10-2002, 06:03 PM   #23
gypsymoth
Member#: 6072
01 Silver 2.5 RS
04 Silver WRX STi
Chieh,
Thanks! That sounds reasonable. It gives me a ball park. I guess if the engine was 4-5k, then the labor would be between 2-3k, depending on the modification, correct? My original question was for a bone stock conversion.
Chieh
Old 05-10-2002, 06:10 PM   #24
jetfan8178
Member#: 15669
2009 Cadillac
STS-vvvvvvvvvv
Thats a darn good deal if it includes everything.
When are you coming over to do my car?
Old 05-10-2002, 08:19 PM   #25
christoph1371
Member#: 1090
I am a consultant. Draft me a proposal and we will talk about it
Chieh - you are correct.
'05 Wrx motor swap into '02 Wrx *Need Help Badly* ZRO Subaru Conversions 2 03-01-2010 03:22 PM
Turbo motor swap into GC8 Jaredm82 Subaru Conversions 7 05-04-2004 08:23 PM
anyone done a USDM WRX motor swap into a RS? ^jynx^ Tri-State Area Forum 15 01-02-2003 07:27 PM
Who had WRX motor put into GC8 at dealership? Ikonosin General Community 9 01-02-2003 03:16 AM
wrx motor swap into an RS coupe INeedSubyHelp Newbies & FAQs 1 12-04-2002 03:02 PM
